brillo_76, JMat, RandyBobandy, Toy2play
Old 04-01-2020, 04:05 PM #16
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
Synthetic shouldn't be causing any leaks if everything is in good shape. I've been all synthetic in every vehicle for years.
Is synthetic needed? Not going to go there. I see the wisdom in conventional and frequent changes too. I may consider this in the rear diff also.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 04-01-2020, 04:38 PM #17
Is you have a axle seal leak look at your vent.
Old 04-01-2020, 07:33 PM #18
anormalflame's Avatar
anormalflame anormalflame is offline
Real Name: Blaine
anormalflame is on a distinguished road
Real Name: Blaine
The passenger rear axle seal is definitely leaking. The driver side is clean as a whistle. Can I get away with just swapping the passenger side?
1997 Toyota 4Runner SR5 4WD
Birmingham, Alabama - Central Alabama 4Runners
Go Avs Go | Roll Tide
BlainePrickett.com
anormalflame is offline   Reply With QuoteReply With Quote
Old 04-01-2020, 08:21 PM #19
RandyBobandy's Avatar
RandyBobandy RandyBobandy is offline
RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice
You should be able to, it likely started leaking because your rear diff breather is plugged so make sure you fix that while you're at it. I just did the passenger side when I did mine as well as extend the rear breather
RandyBobandy is offline   Reply With QuoteReply With Quote
brakes , driveway , hesitation , light , red
Dash lights on after bump in driveway jamiemm18 4th Gen T4Rs 5 06-12-2018 06:16 PM
Shuttering while driving. trey99ek 4th Gen T4Rs 20 02-10-2018 10:55 AM
P0306 Code and is shuttering. scionicboom 3rd gen T4Rs 2 10-09-2014 01:37 PM
Lights Dim when Applying Brakes Paragon1 5th gen T4Rs 2 01-22-2014 04:08 PM
Shuttering transmission / engine problems Juanto 4th Gen T4Rs 0 05-10-2011 09:56 PM
