Old 03-27-2020, 06:51 PM #1
trap-alaska trap-alaska is offline
Real Name: Greg
trap-alaska is on a distinguished road
Real Name: Greg
Clutch Failure Symptoms?
So my 2002 T4R with automatic transmission won't move and I think it's the clutch but I wanted to confirm with you guys or see what else it might be.
It was driving fine earlier today and after it was parked it won't go in to gear. Any of the gear selections result in the RPMs running up and it doesn't move (like it's in neutral) and when we put it back in Park there is a grinding noise.
About a year ago the radiator failed and the transmission cooler line broke off. We didn't have the pink milkshake but the transmission did run very low or even dry before we could safely pull over. It was towed in and the radiator replaced and it has driven fine since then, for several thousand miles.
So what say you? Clutch or something else? Any options beside rebuilding/replacing the clutch? TIA
trap-alaska is offline   Reply With QuoteReply With Quote
Old 03-27-2020, 07:45 PM #2
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim is a splendid one to behold mtbtim is a splendid one to behold mtbtim is a splendid one to behold mtbtim is a splendid one to behold mtbtim is a splendid one to behold mtbtim is a splendid one to behold mtbtim is a splendid one to behold mtbtim is a splendid one to behold
mtbtim's Avatar
Real Name: Tim
I think you have suffered the common planetary gear failure that the 01 and 02 model transmissions are known for. Just so you know, you don't have a clutch like a manual transmission does but you do have clutch plates that can wear out.
The only other possibility is your flex plate cracked all the way around and that's why you have zero forward propulsion.
I'd start by removing the access hatch on the bottom of the bell housing and taking a look at your flex plate. If the flex plate is still intact, I'd drop your pan. I think my first guess is probably right and your planetary gear imploded and I bet you'll find a plethora of metal chunks which means it's transmission replacement time.
This video will help you drop you trans pan:
Old 03-27-2020, 10:03 PM #3
MaineRunna's Avatar
MaineRunna MaineRunna is offline
MaineRunna will become famous soon enough MaineRunna will become famous soon enough
MaineRunna's Avatar
I don't remember if the 02 has a neutral position in the transfer case, but could it possibly be in neutral? That would explain the grinding when you put it in park.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, Tundra brakes, BFG 255/85R16 Mud Terrain T/A's 227,000 miles
MaineRunna is offline   Reply With QuoteReply With Quote
Old 03-27-2020, 11:25 PM #4
Thebeastlives Thebeastlives is offline
Thebeastlives will become famous soon enough
Try putting it in 4 lo and see if it moves
Thebeastlives is offline   Reply With QuoteReply With Quote
Old 03-28-2020, 08:40 AM #5
Real Name: Greg
Real Name: Greg
Thanks for the ideas guys. It's pouring rain right now but I'll head out in a few to check it out.
clutch , fine , gear , radiator , transmission
Fan Clutch Symptoms? How loud is yours? TheFriZ 3rd gen T4Rs 69 12-08-2018 06:26 PM
Opinions on Radiator Failure Symptoms? Luciendar21 3rd gen T4Rs 9 10-04-2018 10:32 AM
Fuel pump failure - any advance warning/symptoms? mckennar 3rd gen T4Rs 24 01-25-2017 04:44 PM
Symptoms of a failing clutch? JBurt Off Topic 1 08-26-2015 12:59 AM
Transmission Failure Symptoms T4RBoarder 3rd gen T4Rs 6 11-03-2014 11:23 AM
