Old 04-04-2020, 03:08 PM #1
fourfive's Avatar
fourfive fourfive is offline
fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough
fourfive's Avatar
What's your preferred general use black spray paint
Having something professionally painted, powder coated or rattle canned all have their place.
As far as spray paints, even though I use primer the majority of the time, I like spray paints that don't require it which is why I've been using vht roll bar & chassis gloss black for anything that needs to get painted black. I don't necessarily think it's any better than the other stuff but it makes it easier having the same color of black on hand & an extra bonus that it still works well without primer. It happened to be one of the first black spray paints I used for car parts so kinda got locked into it early on. I initially started with lower gloss/flatter black paints but noticed that most rattle can paints fade relatively quickly. So starting with a full gloss spray paint, allows it to fade to a more semi gloss/flatter finish.
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
fourfive is offline   Reply With QuoteReply With Quote
Old 04-04-2020, 03:32 PM #2
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
Rustoleum is what I keep around. Krylon dries faster.
Old 04-04-2020, 03:44 PM #3
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
Mostly Rustoleum Flat Black BBQ paint. It resists heat well and holds up as well as the regular spray paint.
For Frame touch ups, I use Rustoleum Flat Black Epoxy spray paint. It dries to a nice matter finish that looks pretty much factory.
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 04-04-2020, 03:47 PM #4
T4R2014's Avatar
T4R2014's Avatar
Actually that might be the most bulletproof spray paint I've ever used. 4 years on my break calipers and the salt hasn't damaged the finish. That says a lot. It is SUPER flat though. Not for appearance.
Old 04-04-2020, 04:01 PM #5
jross20's Avatar
jross20 jross20 is offline
jross20's Avatar
I've been using summit racing semi glass chassis paint for a while now. So far it seems to be holding up, time will tell.
Old 04-05-2020, 08:14 AM #6
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
X3 on the Rustoleum BBQ paint if outward appearance is not important. Paints up well on bare surfaces (I have used it on diff cover replacements on other makes) and dries quickly in direct Southern sunlight.
Otherwise, some shade of Duplicolor black suffices if appearance is key.
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 04-05-2020, 11:04 AM #7
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
Yup, Rustoleum BBQ black is very flat. I recently painted some things with BBQ black and others with Rustoleum semi-gloss black "Painters Touch 2X" (Ace Hardware was having a twofer sale at the time) and the BBQ looks ashy LOL
When I bought the BBQ black at Home Depot they also had Rustoleum high-temp engine paint in flat black, it was like $2 more and had a lower temperature rating than the BBQ....not thanks
Old 04-05-2020, 12:28 PM #8
aontkos's Avatar
aontkos aontkos is offline
aontkos will become famous soon enough
aontkos's Avatar
POR-15 Top Coat in a spray can is the best I’ve found. It’s expensive but it actually hardens into a shell. It’s all I’ll be buying from now on.
aontkos is offline   Reply With QuoteReply With Quote
black , gloss , paints , primer , spray
Spray paint enamel that matches body paint code? luke87gt 4th Gen T4Rs 11 09-13-2016 05:06 PM
Has anyone tried 3M spray on Paint defender? Cheers! Maintenance/Detailing 6 09-03-2014 07:45 AM
Spray can paint job Steven94 General Discussions 20 07-14-2013 12:07 AM
OEM paint color spray can foxtrot 4th Gen T4Rs 6 11-02-2012 08:56 PM
Spray paint fail tineman06 3rd gen T4Rs 11 02-22-2009 02:10 PM
