Old 04-05-2020, 06:42 PM #1
ptsailing ptsailing is offline
ptsailing is on a distinguished road
Custom High End winch ropes
Bare with me....its a bit of a long read but I would love your thoughts at the end.
I have been toying with making a Gucci custom winch rope. The first one I built on my own was out of HTS90 that has a breaking load of 25500 lb. The concern I had was not the breaking load but the chafe resistance....which is the only factor that would make you go with a steel cable vs synthetic rope. Otherwise synthetic rope is superior, its far lighter for the same load rating, less danger if it were to fail etc.
Before I propose my idea let me explain: I have been a professional racing Grand Prix sailor for 15 years....competed for both the Australian and USA Olympic teams. Now my job is to race on Grand Prix sail boats where we use nothing but synthetic rope (steel cable sheets and guys similar to our winch cables died out back in the 80s).
A new rope manufacturer that one of my co workers started is making synthetic rope that is infinitely more chafe resistant than any other rope I have ever seen. One of the boats I race has a harness line for the crew. We are incredibly hard on the ropes and by the end of 2 days of racing, the line has usually chafed through and needs to be replaced. You always need to carry 2 or 3 spares.
My coworker has come up with a line that we are now using in this high chafe application....where I used to go through one line per weekend....I now have used the same piece of his line for 2 YEARS, racing almost every weekend and it is still going strong. I am not planning to replace it anytime soon. Its made out of the same material they make mining conveyor belts out of. What better material to make a winch cable from than one that was designed to be in the sun and drag rocks and dirt across it day in day out.
I figured this line could be made into an indestructible winch cable. The only fly in the ointment is price.
I want to build a few winch cables out of this stuff and see how much better it is. The problem is it comes on a spool of 700ft. Ill make myself a winch rope of 100ft but I cant afford to sit on 600ft of the stuff.
Id sell the remaining 600ft at cost if anyone wants one. Ill splice some ends onto the rope and make it so that it will be a finished winch rope when I send it out. Just wind it onto your winch and away you go. It will be the last winch rope you ever need.
Line Dia Breaking strength Price
3/8" 12,000 $3.70 per ft
Anyone interested? Help me out...What am I missing? Is this a bad idea?
Custom High End winch ropes-20200405_153154-jpg
ptsailing is offline   Reply With QuoteReply With Quote
Old 04-05-2020, 06:45 PM #2
Photos of winch cable I made with a short chafe cover
Custom High End winch ropes-20200405_153219-jpg  Custom High End winch ropes-20200405_153224-jpg
Old 04-05-2020, 08:04 PM #3
theesotericone's Avatar
theesotericone theesotericone is offline
theesotericone is just really nice theesotericone is just really nice theesotericone is just really nice theesotericone is just really nice
I'd like to see the actual manufacturers specs on the line. It's got a very low breaking strength for it's diameter. Is it a standard 12 strand line? Material composition?
I don't think it's a bad idea to think outside the box. Sailing and climbing(my background) both have tech that's made it into the off-road industry. Synthetic winch ropes wouldn't be a thing if sailors and climbers hadn't gotten away from nylon and into Kevlar/Dyneema in the late 80's.
Masterpull is pretty much the gold standard for synthetic winch and recovery line. To give you an idea, there shittiest load rating on a 3/8 line is 17.5K. That line is $3 a foot. There best line is rated at 29K. That line is $5 a foot.
The general rule for winch lines is 1.5x -2xhe breaking strength of the rating on the winch. So with a 9K winch your still only at 1.3x with your set-up. Will it fail? Probably not. In my case my winch is a 12K. There's no way I'd use that line.
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. --Albert Einstein
theesotericone is offline   Reply With QuoteReply With Quote
Old 04-05-2020, 08:22 PM #4
TonyB66's Avatar
TonyB66 TonyB66 is offline
Real Name: Tony (no surprise)
TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light
TonyB66's Avatar
Interested, at least I think I should be. Seems like a sound idea...
Sorry, I'm ignorant on such matters. The last time I used a winch was on an FJ-40, like 30 years ago. Steel cable... Last year I purchased a Smittybilt (98510) X2O:
Amazon.com: Smittybilt (98510) X2O Waterproof Synthetic Rope Winch - 10000 lb. Load Capacity: Smittybilt Products: Automotive
I then decided to get this winch shackle to fit behind the license plate. I'll need to splice it in, which I have no idea how to do...
Should this prove to be desirable, I'd be interested.
2000 Limited, E-locker
Maintenance/Build Thread
TonyB66 is offline   Reply With QuoteReply With Quote
Old 04-05-2020, 09:42 PM #5
Thanks for your input. Some good points.
Its actually a rope with a cover and a core. The core is 12 strand specially coated dyneema and the cover is woven from Technora fiber (that super chafe resistant conveyor belt material). G&B Ropes | Mistral Tech 78
My coworkers factory (made in the USA) also makes a line that is similar to masterpull with a 29000 lb of breaking strength and its also at $5 per ft. I can make a $500 winch rope that is 100ft long and you could lift 7 of our rigs clean off the ground with it. But you dont have the chafe outer cover on that one...I would think most would gladly give up a bit of the overkill strength for more chafe protection.
If people want more breaking strength....Say go up to a 1/2" line with the chafe protection cover that would be $5 per foot and 15250lb breaking strength. not quite at the 2:1 ratio but getting better.
However I guess my question is what are people willing to pay for a bulletproof winch rope? What would make it worth it to shell out for a rope that would last the life of the vehicle and that you could beat to hell and back on the worst trails.
If money is no object Then a 1/2" line with chafe cover, a breaking load of 18000lb would be $8.15 per foot.
What is the limit for a premium Gucci winch line that will most likely out last the owner and the vehicle?
Old 04-05-2020, 09:44 PM #6
the great him's Avatar
the great him the great him is offline
Real Name: Isaac
the great him is a name known to all the great him is a name known to all the great him is a name known to all the great him is a name known to all the great him is a name known to all the great him is a name known to all
Real Name: Isaac
Depending on specs I'd be interested especially in a SAR application. It would have some benefits and the main reason I still use steel line is I can abuse the heck out of it, drop it in the mud walk over it, drag it through rocks, trees, brush, dirt ect. But it's heavy and can be difficult to work with at times.
if a*sholes could fly this place would be an airport -2004 GX470 spm -97 SR5 3.4, SCS Stealth 6's w/305 70 17s MTRs, Icon 2.5" RR w/700#coils, OME861s w/Icon tacoma 2.0 RR, ARBs w/nitro 4.88, PIAA LED lights, 170amp CS144, ARB snorkel, ARB bumper w/xd9000ce, CBI swingout loaded, BudBuilt skids, lil skip tank skid, sliders, LCE 231s(d&s), first gen roll bar mod, LED interior/dash lighting, B&M 70624+perma cool w/electric fan, dual electric fanshttp://www.toyota-4runner.org/3rd-ge...ld-thread.html
http://www.metaltech4x4.com/
the great him is offline   Reply With QuoteReply With Quote
Old 04-05-2020, 10:26 PM #7
TonyB66's Avatar
TonyB66's Avatar
Good stuff Matt. I recall that the winch and/or its line should be rated at 1.5x the weight of the vehicle? If so, with the average 4Runner on this 3rd gen forum is around 5k pounds, a winch rated at least 7,500 lbs would be desirable. With the proposed rope rated up to 12k pounds, I thought that would be adequate. I'll read-up more, but I trust what you stated above....
Old 04-05-2020, 11:30 PM #8
jbtvt's Avatar
jbtvt jbtvt is offline
jbtvt has a spectacular aura about jbtvt has a spectacular aura about
jbtvt's Avatar
Good info, good thread. How are you getting two different breaking loads from 1/2" line in the above? I thought that strength was calculated based on just the cores, at least with climbing lines, and the sheath was just for protection. So is the core thicker in the latter, and sheath is thinner? Or is the composition of the lines different?
If sheath isn't factored into strength you'd end up with some amount higher than the rating, which is good. You also need to factor in a ~10% decrease in line strength if you're splicing it, from what I read. Looks like Technora isn't great with UV, although that's true with almost any synthetic fiber, would just have to be covered when not in use.
'85 4Runner, 22re 5spd; '90 4Runner, 5spd, 3.4 swap
'98 GS400 1uz; '07 GX470 2uz
jbtvt is offline   Reply With QuoteReply With Quote
Old 04-06-2020, 02:05 AM #9
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
He’s jumping products. They offer a Tech78 (SK78 core) and a Tech99 (SK99 core). The 1/2” 78 is rated at 15250 and the 99 at 18000.
The line the OP shows is assumed to be the 3/8” Tech78 rated at 11750. But...... the OP calls it 12000 rated and in the picture is a 12000 winch. Makes for questions.
How much is the 7/16” stuff?
What the price per foot of the 3/8” Tech99?
It seems like the end price will be the same $300+ for a top shelf rope. The others last 8 years or so. How long will this one last?
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 04-06-2020, 10:34 AM #10
Tony, you base the line rating off the winch rating. I was going to write a long explanation about load forces but this guys already done that for me. Hope you enjoy the read. There's some very good info in it.
Stuck Assessment and Recovery Plan - OutdoorX4
Old 04-06-2020, 02:41 PM #11
TonyB66's Avatar
TonyB66's Avatar
Tony, you base the line rating off the winch rating. I was going to right a long explanation about load forces but this guys already done that for me. Hope you enjoy the read. There's some very good info in it.
Wow, I just bookmarked that website. Thanks much Matt. I have this discussion open from last night that contains some of the same considerations/factors:
How much winch do you need? | Expedition Portal
Old 04-06-2020, 06:35 PM #12
Real Name: Isaac
Real Name: Isaac
I wouldn't take a rope that is rated for less than 20k lbs. I have several times doubled over my winch line to get 18k lbs of force and stalled.my winch out, and picked the 4runner up off the ground. The winch ratings are limited by gearing and motor size, not component strengths. The motor and gearing should always be the weak points in a winch everything else should be at least double it's rated pulling force, I said "should be" because I know there are several Chinese winches that are complete garbage. But some people also like this Chinese bow shackles too...
Old 04-06-2020, 06:48 PM #13
Yes you are correct. There are two ways to go about this. Plenty of other people make a single braid winch line (just the 12 strand core with no cover). My idea was why not get some chafe resistance built in too. The line has to be around 1/2" dia or smaller since you cant fit enough line on the winch otherwise, so there is a trade off. If you add in a protective chafe cover like the Tech 78 has you give up some of the overall strength because you have to factor in the additional width the cover will add to the overall diameter of the line. So to keep the line diameter under 1/2" the core (where most of the strength is) is reduced.
Old 04-06-2020, 06:53 PM #14
turbodudey2's Avatar
turbodudey2 turbodudey2 is offline
turbodudey2 will become famous soon enough
Regardless of how many pullies you have in they system, the tension in any one segment of rope will only ever be the winch force.
In a 2:1 or 3:1 (or any mechanical advantage system you may have rigged) you definitely multiply the winch force at the anchor points, but each segment of rope will only carry 1X the force the winch is pulling.
This is all static forces though. The reason you need a rope with a rating higher than the winch is due to any dynamic forces that may occur.
'96 Toyota 4Runner Limited 4x4, Supercharged
turbodudey2 is offline   Reply With QuoteReply With Quote
Old 04-06-2020, 06:54 PM #15
Yes sorry my fault...I was quoting that number from memory....mental error, I must have rounded up.
I will self flagellate 100 times with a rusty dipstick to make amends for my grievous mistake.
line , make , rope , synthetic , winch
Custom 2-3 Gen Winch bumpers Nitewulf Classic T4Rs 22 02-17-2016 01:44 AM
Custom winch bumper Truck4 3rd gen T4Rs 24 11-20-2015 02:45 AM
3rd gen 4runner custom winch bumper racerunner For Sale: T4R Items 45 09-08-2012 11:20 PM
Jsmarine's custom winch bumper jsmarine 3rd gen T4Rs 52 12-17-2011 12:28 PM
Custom Portable Winch Build 4runr30 Engines / Suspension / Wheels / Tires / Audio / Accessories 11 10-11-2011 01:40 PM
