Old 04-01-2020, 03:27 PM #1
JRZEE2000TR4LTD's Avatar
JRZEE2000TR4LTD JRZEE2000TR4LTD is offline
Real Name: John
JRZEE2000TR4LTD will become famous soon enough JRZEE2000TR4LTD will become famous soon enough
Real Name: John
Need to move my 99 AT with no power HELP!
I need to move my truck about 10 feet forward to get in a better position to remove the motor. I have the wiring harness completely disconnected. I was hoping there was an easier way than disconnecting the rear driveshaft. Seems like the shifter interlock needs some sort of power. (kinda stupid if that's true). I did exactly what the owners manual said for a 4wd. Removed the cover and tried to pull back the little white piece in there but it barely moves and after fudging with it for 10 minutes, I gave up. T case in neutral sounded promising but then I read that doing that puts means you have to go into 4wd which I don't think my truck can do in it's present state. ANYWAYS....
Just didn't want to disconnect the rear DS. One more freakin' thing I have to reconnect.
SILVER 2000 4runner Limited TOTALED
WHITE/SILVER 1999 4runner Limited l Rear Locker l Tundra/890 coils | 5100 Bilsteins all around | Sonoran Steel Bumpstops l 199 mm Tundra brake upgrade | SCS Matte Gray Ray10 Rims | 275 70 17 BFG KO2 tires | LR UCAs | EIMKEITH panhard brackets | LED interior upgrade l Rear LED tailights l Pioneer AVH-X5700BHS Alpine Type "R" speakers NVX JAD800.4 Class D Amp Kenwood Under seat Subwoofer l Front window tint 20% l Weathertech window visors and floormats l OutGear Solutions Full Length roofrack l Morimoto 40" LED lightbar
JRZEE2000TR4LTD is offline   Reply With QuoteReply With Quote
Old 04-01-2020, 03:32 PM #2
RandyBobandy's Avatar
RandyBobandy RandyBobandy is offline
RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice
You should be able to unbolt the shifter linkage underneath the vehicle and put it in neutral with the lever on the transmission, be extremely careful and make sure the vehicle won’t roll while you’re under there
RandyBobandy is offline   Reply With QuoteReply With Quote
Old 04-01-2020, 03:38 PM #3
Real Name: John
Real Name: John
Ah yes, the spot right where the large electrical connection is, right? So just put an adjustable on there and move it I guess. Does is have markings on it for the positions?
Old 04-01-2020, 03:53 PM #4
MrClean MrClean is offline
Real Name: Scott
MrClean is on a distinguished road
Real Name: Scott
Floor jack under the pumpkin if it's on level ground?
96' 4Runner SR5 | 3.4L | Manual Trans
MrClean is offline   Reply With QuoteReply With Quote
Old 04-01-2020, 04:07 PM #5
dogtail's Avatar
dogtail dogtail is offline
Real Name: Keith
dogtail has a spectacular aura about dogtail has a spectacular aura about
dogtail's Avatar
Real Name: Keith
Its very easy to pull out the driveshaft, or just disconnect the rear bolts and rope it up. Spray bolts 1st with penetrating oil. Jack rear drive wheel when you need to spin shaft. If you're having trouble getting enough leverage with a box wrench, you could put a hollow pipe on the wrench handle and you'll get a lot of leverage.
*1999 3.4L, 4wd/5spd, swapped motor and trans, heavy use DD, seasonal rust proofing using WD-40 only
*2000 3.4L, 4wd/5spd, parts rig, picking the carcass
dogtail is offline   Reply With QuoteReply With Quote
Old 04-01-2020, 04:07 PM #6
On the other side, you will see a lever with linkage connected to the end that goes to the shifter in the cab, there are no markings so you will have to count the clicks as you move it to make sure it’s in the right position
Old 04-01-2020, 04:43 PM #7
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
You should have no trouble just slipping the transfer into neutral. Can't see any issue with this, yours is the j-shift mechanical transfer isn't it? You don't need the front diff doing anything and the engine does not need to be running. If it won't go you likely have the vehicle weight on it, just rock the truck gently back and forth.
Any tine I've tried that trick on an auto (corolla, matrix) it was a simple push down on the tab and move the gear shift. Never had to mess around with one for more than the 2 seconds it takes to push a key on the tab...
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 04-01-2020, 05:04 PM #8
Why are you having so much trouble with the shift interlock override? Pop the cover and move the little arm in there with your key...
It does work, really. I know you already tried - try again before removing things unnecessarily from the truck. It may move a bit differently than you expect.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 04-01-2020, 05:07 PM #9
Real Name: John
Real Name: John
I assume you are you talking about the shifter override? I pressed it down with a screwdriver pretty hard. Thought I was going to break it.
Old 04-01-2020, 05:20 PM #10
It takes almost no force. Push the tab back towards you (well under 1 lb of force), then push the shifter button and move the shifter.
Old 04-01-2020, 05:22 PM #11
Iffykid Iffykid is offline
Iffykid is on a distinguished road
Never had reason to try this before, Just out of curiosity I just went and tried popped the cover off and pushed the little white tab down and towards the shift lever with my finger nail and it released if I just tried pushing straight down it did not release.
Ohwell phattyduck beat me to it.
Iffykid is offline   Reply With QuoteReply With Quote
Old 04-02-2020, 07:34 AM #12
Real Name: John
Real Name: John
Tried it again, no go. Not sure why I'm having so many problems. Trust me , I'm not a noob when it comes to anything technical. Maybe mine is broke. Doesn't look like it's been fooled with. I have the entire wiring harness out as I said. I will try it again when I get things back together again. Luckily, I was able to put the transfer case in neutral which did the trick.
Old 04-02-2020, 10:39 AM #13
OrRunner's Avatar
OrRunner OrRunner is offline
OrRunner is on a distinguished road
OrRunner's Avatar
This is an easy way to do it, make sure you have a couple people on hand to push/spot
OrRunner is offline   Reply With QuoteReply With Quote
Old 04-02-2020, 01:37 PM #14
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Sound like someone before you had it apart and didn't put it together right. It should be super simple.
Agree on disconnecting the linkage. It's only one 12 or 10 mm bolt and it's off. Then push the rod two clicks (P to R to N) and you're good to go. No markings so if it doesn't roll try another position. You can't hurt it as long as the engine is off, JUST BE SURE TO PUT IT BACK TO P BEFORE STARTING!
326WHP 347TQ
Old 04-02-2020, 02:38 PM #15
SeaBassHWD SeaBassHWD is offline
SeaBassHWD will become famous soon enough
Get some wheel dollies.
SeaBassHWD is offline   Reply With QuoteReply With Quote
4wd , move , power , rear , truck
I Want to Move 4Running Daily 3rd gen T4Rs 23 04-10-2012 01:20 AM
Mods for Ipod, Garmin Nav, Valentine1 and move 12v power socket... jcage89 Engines / Suspension / Wheels / Tires / Audio / Accessories 14 02-13-2012 06:59 PM
'03 V8 won't move Bacon 4th Gen T4Rs 7 02-24-2009 01:16 PM
won't move in 2wd or 4wd johnw2200 Problems & Warranty Issues 1 03-19-2008 09:51 AM
Sad but need to move on T4Runner Engines / Suspension / Wheels / Tires / Audio / Accessories 0 06-13-2006 04:27 PM
