Old 03-31-2020, 03:08 PM #1
BestNThDez BestNThDez is offline
BestNThDez is on a distinguished road
Driver Door Key Lock Question
Does the driver's door key insert allow for both locking and unlocking of the door/s with the key (apparently "Yes", see below)? I know, sounds like a commons sense answer, but I just picked up my first 4R (2000 Limited), and the one and only key that came with it only unlocks the door/s, but will not turn counterclockwise to lock the door/s. (I have to lock the doors by pushing the lock button on the inside before I close the door; the one and only remote keyless entry FOB that came with the vehicle doesn't work, as that is a whole other post.)
I would imagine that it should both lock and unlock the door, but interestingly enough, the thing is that after I went to Home Depot to get a second key made (for the wife), that key both locks and unlocks (turns both ways) the door/s. How is that possible, that the second key, that was matched off of the first key, does both functions, but the first key only does the lock function?
Confused
BestNThDez is offline   Reply With QuoteReply With Quote
Old 03-31-2020, 03:25 PM #2
spartacus's Avatar
spartacus's Avatar
should have gotten two keys. New keys with sharper edges may work better.
Old 03-31-2020, 07:47 PM #3
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Keys can wear. That is unusual. However the new key must be a little crisper with the cuts. If this is the case, what if you make 2nd key off the copy that works and if that works well. Just use those 2 keys. I mostly graphite my lock tumblers once or twice a year to keep them moving smoothly.
Old 03-31-2020, 09:42 PM #4
Ted02 Ted02 is offline
Ted02 is on a distinguished road
I had the exact same issue with my only key and locks when I bought my ‘02 T4R last April. I had two new keys made and all worked great until the hot summer months. After researching online, I replaced all four lock motors (cheap on eBay), and now everything works great again. With age, the motors become worn and also sensitive to heat. I also purchased 2 remotes (again cheap on eBay) and programmed them by following tutorials on YouTube.
Ted02 is offline   Reply With QuoteReply With Quote
Old 03-31-2020, 10:09 PM #5
rglsr rglsr is offline
rglsr will become famous soon enough
Try having a Toyota dealer cut a new key based on key code (if you have it) or VIN number. It's usually under $10, and in my case the at least some of the power lock problems were solved. I still need to replace the drivers side lock cylinder, just worn out...
rglsr is offline   Reply With QuoteReply With Quote
Old 03-31-2020, 11:45 PM #6
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Don't forget to lubricate the front door locks, rear gate lock and ignition, I like a good squirt of wd40 (with the little red spray attachment), displaces water and lubes...makes locks and keys works smoother and last Longer...
Old 04-01-2020, 04:00 AM #7
I bought new keys based off the key code for the ex’s 97 Puppy hauler.
I had to remove the drivers door lock and remove the tumblers and get all the road grime out of it.
I tried spraying first with zero luck.
Old 04-01-2020, 12:36 PM #8
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I never had to clean lock tumblers yet I do have one in a tailgate completely frozen. I really doubt its salvageable. The PO said it's been frozen for years. I do have the keycode so I can get a changed at anytime now.
Old 04-01-2020, 01:34 PM #9
anormalflame's Avatar
anormalflame anormalflame is offline
Real Name: Blaine
anormalflame is on a distinguished road
Real Name: Blaine
Recently I couldn't turn my driver door lock at all and didn't have an extra key. I just bought new locks on amazon and swapped them. They're only $10. I now have door keys and ignition keys, but my door locks work now.
1997 Toyota 4Runner SR5 4WD
Birmingham, Alabama - Central Alabama 4Runners
Go Avs Go | Roll Tide
BlainePrickett.com
anormalflame is offline   Reply With QuoteReply With Quote
Old 04-02-2020, 11:13 AM #10
Thanks for the explanations and ideas.
door , door/s , key , lock , unlocks
Key won't turn driver door lock Qyota 3rd gen T4Rs 29 03-08-2022 11:29 PM
Driver door lock is broken I think. What to do? mannydantyla 4th Gen T4Rs 17 08-28-2018 11:12 AM
Front driver door lock Bballreich 3rd gen T4Rs 4 05-13-2015 12:45 AM
2007 4runner driver side back seat door lock won't lock Richqwert7 4th Gen T4Rs 0 11-30-2013 06:28 PM
WTB: 06' driver door lock switch dixie_boysles Want to Buy/Trade 0 09-05-2013 10:52 PM
