Old 03-30-2020, 10:09 AM #1
la79 la79 is offline
la79 is on a distinguished road
Outer tie rods and alignment?
Hello, I did some work over the weekend on my 3rd gen replacing my lower ball joints and outer tie rods. They had never been replaced and had the originals for 25 years. Talk about Toyota quality.
Anyway when replacing the outer tie rods I tried to match them up as best possible to the originals with the nut and threads. Needless to say my alignment and steering wheel is a little off now and I couldn’t get them perfect. Before I did the job it was perfect.
Back to my question, if I have an alignment done will they need to touch the outer tie rods to fix? Or maybe can someone explain how this would be fixed? They wouldn’t have to remove the out tie rods again would they?
la79 is offline   Reply With QuoteReply With Quote
Old 03-30-2020, 10:27 AM #2
TheSaturnV TheSaturnV is offline
TheSaturnV will become famous soon enough TheSaturnV will become famous soon enough
Just did my entire front end recently, inner/outer, the works. I counted threads, measured and marked with tape and think I got it back to near perfect.
However, I do remember thinking that if I did have to get it aligned I was going to make sure the shop had the special tool required to avoid taking a bunch of stuff back apart.
TheSaturnV is offline   Reply With QuoteReply With Quote
Old 03-30-2020, 10:28 AM #3
plcfcng's Avatar
plcfcng plcfcng is offline
Location: Southern California (please don't hold it against me)
Real Name: michael
plcfcng will become famous soon enough plcfcng will become famous soon enough
plcfcng's Avatar
Real Name: michael
The answer is yes you should have your alignment checked after replacing any tie rod ends, ball joints, or bushings or steering rack. If you not done replacing these items finish them up before having the alignment done unless it will be some time before before the next part of the repairs.
If you only change the tie rod ends there are some people on You tube that check and adjust there Toe angle. It involves setting up strings and taking measurements. If it were me I would try to finish up all the steering and suspension stuff and take it in to a alignment shop and have the angles set.
plcfcng is offline   Reply With QuoteReply With Quote
Old 03-30-2020, 10:31 AM #4
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Loosen lock nut, turn inner tie rod which causes the outer tie rod to thread on further or unthread to adjust the toe, tighten lock nut. No removal of components necessary. An alignment machine looks at toe/camber/caster/etc and displays those readings for a mechanic to make accurate adjustments to all of the above.
Old 03-30-2020, 10:38 AM #5
Awesome glad to know they won’t have to remove everything to get it aligned.
BTW, what special tool are you referring to?
Old 03-30-2020, 10:59 AM #6
Real Name: Patrick
Real Name: Patrick
No special tools required except for an alignment rack.
Old 03-30-2020, 11:12 AM #7
mtbtim's Avatar
mtbtim mtbtim is online now
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Just go to an alignment shop that gets good reviews. Specifically tell the tech that you would like a straight steering wheel when it's all done. You would be surprised that they don't automatically do this for their customers but it's not uncommon for a person to jump into their vehicle after an alignment and find their steering wheel is still crooked. If the tech knows what they're doing, they can get the alignment right and your steering straight with relative ease.
mtbtim is online now   Reply With QuoteReply With Quote
Old 03-30-2020, 01:29 PM #8
ptsailing ptsailing is offline
ptsailing is on a distinguished road
I am just finishing up a full front suspension re build. Upper and lower ball joints, poly bushings on upper and lower control arms, cv axles, brake lines, steering rack bushings....the lot!
I want to get an alignment done....but by someone that knows what they are doing on a lifted truck. Not just some pimple faced mechanic who only knows to turn the bolt till it goes green on the computer. "green on the computer" is using specs for non lifted trucks.
Do any of you know of a really good alignment shop in the North Hollywood or Van Nuys area in Los Angeles?
ptsailing is offline   Reply With QuoteReply With Quote
Old 03-30-2020, 02:53 PM #9
Didn't mean to throw in a monkey wrench.
My OTR's were really stuck on and I remember having difficulty getting any kind of wrench to support the inners/steering rack to get enough leverage. Probably some misunderstanding on my part, sounds like Tim and the gang simply suggest finding a well reviewed alignment shop, which is what I'm going to do next.
Old 03-30-2020, 04:23 PM #10
Real Name: Patrick
Real Name: Patrick
Can you explain what alignment specifications would be different for a lifted 4Runner vs a stock and why? The only difference that most people have is a change in caster to move the wheel forward in the wheel well for tire clearance.
Old 03-31-2020, 12:41 AM #11
plcfcng's Avatar
Real Name: michael
plcfcng's Avatar
Real Name: michael
Not squaring off a steering wheel as part of alignment is a sign of poor service.
Old 03-31-2020, 07:39 AM #12
tvpierce's Avatar
tvpierce tvpierce is offline
tvpierce will become famous soon enough
tvpierce's Avatar
+1
It's the first step any tech should take when performing an alignment... then make adjustments from there.
tvpierce is offline   Reply With QuoteReply With Quote
Old 03-31-2020, 12:58 PM #13
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Well, you would think this would be part of their service but I've ended up with a steering wheel slightly off after an alignment and decided to just live with it because it wasn't off that much. I've heard of plenty others frequenting forums like this one that have experienced the same thing. Some techs take pride in their work and give good customer service and others not so much.
Old 04-01-2020, 08:41 AM #14
thegipper's Avatar
thegipper thegipper is offline
thegipper is a jewel in the rough thegipper is a jewel in the rough thegipper is a jewel in the rough
thegipper's Avatar
Your steering wheel should absolutely be straight after an alignment.
I finally dropped off my rig at a local shop in town to get an alignment done. I've replaced both LBJ's and both outer tie rods in the last couple years and never got an alignment (I know, dumb). What pushed me to finally do it is I noticed my front tires are starting to wear a little funny (worn on the outside). I also noticed that it likes to jump into "divots" into the road now after the passenger OTRE was replaced so something is definitely off.
I probably should have done it sooner but it's not my DD and maybe put 2-3k miles on it since the repairs. I told the owner that if caster/camber are out of spec to give me a call since I know the adjusters are going to be seized in place. If they are slightly out of spec, I'm going to leave it. Hopefully they won't need any adjustment, just the toe.
My truck is at the point where I have to prioritize how much money I want to keep sticking in to it (rocker panels are rotting out, axles seals are starting to leak slightly). The frame is relatively rusty but not bad for a salt belt truck. I've been treating it twice a year with LPS 2 which has worked well. Fortunately, the truck runs great, shifts great and all of the bells and whistles work (AC, windows, cruise etc).
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
Old 04-01-2020, 08:54 AM #15
JRZEE2000TR4LTD's Avatar
JRZEE2000TR4LTD JRZEE2000TR4LTD is offline
Real Name: John
JRZEE2000TR4LTD will become famous soon enough JRZEE2000TR4LTD will become famous soon enough
Real Name: John
The spec doesn't change. It's the geometry of the suspension that changes. The specs are still the specs and you have to get the alignment back into "spec" to maintain the factory ride (as much as possible with a lift)
Caster does change. But as caster changes, so does camber and even toe. So you need to get the camber/caster right then finally dial in the toe for a proper alignment.
SILVER 2000 4runner Limited TOTALED
WHITE/SILVER 1999 4runner Limited l Rear Locker l Tundra/890 coils | 5100 Bilsteins all around | Sonoran Steel Bumpstops l 199 mm Tundra brake upgrade | SCS Matte Gray Ray10 Rims | 275 70 17 BFG KO2 tires | LR UCAs | EIMKEITH panhard brackets | LED interior upgrade l Rear LED tailights l Pioneer AVH-X5700BHS Alpine Type "R" speakers NVX JAD800.4 Class D Amp Kenwood Under seat Subwoofer l Front window tint 20% l Weathertech window visors and floormats l OutGear Solutions Full Length roofrack l Morimoto 40" LED lightbar
JRZEE2000TR4LTD is offline   Reply With QuoteReply With Quote
alignment , outer , perfect , rods , tie
Inner/Outer Tie Rods nvestor88 4th Gen T4Rs 5 01-17-2020 04:05 PM
Outer tie rods not lining up after lift Jason7191 3rd gen T4Rs 10 05-14-2018 11:32 AM
Looking for best way to install new outer tie rods AnotherCO4Runner 3rd gen T4Rs 13 01-11-2018 01:20 PM
OEM outer tie rods? atalarico 3rd gen T4Rs 8 10-04-2016 06:26 PM
Outer Tie Rods beat up..other suspension parts too. bak3rme 3rd gen T4Rs 1 11-18-2012 07:17 PM
