Old 03-26-2020, 08:39 AM #1
dogtail's Avatar
dogtail dogtail is offline
Real Name: Keith
dogtail has a spectacular aura about dogtail has a spectacular aura about
dogtail's Avatar
Real Name: Keith
Headlight high beam position now low beam, low beam position no lights.
I have a 99 SR5 with about 390K on the chassis. Last night I noticed the headlight column switch lever position in low beam I have no headlights just side markers and tails. When I switch to high beam position I get low beam without the blue high beam dash indicator. Is this just a bad column switch? I didn't find anything in forum search. Headlight filaments should be fine, replaced both a couple months ago. If anybody has any experience with this or knows of other possibilities in this area circuit wiring, and has wiring diagram, would be appreciated.
I do have a 2000 SR5 parts rig I can pull switch out of, also a 98 SR5 as a backup.
*1999 3.4L, 4wd/5spd, swapped motor and trans, heavy use DD, seasonal rust proofing using WD-40 only
*2000 3.4L, 4wd/5spd, parts rig, picking the carcass
dogtail is offline   Reply With QuoteReply With Quote
Old 03-26-2020, 07:45 PM #2
Twan's Avatar
Twan Twan is offline
Twan will become famous soon enough Twan will become famous soon enough
Twan's Avatar
Had a similar issue with mine. Ended up replacing the cluster with a used unit and also the main DRL relay underneath the dash on the driver's side. I wasn't able to fix it/track it down myself even with a ton of help from members here, so I ended up taking it to a Toyota specialty shop in the end. You might be able to pull some helpful info from my thread: Low/High beam inop
2000 SR5 Sport - 4EAT and E-locker, King 2.5s, EimKeith PCK, SPC UCAs, 33" KO2s on Black Rhino Boxer gloss gold 17x8.5, Savage/Lotus skids, 4xInnovations front bumper/sliders, Shrockworks bumper & tire carrier, Lil Skip Gas Tank Skid, Magnaflow Overland cat back
Twan is offline   Reply With QuoteReply With Quote
Old 03-27-2020, 07:56 AM #3
dogtail's Avatar
Real Name: Keith
dogtail's Avatar
Real Name: Keith
Ok thanks. Yours is a 2000 with DRL, My 99 doesn't have DRL, but it actually has a 2000 cluster I put in it a few years back been working fine. But I'll look into the cluster also, I have a couple extra. I looked at the wiring diagram in your link, its a 2000 with a bunch of DRL stuff, wish I could get a 99 wiring diagram of the light circuit.
Thanks for the info.
Old 03-27-2020, 10:22 AM #4
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
What happens when you flash the highs? As it bypasses the cluster and uses a different part of the switch that might confirm the bulbs are good.
Below is the NON-DRL EWD for a 2000. It is identical to the '99 NON-DRL EWD. I have the '99 EWD manual in paper and I checked. '99 also had the DRL setup but it was only sold that way in Canada. The Canadian '99 is identical to the US 2000.
I have looked really hard at this and I don't see how this fail could be anything but the stalk switch. The cluster would kill both high and low. There is no relay other than the main headlight which would also kill both.That said, I would never swap a switch without first putting in new bulbs or checking for voltage at the bulb plug. Sometimes they die fast, and a lot of people don't notice a dead one until the second one goes.
All bets are off if an alarm is wired into the headlights.
Congratulations. 14 years reading every electrical post on here and I have never seen this fail. You are sui generis.
File Type: pdf 96 Headlight (without Daytime Running Light).pdf (45.7 KB, 58 views)
My Backyard Frame Swap
Old 03-27-2020, 03:14 PM #5
dogtail's Avatar
Real Name: Keith
dogtail's Avatar
Real Name: Keith
When I flash the highs, the low kicks on just like the low is on in the high position. In the low position, no lights at all. I don't get the dash blue high indicator in any position. I'll try the stalk switch 1st, after double checking the headlights, they're fairly new and I didn't notice one out. If no go, I'll hit the other things. When I bought it years ago it had a gaffed alarm system that I meticulously removed and then solder repaired harness, so if need be, I'll check the harness repairs.
Thanks for the diagram.
Old 03-28-2020, 07:35 AM #6
MaineRunna's Avatar
MaineRunna MaineRunna is offline
MaineRunna will become famous soon enough MaineRunna will become famous soon enough
MaineRunna's Avatar
Sounds like it's most likely is the combo switch, but give a good check of your wiring under the dash and out in the engine compartment. Bad grounds can do some weird stuff.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
MaineRunna is offline   Reply With QuoteReply With Quote
beam , headlight , low , position , switch
High Beam Headlight Diagram mogmanbrad 5th gen T4Rs 2 08-28-2017 02:59 PM
HID (Low-Beam Xenon/ High-Beam Halogen) -H4 5000k 55w on Projectors Cuco 3rd gen T4Rs 7 08-07-2016 11:17 PM
question regarding my high beam/low beam pokits 5th gen T4Rs 2 05-21-2015 02:14 AM
Drivers side high beam headlight not working morerockin 3rd gen T4Rs 7 10-11-2012 10:02 PM
high beam low beam macallen 4th Gen T4Rs 5 08-01-2010 11:37 AM
