Old 03-27-2020, 08:01 AM #1
VernySanders's Avatar
VernySanders VernySanders is offline
Real Name: Werner
VernySanders will become famous soon enough VernySanders will become famous soon enough
Real Name: Werner
Any solid DIY write ups for custom rear control arms?
Please reference any info you have on these. I plan on building my own soon and providing a solid, in-depth, writeup like I did on the coastal front bumper. Thanks.
The dunes got boring because I couldn't jump. I'm not the type to enjoy someone else's vehicle. So i'm in the process of making making the dunes no longer boring. I guess that involves jumping.... A lot.
VernySanders is offline   Reply With QuoteReply With Quote
Old 03-27-2020, 09:44 AM #2
theesotericone's Avatar
theesotericone theesotericone is offline
theesotericone is just really nice theesotericone is just really nice theesotericone is just really nice theesotericone is just really nice
You mean upper and lower links when you say rear control arms?
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. --Albert Einstein
theesotericone is offline   Reply With QuoteReply With Quote
Old 03-27-2020, 10:26 AM #3
rexassian rexassian is offline
rexassian is on a distinguished road
Are you building stock replacement? Adjustable? etc... I'm certainly interested but at this point it's digging up other threads on other sites....
1999 SR5 V6 manual trans 4x4 - Lifted on 35's - Build thread
rexassian is offline   Reply With QuoteReply With Quote
Old 03-27-2020, 11:48 AM #4
spartacus's Avatar
spartacus's Avatar
7
There are a few guys who've done it in their build threads.
I'll get you started.
Building rear control arms. Thoughts and opinions
Old 03-28-2020, 08:38 AM #5
Real Name: Werner
Real Name: Werner
Yes!!
Old 03-28-2020, 08:44 AM #6
Real Name: Werner
Real Name: Werner
I'd like to do some adjustable that can still sit at stock lengths. I'm guessing my main thing is critical dimensions.
Old 03-28-2020, 08:45 AM #7
Real Name: Werner
Real Name: Werner
Originally Posted by spartacus View Post
7
Coooooooooool thanks a lot Spartacus!!
Old 03-28-2020, 08:51 AM #8
Real Name: Werner
Real Name: Werner
Specifically I'd like to use duroflex joints on both sides. Not sure is anyone with a toyota is running them.
Old 03-28-2020, 01:41 PM #9
Yes!!
Off the top of my head I know @AssBurns has 4 linked. I'm pretty sure he;s using Johnny Joints. @Dirtco 3 linked if I remember correctly.
I kept the stock locations but went with Front Range OR adjustable uppers and Metal Tech adjustable lowers. I pushed the axle back about 1/2" and got a way better pinion angle.
What route do you plan on going with the links?
Old 03-28-2020, 08:33 PM #10
Real Name: Werner
Real Name: Werner
Right now I want to get rid of the twigs, improve rideability on the sand dunes for the rear end, but ultimately I want to get my feet wet fabbing something like this because I wanna go longtravel. That's my ultimate goal. But I'm a ways from it.
Old 03-28-2020, 08:52 PM #11
You mean these twigs? lol
Old 03-28-2020, 09:18 PM #12
Real Name: Werner
Real Name: Werner
LOLOL YES those things. I dont know how that was even safe. Or allowed from the factory especially in the rust belt!!
Old 03-30-2020, 03:02 PM #13
AssBurns's Avatar
AssBurns AssBurns is offline
Real Name: Steven
AssBurns will become famous soon enough
AssBurns's Avatar
Real Name: Steven
I ran DuroFlex joints on my stock replacement links. They were great joints and I definitely recommend them. I sold them to @rkntoy who has used and abused them for a while.
The only negative about the DurFlex joints is that they must be mounted with the joint in the neutral position (no misalignment at ride height), or else they will wear out prematurely. So just keep that in mind when using them. Stock suspension geometry allows them to be used with no issues, but if you plan to make custom brackets, just make sure everything lines up perfect when making brackets.
This was why I chose to use Ballistic Fab joints when I did my 4-link. They aren't necessarily any better than DuroFlex joints, but they can be at misalignment at ride height without issues. I didn't want to take the time to make sure all brackets are perfectly straight, especially if I had to cut things off and move things around for better geometry. I have my joints within a few degrees of neutral, and it doesn't cause any issues at all. If you have the patience to make sure things are neutral, i would still recommend DuroFlex joints. They are quiet, smooth, low maintenance and maintenance is super easy if you need to service them.
The BeerRunner - http://www.toyota-4runner.org/3rd-ge...ld-thread.html
AssBurns is offline   Reply With QuoteReply With Quote
Old 03-30-2020, 03:50 PM #14
rkntoy's Avatar
rkntoy rkntoy is offline
rkntoy will become famous soon enough
rkntoy's Avatar
They have been great. Like @AssBurns says they are easy to maintain and work well. Currently running them on both lowers. I also run them on my one upper (only run an upper on my passenger side.
1999 Base model 4x4 3RZ 5 speed - added e-locker, front Aussie, dual cases with 4.7 front, manual hubs, Tundra/OME 861 springs, Shaved firewall (thanks Tyler James Inc), AssBurns rear links (run as 3 link),Limited interior w/ Mazda3 Grand Touring seats, Savage front and rear bumpers w/ winch, sliders, Thorley header w/ Magnaflow exhaust, SPC UCAs, 37s with 5.29 gears, roof rack and storage box, sport hood, BL and more. Linky
rkntoy is offline   Reply With QuoteReply With Quote
Old 03-30-2020, 06:01 PM #15
Real Name: Werner
Real Name: Werner
Do you have a writeup on your 4link fab job? I appreciate the solid contribution of tested info Assburns sounds like I'll go the route you did. Stock replacements go with the Duroflex and when I go 4link I'll look into those ballistics. I saw a comment on another thread where you were still seeing if you liked them just as much as the Duroflex. It seems like dependent upon the application the ballistics or duroflex would be the way to go for functionality / reliability when talking stock replacement vs 4link applications in particular.
bumper , coastal , front , solid , ups
Custom(ish) Extended Rear Sway Bar Links Write-Up Nathana92 4th Gen T4Rs 35 11-20-2018 12:59 PM
WTB: 3rd gen upper/lower control arms/rear trailing arms BADCLOWN Want to Buy/Trade 2 05-24-2017 03:11 PM
Rear Control Arms kpnavarro Classic T4Rs 4 12-04-2012 03:53 PM
Any write ups on replacing Lower Control Arms? DeTwizzle 3rd gen T4Rs 10 09-01-2011 09:11 PM
