Old 03-24-2020, 10:08 PM #1
jman11788's Avatar
jman11788 jman11788 is offline
jman11788 is on a distinguished road
jman11788's Avatar
Chasing a hard brake pedal issue
I’m having issues with having to use a lot of effort to stop the truck.
I’ve been chasing it for awhile now as I’ve replaced some parts
New master cylinder
New brake booster
New calipers
Bled the system very liberally
I’ll also mention the ABS light is on. I have a about 7 codes for the ABS and I guess my next thing will be to replace the speed sensors. Also I have checked to see if the engine is pulling enough vacuum. My tool was reading 18-20” lbs of vacuum, so seemed good there.
After replacing all the parts and bleeding the system there was ZERO change. I’m thinking there maybe air in the ABS module but have no clue how to diagnose. Also if there is air in the module would I have to replace the unit and how easy it would be to replace. Thanks
2000 Limited 4wd Supercharged with E-Locker
jman11788 is offline   Reply With QuoteReply With Quote
Old 03-25-2020, 04:08 AM #2
The vacuum check valve in the brake booster is know to do that when it fails.
Air in the system is usually associated with soft pedal feel and long travel.
Old 03-25-2020, 07:26 AM #3
Captsolo Captsolo is offline
Captsolo will become famous soon enough
Take it to a professional brake shop and pay to have them fix. Throwing parts when you are not an expert is not the way to go with brakes, calipers, fluid, MC, air in line,
2005 4runner 150,000 miles SR5 1 brake job at professional shop where they do hundreds of brakes on all vehicles = $200 + parts / new calipers / new pads / rotors / test drive.
Captsolo is offline   Reply With QuoteReply With Quote
Old 03-25-2020, 09:36 AM #4
spartacus's Avatar
spartacus's Avatar
New master cylinder
New brake booster
New calipers
What are the codes. you can also clean the abs sensors at the wheels also check for vacuum leaks.
Old 03-26-2020, 11:03 AM #5
jman11788's Avatar
jman11788's Avatar
Don't remember the codes. However, i cleaned all the sensors and the ABS light went off!! Still don't have much power assist to the brake pedal though. I'm almost certain its because there is air inside the ABS module..
If i replace this part do i have to bleed anything in the system? Or can i just bleed the one I have now ?
Old 03-26-2020, 11:40 AM #6
spartacus's Avatar
spartacus's Avatar
Assuming you bench bled the master cylinder before the install. Drive the truck on a gravel or dirt road if possible use the brakes so that the abs system kicks in a few times then take it back to where you can work on it and bleed the brakes with motor running and see if it helps. I still think there is a vacuum issue. My limited experience, hard brake pedal is always almost due to vacuum issues and brake booster. Air in the system normally leads to spongy brakes.
Old 03-26-2020, 12:05 PM #7
I did front hoses and had a great pedal until the abs activated in the rain. Then pedal went to mush.
Bleed the brakes and firm pedal until abs activated but not as mushy as first time.
Third time was a charm. Pedal felt the same after abs activation.
abs , air , parts , replace , vacuum
Hard Brake Pedal During Panic Stops - Brake Booster? Friday88 3rd gen T4Rs 24 Yesterday 12:14 AM
Hard brake pedal solved - Vacuum issue - greeney 3rd gen T4Rs 25 03-14-2023 01:47 PM
Strange brake issue - hard pedal Renton4runner 3rd gen T4Rs 22 11-15-2019 04:11 PM
Brake pedal hard to push down shoota 3rd gen T4Rs 40 04-23-2019 09:26 PM
Hard Brake Pedal? Brake Accumulator? beatadrum 4th Gen T4Rs 2 02-17-2018 12:33 AM
