Old 04-06-2020, 01:11 AM #16
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire has a spectacular aura about UnderFire has a spectacular aura about UnderFire has a spectacular aura about
UnderFire's Avatar
Originally Posted by jross20 View Post
Oh yeah I know the 0.15" isn't the articulation, it is just what I can visually see when I'm on a creeper under her. I'll have to see if I can measure it carefully somehow.
I presume the 880's would not work well with the arb deluxe bumper...so now I guess I need to decide what coil to get and hope the extra weight eases up the shocks.
So you're using FJ80 shocks? What years?
Also, can you clarify this part?
"Tundra 5100's definitely can be harsh with no extra weight up front your soft 880's should help a bit"
Did you mean they won't help?
90-97 rear shocks is what you'd be after.
Looking at my Tacoma which sits at about 2.5" above stock rode height I do have probably an inch and a half between bumpstop and frame. That is with a stock bumpstop, I don't know how much taller the aftermarket ones are, but in order to get below a quarter inch I'd be nearly at full stuff. Probably 4.5-5" of wheel travel. If your truck was sitting that low it'd be blatantly obvious, so the bumpstops very well could be part of the problem.
In theory your soft front springs should help the ride to a point, that is unless they are too soft and bottoming out under regular driving conditions. I had this happen before I switched from 600lb to 700lb springs on my coil overs, jarring to say the least and very slow to recover. If this is the problem it would only get worse with more weight, and moving the spring perch up is NOT a good solution, as that would over-preload the spring and sacrifice even more ride quality and performance
Sent from my JSN-L23 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
UnderFire is offline   Reply With QuoteReply With Quote
bumps , feels , front , note , truck
I admit... clean as hell, but overpriced amalik 4th Gen T4Rs 23 04-02-2018 09:09 AM
I must admit, jeep owners really know how to wheel... Tucson4runner 3rd gen T4Rs 17 05-13-2016 04:23 PM
05 4runner rough suspension Vols77 4th Gen T4Rs 10 10-12-2015 04:25 PM
There are two things a man will not admit he cannot do well, drive and make love. JBecker Off Topic 6 12-18-2013 03:03 PM
rough country suspension help 7point3 Classic T4Rs 6 04-18-2012 04:31 AM
