Old 03-26-2020, 01:05 AM #1
3RDGENGuy's Avatar
3RDGENGuy 3RDGENGuy is offline
Real Name: Matt
3RDGENGuy is on a distinguished road
3RDGENGuy's Avatar
Real Name: Matt
Quick questions: 3rd Gen Problems.
Hey so when I go and pull the release lever for the gas cap I get no tension and it doesn’t open. I have to push the gas lid to get it to open. What do I need to buy a spring or new cable? I examined the entire cable.
I also replaced my rear hatch bottom latch and now it won’t lock. Is there a reset or is that part defective? It doesn’t respond to my door locks.
And finally! Quick questions: 3rd Gen Problems.
I replaced my front brake hoses to correct the pull when I brake hard and the steering wheel still moves a little. Maybe rotate my tires or adjust the rears brakes? Or bleed the crap out of them? I bleed them three times
Thanks Guys!
I’m home and bored during this crazy time and would like some help! Quick questions: 3rd Gen Problems.
3RDGENGuy is offline   Reply With QuoteReply With Quote
Old 03-26-2020, 01:37 AM #2
Mark_BC's Avatar
Mark_BC Mark_BC is offline
Real Name: Just call me the Grease Monkey
Mark_BC has a spectacular aura about Mark_BC has a spectacular aura about
Mark_BC's Avatar
Maybe your rotors are warped and need turning
My Snow and Sand build thread
Mark_BC's 2000 Limited Salvage Build
Determined to keep them from becoming parts trucks. Yes, even the one I just picked up as a parts truck...
Mark_BC is offline   Reply With QuoteReply With Quote
Old 03-26-2020, 06:28 AM #3
G_Raw's Avatar
G_Raw G_Raw is offline
G_Raw has a spectacular aura about G_Raw has a spectacular aura about
G_Raw's Avatar
I bought a spri mgg at hardware store for 3 bucks or something close to that 5 yrs ago and my gas cap door still works great. I'd start with the spring.
G_Raw is offline   Reply With QuoteReply With Quote
Old 03-26-2020, 09:10 AM #4
Bad Luck Bad Luck is online now
Real Name: Patrick
Real Name: Patrick
Thanks Guys!
Sounds like you have a control arm bushing going bad. Have someone brake hard from 3-5 mph while you watch the tire for a shift in toe. Start with whichever side it pulls to.
Bad Luck is online now   Reply With QuoteReply With Quote
Old 03-26-2020, 12:00 PM #5
sportscarfan's Avatar
sportscarfan sportscarfan is offline
sportscarfan will become famous soon enough
Same thing happened on mine recently - the spring fell off because the plastic clip on the inside of the fuel filler door broke. Fortunately, I heard it fall when I opened the filler door.
I tried to epoxy it back in place, but on the next fill-up, I again heard the spring hit the ground.
Plan B for now, to open the fuel door, I have a 6' dog leash I clip onto the under-dash release so I can reach the door to open it.
Time to look into plan C.
Edit - Plan C = Looks like the OEM spring from the dealer is an "assembly" which includes the plastic that snaps onto the door. Part Number 77360-0E010
'97 SR5 V6 4x4 | 5-speed | e-locker | 33's
sportscarfan is offline   Reply With QuoteReply With Quote
Old 03-26-2020, 01:25 PM #6
3RDGENGuy's Avatar
Real Name: Matt
3RDGENGuy's Avatar
Real Name: Matt
I recently put all new rotors pads and calipers on.
Old 03-26-2020, 01:26 PM #7
3RDGENGuy's Avatar
Real Name: Matt
3RDGENGuy's Avatar
Real Name: Matt
Okay cool I will order a new clip. Thanks!
Old 03-26-2020, 01:34 PM #8
3RDGENGuy's Avatar
Real Name: Matt
3RDGENGuy's Avatar
Real Name: Matt
So is a broken clip what causes the cable to not have any tension?
Old 03-26-2020, 01:48 PM #9
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
The tension is in the gas door hinge.
Old 03-26-2020, 02:04 PM #10
3RDGENGuy's Avatar
Real Name: Matt
3RDGENGuy's Avatar
Real Name: Matt
Old 03-26-2020, 03:45 PM #11
The cable just retracts the pin holding the door closed. The spring pops it open when you pull the cable. No spring, no pop-open.
Old 03-27-2020, 03:59 PM #12
Does it lock/unlock with the key in the hatch? You may also need to lube up all the mechanisms in there. Mine got sticky and wouldn't operate most of the time with the lock solenoid. Lubing up got it going again.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 03-27-2020, 04:06 PM #13
3RDGENGuy's Avatar
Real Name: Matt
3RDGENGuy's Avatar
Real Name: Matt
Yes I have lubricated the crap out of it. Here is a pic of it.
Old 03-27-2020, 04:07 PM #14
3RDGENGuy's Avatar
Real Name: Matt
3RDGENGuy's Avatar
Real Name: Matt
Maybe replace the spring behind the mechanism?
Old 03-27-2020, 04:29 PM #15
3RDGENGuy's Avatar
Real Name: Matt
3RDGENGuy's Avatar
Real Name: Matt
I figured it out the black connection was in the wrong spot and rubbing and preventing the cable from retracting. But I unplugged the plug that goes to the key and now it won’t lock. Do I have to reset it?
cable , doesn’t , gas , open , replaced
3rd Gen Power Antennae problems-Quick Fix Teamroper 3rd gen T4Rs 1 06-28-2017 01:43 AM
2 quick Questions for 285/70/R17 for TEP PCH4R 5th gen T4Rs 10 11-18-2014 06:26 PM
2 quick questions MidwestJ 5th gen T4Rs 4 04-15-2013 09:31 AM
Two quick questions TRDteen 3rd gen T4Rs 3 03-28-2013 04:25 PM
New Here...and a Few Quick Questions TOOFAST88 Engines / Suspension / Wheels / Tires / Audio / Accessories 3 01-02-2008 10:20 PM
