Old 03-22-2020, 07:31 PM #1
fan of fanboys fan of fanboys is offline
fan of fanboys is on a distinguished road
error code p0420: O2 sensor or catalytic converter?
out driving tonight and CEL popped on. Quick OBDII scan and p0420. Attached is a screenshot. I really hope I do not need to replace the catalytic converter but I feel like that is the issue
[IMG]
[/IMG]
fan of fanboys is offline   Reply With QuoteReply With Quote
Old 03-22-2020, 07:35 PM #2
I will add a few notes:
it has spent most of the last 6-8 months sitting, very little driving.
I had the MAF cleaned right before I stopped driving it along with new spark plugs
Last week I took it to the mechanic and had the following done:
Knock sensors and harness
Spark plug wires
Heater hose
All three serpentine belts
Radiator coolant hose
Timing belt
Water pump
Radiator and new antifreeze
Trailer wiring harness
Camshaft seal
Intake manifold gasket
Thermostat and seal
Valve cover gasket
PCV valve and grommet
Radiator cap
Couple oil cooler hoses
Prior to tonight, it has been driven probably 10 miles since I picked it up. Tonight I drove it for 15-20 minutes before the light came on
So I was thinking maybe I drive this old tank of gas out and fill up. Should I bother adding something to the tank such as cataclean? Should I take it back to the mechanic Monday and have them look at it?
Old 03-22-2020, 07:37 PM #3
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
A quick way to test your catalytic converters is with your nose. Start the car, let it warm up and go out near the exhaust pipe. If the cats are failing, they will start to allow NOx, hydrocarbons and O2 and other gases to pass through. The easiest ones to smell is NOx which smells like skunk spray and rotten eggs and hydrocarbons which smell like fuel. If you smell that then yeah, your cats have failed.
If not and just smells like plain 'ol car exhaust the rear oxygen sensor is all that's needed. Very simple fix and you can find your replacement sensor here: Find My Part.
326WHP 347TQ
Old 03-22-2020, 08:34 PM #4
MaineRunna's Avatar
MaineRunna MaineRunna is offline
MaineRunna will become famous soon enough MaineRunna will become famous soon enough
MaineRunna's Avatar
The work done by the mechanic should be checked for vacuum leaks etc. Also check your exhaust for small leaks around the cat, or near the downstream O2 sensor.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
MaineRunna is offline   Reply With QuoteReply With Quote
Old 03-23-2020, 02:22 PM #5
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Or could be like mine with new cats/02 sensors that never hits a P0420 Until, you drive it slowly (5-10 mph, usually at deer lease) for a couple miles, boom every time like clockwork.
Reset and can be driven thousands of miles until....so maybe Nothing really at all.
If you don't believe my scenario, google it, lots of others can replicate P0420 the same exact way, mall cruisers too but didn't wanna' throw them under the bus....
2001 Limited 4WD - 349+K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL - StopTech ANGLED rotors - In series 699 trans cooler, New Yota1 transmission, All new OEM suspension front to rear.
catalytic , converter , error , hope , p0420
Error Code P0353 & Catalytic converter repair islandfellow 4th Gen T4Rs 6 01-07-2016 12:05 PM
2000 sr5 Catalytic Converter Replacement (P0420 Code) mattkasparian 3rd gen T4Rs 2 01-12-2015 01:28 PM
Catalytic Converter Replacement (P0420) fish0281 3rd gen T4Rs 13 11-15-2014 06:29 PM
Catalytic converter P0420 Please help Nimphius27 4th Gen T4Rs 3 06-07-2011 08:18 AM
Catalytic converter P0420 Please help Nimphius27 4th Gen T4Rs 2 06-06-2011 11:08 PM
