Old 04-01-2020, 08:57 AM #16
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Originally Posted by JRZEE2000TR4LTD View Post
The spec doesn't change. It's the geometry of the suspension that changes. The specs are still the specs and you have to get the alignment back into "spec" to maintain the factory ride (as much as possible with a lift)
Caster does change. But as caster changes, so does camber and even toe. So you need to get the camber/caster right then finally dial in the toe for a proper alignment.
I'm a mechanic that does alignments so I'm aware of how to do one. I'm curious why ptsailing thinks the specifications are different on a lifted vehicle.
Old 04-01-2020, 09:38 AM #17
JRZEE2000TR4LTD's Avatar
JRZEE2000TR4LTD JRZEE2000TR4LTD is offline
Real Name: John
JRZEE2000TR4LTD will become famous soon enough JRZEE2000TR4LTD will become famous soon enough
Real Name: John
Gotcha. I read you comment a few more times and understand what your saying by changing the caster spec. Why not just debunk his misinformation? Many people don't understand how alignments work and easily get misinformed.
SILVER 2000 4runner Limited TOTALED
WHITE/SILVER 1999 4runner Limited l Rear Locker l Tundra/890 coils | 5100 Bilsteins all around | Sonoran Steel Bumpstops l 199 mm Tundra brake upgrade | SCS Matte Gray Ray10 Rims | 275 70 17 BFG KO2 tires | LR UCAs | EIMKEITH panhard brackets | LED interior upgrade l Rear LED tailights l Pioneer AVH-X5700BHS Alpine Type "R" speakers NVX JAD800.4 Class D Amp Kenwood Under seat Subwoofer l Front window tint 20% l Weathertech window visors and floormats l OutGear Solutions Full Length roofrack l Morimoto 40" LED lightbar
JRZEE2000TR4LTD is offline   Reply With QuoteReply With Quote
Old 04-01-2020, 10:12 AM #18
Real Name: Patrick
Real Name: Patrick
I'm always curious how people come up with whatever misinformation they have. I prefer to have someone explain to me why I'm wrong rather than just say "you're wrong", and knowing why they think that X is true helps me explain why they're wrong. I didn't mean to come of snarky or snappy to you earlier so I apologize if it read that way.
Old 04-01-2020, 11:55 AM #19
thegipper's Avatar
thegipper thegipper is offline
thegipper is a jewel in the rough thegipper is a jewel in the rough thegipper is a jewel in the rough
thegipper's Avatar
Just got the call from my mechanic, toe was way off but everything else was still in spec. So even though my adjusters are probably seized in place, no adjustments were needed.
My shop charges $70 for an alignment (for reference).
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
alignment , outer , perfect , rods , tie
Inner/Outer Tie Rods nvestor88 4th Gen T4Rs 5 01-17-2020 04:05 PM
Outer tie rods not lining up after lift Jason7191 3rd gen T4Rs 10 05-14-2018 11:32 AM
Looking for best way to install new outer tie rods AnotherCO4Runner 3rd gen T4Rs 13 01-11-2018 01:20 PM
OEM outer tie rods? atalarico 3rd gen T4Rs 8 10-04-2016 06:26 PM
Outer Tie Rods beat up..other suspension parts too. bak3rme 3rd gen T4Rs 1 11-18-2012 07:17 PM
