Old 03-31-2020, 04:15 PM #1
la79 la79 is offline
la79 is on a distinguished road
Heater Control Valve
Searched the forums for a heater control valve DIY but can’t find anything. Anyone done it before?
Have to replace mine along with leaking hoses that attach to it. Do I have to drain the radiator first and then refill? Or bleed the system after?
la79 is offline   Reply With QuoteReply With Quote
Old 03-31-2020, 04:33 PM #2
JWaldz's Avatar
JWaldz JWaldz is offline
Moderator
Real Name: Waldo
JWaldz is a jewel in the rough JWaldz is a jewel in the rough JWaldz is a jewel in the rough
Moderator
JWaldz's Avatar
Real Name: Waldo
I've done extensive research on this and there's no custom setups out there that retain factory functions.
As for changing it out, no need to drain the rad. Just clamp off the hoses so fluid is retained within the lines. Any fluid beyond where you clamped will obviously be lost.
Probably wise to get one of those spill free funnels that you can clamp to the top of the radiator to add a bunch of fluid at once and run the vehicle. This will help get air pockets out.
'99 Toyota 4Runner LTD - Dual Locked | Geared | Mid-Travel | 35s | Armored
Sponsors: Coastal OR | Extreme LED | SherpaEC | Overland GG
3G Build: ShowGirl | Instagram: ^Click Above^ | FB Page: JWaldz4R | T4R Mod: Contact Me
JWaldz is offline   Reply With QuoteReply With Quote
Old 03-31-2020, 04:40 PM #3
Cool thanks for the tips. Been meaning to do this for awhile and now have the time.
Old 03-31-2020, 04:44 PM #4
spartacus's Avatar
spartacus's Avatar
Have to replace mine along with leaking hoses that attach to it. Do I have to drain the radiator th Luis first and then refill? Or bleed the system after?
it is fairly simple. don't have to drain the radiator but once done burp the system.
here is a video of a t100 but the process is the same
https://www.youtube.com/watch?v=_4Xyf1Wmwlk&feature=youtu.be
So Who's had To Replace Their Heater Control Valve?
Old 03-31-2020, 05:47 PM #5
turbodudey2's Avatar
turbodudey2 turbodudey2 is offline
turbodudey2 will become famous soon enough
I had to replace my last year - it was leaking out through the valve packing.
I found an OEM Toyota valve (87240-35050) online for $35. From the dealership they're usually around $100 or so.
It's easy to change, as it's pretty much the highest point in the cooling system. Very little coolant will spill out if you're careful.
'96 Toyota 4Runner Limited 4x4, Supercharged
turbodudey2 is offline   Reply With QuoteReply With Quote
Old 04-01-2020, 08:26 AM #6
thegipper's Avatar
thegipper thegipper is offline
thegipper is a jewel in the rough thegipper is a jewel in the rough thegipper is a jewel in the rough
thegipper's Avatar
I strongly suggest you buy an OEM heater valve. I wen't through 2 or 3 aftermarket parts and they all leaked within a few months until I finally bit the bullet and bought an OEM one. There is only one 10mm bolt holding it to the fire wall. Once it is removed, you can undo the cable and the hose clamps. It took me 15 minutes to replace it so it's a pretty easy/straight forward job.
Cheapest place I could find the valve was on partsouq.com
I want to say it was $60ish bucks including shipping.
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
Old 04-01-2020, 09:54 AM #7
rexassian rexassian is offline
rexassian is on a distinguished road
OEM valve is the only way to go for these. Also, if you have a body lift, see my fun experience here:
Coolant valve broke / engine overheat
cliff-notes is add a drop bracket so you don't put any strain on the plastic hose ends.
1999 SR5 V6 manual trans 4x4 - Lifted on 35's - Build thread
rexassian is offline   Reply With QuoteReply With Quote
Old 04-01-2020, 12:35 PM #8
Ok so I called a dealership to get correct parts and was given also given part numbers for two hoses that come off of the valve. However when I look at my valve in my truck it doesn’t look like the parts diagram? Mine has two hoses that come off but on the right it splits and there is a “T” connection.
My truck is a 96 and has a rear heater. So I’m wondering if they changed the hoses after that year?
Heater Control Valve-a665b6f2-f610-4b2a-bf35-7b182fe94d23-jpg  Heater Control Valve-26e34f46-15b0-40af-8ec6-faf345d7522e-jpg
Old 04-01-2020, 02:37 PM #9
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
You need part# 87240-35050 (used through 98). They probably gave you 35070, which works from 99 through 02.
There is a thread here which tells the differences but it has to be five years or older. The OP ran into the same problem.
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 04-01-2020, 09:23 PM #10
Thanks for the help everyone. I did some more searching to confirm parts and part numbers:
What other hoses should I replace?
heater hoses
Please Help With Heater Line Part Numbers
Hopes this helps others.
Old 04-01-2020, 10:45 PM #11
I put a Napa in my 97 two ish years ago. I’ll let you all know how it holds up.
attach , control , heater , radiator , valve
Cable for Heater Control Valve HammerHead 3rd gen T4Rs 15 02-12-2024 12:31 AM
So Who's had To Replace Their Heater Control Valve? blaze17 3rd gen T4Rs 48 06-25-2022 09:20 AM
Heater control valve thegipper 3rd gen T4Rs 13 12-28-2019 02:10 PM
Heater control valve unit 9494runner Classic T4Rs 2 11-05-2015 10:36 PM
2004 Heater control valve DPET 4th Gen T4Rs 6 02-24-2015 11:23 AM
