Old 03-21-2020, 05:43 PM #1
Ser1clymb's Avatar
Ser1clymb Ser1clymb is offline
Ser1clymb is on a distinguished road
Ser1clymb's Avatar
Timing Belt Conundrum
I figured with everything going on and since I'm working from home now would be a great time to do some maintenance and change my timing belt, WP, etc.
I followed Tim's instruction video (Thank you very much) and it went surprisingly well, other than the tensioner bolts being rounded and having to take the whole A/C compressor off to get to them.
Once back together, I went to start it and it cranked up and then immediately died. I tried giving it some gas, and still only ran for a few seconds and died. Waited a day, came back and same results.
*Full disclosure, I made the mistake of trying to change other stuff while I had it all apart. I cleaned the throttle body, changed IAC valve and gasket (reverted back to old IAC, and changed coolant temp sensor.
I stripped it down to check timing again and everything still lines up.
I did a little cleaning while in there with some compressed and paper towels but only sprayed throttle body with any cleaner.
I would really appreciate any input and things to check or test and see what I could have screwed up. I've read through other threads and checked all connections to make sure they're in-tact, but can't find anything wrong.
"Bettie" - 1998 4runner LTD E-Locker Evergreen Pearl 275K+, Alpine HU, Infinity Reference Speakers, Airraid MIT, B&M Cooler, Light Racing UCA, RCI skids, Bilstein Tundra 5100 and 4runner Eibach Coils in front/ Bilstein FJ 5100 and OME 890 rear, LC80 wheels wrapped with MT Baja ATZ 285/75/16, 99+ overhead console, 99+ center console, sound-deadening, Ditch lights
Ser1clymb is offline   Reply With QuoteReply With Quote
Old 03-21-2020, 05:59 PM #2
TheSaturnV TheSaturnV is offline
TheSaturnV will become famous soon enough TheSaturnV will become famous soon enough
Check the big 3: Fuel, air, spark.
Did you disable the fuel pump during the procedures?
Spark is easy enough to check.
I suspect something not put back together correctly with the TB.
TheSaturnV is offline   Reply With QuoteReply With Quote
Old 03-21-2020, 06:38 PM #3
Ser1clymb's Avatar
Ser1clymb's Avatar
Thanks for the quick reply. I have those since it is starting and running, just not well. I wonder if I could have screwed something up when I took the throttle body off and cleaned it, but I think it would have dried out and would run by now.
Could the mixture be out of whack? When I tried running it, and repeatedly cranking it, it smelled strongly of gas afterwards.
Old 03-21-2020, 06:56 PM #4
mtbtim's Avatar
mtbtim mtbtim is online now
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Did you remember to reconnect the cam position sensor?
Did you double check all vacuum lines are properly connected?
Why did you replace the IAC and then go back to the old one?
mtbtim is online now   Reply With QuoteReply With Quote
Old 03-21-2020, 07:45 PM #5
HiLife HiLife is offline
Double check your cam, crank and maf sensors conections. Make sure they are secure and tight when trying to start the engine.
Old 03-21-2020, 07:47 PM #6
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
Always double check this....so easy to mess up.
My Backyard Frame Swap
Old 03-21-2020, 08:26 PM #7
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
Pull one of the plugs and see if it smells like gas. Sounds as if there is no fire.
Did you change the crank seal?
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 03-21-2020, 09:02 PM #8
Ahh, I read that it ran for a few seconds then died. Agreed that the fuel smell points towards IGN.
Old 03-22-2020, 04:47 PM #9
Ser1clymb's Avatar
Ser1clymb's Avatar
Yes I checked the cam and crank sensors to make sure they were plugged in good and tight. Could coolant spilling on the crank sensor plug cause it to short? When I replaced the thermostat some coolant poured out onto the plug.
I reviewed my vacuum diagram before starting it to make sure all the hoses were on.
I had a high idle thing going on and bought a remaned IAC off ebay to try and fix it. When I plugged it in the connection wasn't great, and the lack of any part number made me think I got cheated, so I immediately put the old IAC back on. But that was after trying to start it.
Old 03-22-2020, 04:48 PM #10
Ser1clymb's Avatar
Ser1clymb's Avatar
Thanks. I found that to be a common issue when searching, but I made sure all were plugged in good and tight before starting it.
Old 03-22-2020, 04:50 PM #11
Ser1clymb's Avatar
Ser1clymb's Avatar
[IMG][/IMG]
Thanks for replying.
I didn't remove the plugs or wires. They are still in good shape, only about 1.5 years old.
Old 03-22-2020, 04:53 PM #12
Ser1clymb's Avatar
Ser1clymb's Avatar
I did not change the seals. I was going to, but they looked fine and weren't leaking, so I didn't mess with them.
I'll try pulling a plug and see what I find. It does run upon cranking it, but then stalls and dies.
Old 03-22-2020, 05:04 PM #13
If you have fire, plugs aren’t gas wet, and you can manually turn over the engine at the crank and all the marks line up every time, consider that it may be a problem that occurred when you took to cleaning the IAC. Vacuum line not hooked up, ete.
Old 03-22-2020, 05:04 PM #14
plcfcng's Avatar
plcfcng plcfcng is offline
Location: Southern California (please don't hold it against me)
Real Name: michael
plcfcng will become famous soon enough plcfcng will become famous soon enough
plcfcng's Avatar
Real Name: michael
The picture you provided were bit unclear did the cam and crankshaft marks line up correctly after hand spinning the cranksaft?
plcfcng is offline   Reply With QuoteReply With Quote
Old 03-22-2020, 05:05 PM #15
Coolant temp sensor OEM?
back , changed , check , died , timing
3rd Gen Timing Marks for Timing Belt Replacement FTW1996 3rd gen T4Rs 4 10-01-2015 04:00 PM
Timing belt? or Timing chain? MNguns General Discussions 3 06-24-2013 12:06 AM
Timing Belt Tensioner: Should I replace it when doing the timing belt change? Lugnutz 3rd gen T4Rs 14 05-12-2011 12:58 PM
Aisin timing belt kits vs. Dayco Timing Belt Kits drz Maintenance/Detailing 1 10-11-2010 06:42 PM
