Old 04-02-2020, 12:41 PM #1
Poorboy64 Poorboy64 is offline
Poorboy64 is on a distinguished road
Front pass window woes
Hello all,
99 limited front pass. Window is acting strange, it rolls up n down with the key in the on position (not in one touch mode only rolls down 1/2 way) from both drivers and pass side switch. When the truck is running the window will not operate just a clicking from internal door.
I have performed all the reprogramming procedures I have searched.
I did have to replace the battery in the last week?
Any one encounter this problem, any ideas?
Thanks,
Poorboy64 is offline   Reply With QuoteReply With Quote
Old 04-02-2020, 01:41 PM #2
gamefreakgc's Avatar
gamefreakgc gamefreakgc is online now
Real Name: Jerod
Real Name: Jerod
I've had to clean the driver's switch before. It does get pretty dirty and the contacts stop working as they should. If that doesn't do it replace with a used unit from a junkyard or off Ebay.
326WHP 347TQ
gamefreakgc is online now   Reply With QuoteReply With Quote
Old 04-02-2020, 05:07 PM #3
Took the drivers and pass. Switches out and apart to clean them, the ones on a limited look nothing like what I found on the net, these look to be all IC not much to clean but did clean what I could, still acts the same. It seems when power is removed from the switch it works with the key in the on position ( but still not in 1 touch mode, when ya start the truck it doesn’t work? At first it just clicks and the window kinda ratchets down a couple mm at a time. Then eventually stops working.
When it does work the motor seems strong it pushes the window up n down with ease, very smooth.
Could this be a BCM issue? A switch issue?
front , internal , pass , rolls , window
Rear window woes GearJunkie88 5th gen T4Rs 12 10-04-2018 08:22 PM
92 hilux (4 runner) rear window woes SmirnofSoldier Classic T4Rs 5 09-30-2013 01:25 PM
Rear window wiring woes TrueNorthist Classic T4Rs 7 08-15-2013 10:01 PM
Rear Window Woes Swimmerboy2112 3rd gen T4Rs 7 07-22-2013 05:48 PM
Back Window woes YotaGuy General Discussions 12 01-02-2009 02:56 PM
