03-29-2020, 10:56 AM
Real Name: Blaine
Real Name: Blaine
hesitation / shuttering brakes (driveway or red lights)
1.) I'm experiencing a hesitation when accelerating after being parked overnight and pulling out of the driveway or occasionally when taking off from a red light. I push the gas and there's a hesitation and then it just takes off. It feels like I'm getting bumped from behind before taking off. It seems like it happens most often just after leaving the house.
2.) Also, when I brake coming in very slowly to the driveway or to a red light, it shutters and then the brakes lock up hard. My front brakes are new and rear brakes are fine. For example, if I pull my car from the driveway to my garage, it almost always does this. Again, this is something that only seems to happen early on driving.
3.) My ABS light has been on since I've owned it, which I've just now began to try to diagnose since having these braking issues. I'm getting Code 32: Left front wheel speed sensor signal malfunction. Tried cleaning the sensor, but that did nothing.
Anyone else experience anything like this? It started around 8 months ago, but I haven't driven my truck much this year due to work and have just began getting back under the hood.
TIA for any help
@ brillo_76
@ TheDurk
ever seen anything like this?
1997 Toyota 4Runner SR5 4WD
Birmingham, Alabama - Central Alabama 4Runners
Go Avs Go | Roll Tide
BlainePrickett.com
03-29-2020, 11:10 AM
Real Name: Blaine
Real Name: Blaine
Work completed within the last year:
Fuel filter changed
Spark Plugs Changed
Plug Wires Changed
New MAF sensor
Valve Cover Gaskets replaced along with all other related parts
IAC Cleaned
Throttle Body Cleaned
Front Diff Fluid replaced
New Intake hose
BlainePrickett.com
03-29-2020, 01:58 PM
I had the same issue and it was leaking rear axle seals, they swell from being soaked in gear oil. Once you drive around for a little bit does it stop acting like this? Mine was really noticeable when it was cold and/or damp out. I'd pull the rear drums(easy enough to do) if I was you and see what you find. I'd bet you'll find gear oil in there.
1998 Toyota 4Runner 3.4 4x4 with 340,000 miles.
199mm TBU-Bilstein 4600-'99 Tall Springs(Rear).Almost Totally Stock
1997 Toyota 4Runner 3.4 4x4 with 247k miles-Project car
03-30-2020, 02:39 AM
Real Name: Blaine
Real Name: Blaine
97 T4R 3.4 4WD
The more I read, I’m leaning toward axle seals.
BlainePrickett.com
03-30-2020, 05:41 PM
Originally Posted by anormalflame
97 T4R 3.4 4WD
Same symptoms I had and it was a rear axle seal. Brake shoes containmented and swell up.
97 Charged, lifted, armored, geared, locked SR5.
03-30-2020, 07:21 PM
could the shuddering possibly be the abs activating when it isn't supposed to? can you feel it in the pedal?
03-30-2020, 07:49 PM
Originally Posted by brillo_76
Well, are you rear shoes covered in gear grease or brake fluid?? As you know we are curious. ;-)
Right? Takes about 10 mins to find out and even less with an impact gun
03-31-2020, 03:02 PM
Real Name: Blaine
Real Name: Blaine
From your responses and my research, I believe it is the rear seals. I don’t feel it in the pedals when braking. It seems like it’s coming from the rear. And the hesitation seems to go away after driving for a while. When hesitating while accelerating, it feels like a bump from behind. Kind of like it’s breaking free from something. It happens almost every time when driving a short distance from my driveway to my detached garage. Going to inspect tomorrow. Building new baby nursery furniture tonight.
If it is the seals, I’m going to replace them myself. Also, I plan on draining and refilling front and rear diff, and t-case fluid. I have 235k miles and I don’t know when the previous owner changed it out. He was mechanically savvy, so I’m sure he did before. Just not sure when, and I’ve had it for 35k miles.
When I change fluids, do you recommend making the swap to synthetic? And do I have to do anything special to make the switch?
Will update with findings from removing the wheel and drum.
TIA
@jMat
@ brillo_76
@ Toy2play
@ RandyBobandy
BlainePrickett.com
03-31-2020, 04:51 PM
After doing some research on this forum and others I went with synthetic all around.
04-01-2020, 12:19 AM
TIA
@jMat
@ brillo_76
@ Toy2play
@ RandyBobandy
I stuck with conventional gear oil. I actually had a leak on one of my seals when I switched to synthetic oil so I switched it back and never leaked since. It wasn't much that leaked, but it did. I've changed mine out so often I go with the cheap stuff. I use mine for a bit of overlanding travel so I change it out often, river crossings and such. I like to do it as preventative maintenance and it's pretty easy to change.
04-01-2020, 01:27 PM
Real Name: Blaine
Real Name: Blaine
Interesting point. I've seen where some have said synthetic gear oil caused leaks for them as well. I wonder if the issues I'm experiencing could be due to synthetic already being in the diff. Maybe I should swap it out and refill to a cheap conventional to see what happens and see if my issues go away. Or do any of you think it's most likely the seals? Pulling the wheels to check for oil tonight. I can't see oil over spray or stains inside the fender well.
BlainePrickett.com
04-01-2020, 01:28 PM
Real Name: Blaine
Real Name: Blaine
Pulling the wheels tonight to check. I looked inside the fender wells to see if there's over spray or stains from oil, and I don't see anything.
BlainePrickett.com
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
