Old 04-07-2020, 03:30 PM #1
Doc2012's Avatar
Doc2012 Doc2012 is offline
Location: Stationed in Camp LeJeune, home is Conover, NC
Doc2012 has a spectacular aura about Doc2012 has a spectacular aura about
Doc2012's Avatar
Lefty is coming back!
Just got off the phone with Marlin.
THE RUMORS ARE TRUE! INCHWORM IS MAKING A COMEBACK!
Marlin hopes to be selling the Lefty in the next couple months.
Not sure if it’s going to be the ‘Inchworm Lefty’, or if it’s going to be branded with Marlins name, but it’s going to be Inchworm adapters.
"We are experts in the application of violence."
-LtCol Christian Cabannis, Camp Letherneck, Afghanistan, 2009. The "Summer of Decision."
Doc2012 is offline   Reply With QuoteReply With Quote
Old 04-07-2020, 04:33 PM #2
Team_Jake's Avatar
Team_Jake Team_Jake is offline
Team_Jake is just really nice Team_Jake is just really nice Team_Jake is just really nice Team_Jake is just really nice
Team_Jake's Avatar
YES!!!
I have been following this very closely. Marlin has been hinting at it for a while but hasn't given any promises or timelines. This is the first time I've heard of a timeline.
Trevor said the issue with the leftys was that the output shafts were breaking due to its small size or lack of oil lubrication (which became especially prevalent with heavy 4th gens with V8 motors). Marlin's new 30-spline output shafts address both of those issues so the only thing needed are the housing/adapters. If Inchworm is coming back then that's the last piece to revive the lefty!
1999 4Runner Limited - 5VZ, 4wd, Factory E-Locker, Multi-Mode, 5-speed swap, Armored, Icons, 295s (thread)
2001 Tacoma Xtracab - 3RZ, 4wd, 5-speed (Daily Driver)
Team_Jake is offline   Reply With QuoteReply With Quote
Old 04-07-2020, 06:31 PM #3
eimkeith's Avatar
eimkeith eimkeith is offline
Official Vendor
eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light
Official Vendor
eimkeith's Avatar
Fantastic news! I wasn't sure how I was going to fund something similar if they didn't reappear on the market (whew!)
It really is the best solution for most Toyota builds.
keith
eimkeith.com
all product descriptions © eimkeith LLC 2016-2023
eimkeith is offline   Reply With QuoteReply With Quote
Old 04-07-2020, 11:49 PM #4
Doc2012's Avatar
Doc2012's Avatar
Interesting. Never heard that before.
Old 04-08-2020, 08:42 AM #5
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
So what's the advantage of a lefty transfer case over a taco box doubler setup?
Old 04-08-2020, 09:14 AM #6
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
It fits in a 4Runner.
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 04-08-2020, 09:23 AM #7
Doc2012's Avatar
Doc2012's Avatar
Um, no.
The Inchworm Lefty is a gear driven, 2nd Gen passenger drop case, adapted to be a driver side drop transfer case.
Instead of the chain driven stock 3rd Gen case, the 2nd Gen case uses gears, which could be replaced with a lower ratio of 4.7:1.
A Taco Box is just a crawl box; you can add it in front of either the gear driven case, or the chain case, and change the low ratio to 4.7:1; however, you can’t change the chain case ratio of 2.28:1.
With the Lefty, or (what use to be trail-gears Verso) you can run double 4.7:1 low ratios.
The taco box is part of the chain driven case; so if you didn’t want to spend 1500, you can pick up a cheap gear case, and adapter plates from either Marlin or Trail-Gear.
Old 04-08-2020, 09:28 AM #8
Real Name: Patrick
Real Name: Patrick
Originally Posted by Doc2012 View Post
Um, no.
So if I'm understanding you correctly with a Lefty case you can have same or more transfer case reductions vs adding a taco box for cheaper? Or is the advantage the ability to change the transfer case ratio with a Lefty? Sorry for the pestering questions
Old 04-08-2020, 09:37 AM #9
Inv4drZm's Avatar
Inv4drZm's Avatar
Um, no.
Fine, it doesn't fit in 4th gen 4Runners or FJ's without modifying the fuel tank, and the limited 5th gens if not all 5th gens without modifying the fuel tank.
Old 04-08-2020, 10:19 AM #10
Doc2012's Avatar
Doc2012's Avatar
The main advantage with the lefty is strength and lower low ratio.
You’ll still have hi-low with the lefty, and you’ll have hi-low hi-low with the doubler.
Old 04-08-2020, 12:13 PM #11
eimkeith's Avatar
Official Vendor
Official Vendor
eimkeith's Avatar
it's significantly smaller and already clocked; no floorboard cutting that I can tell (at least in my 1st gen taco)
keith
eimkeith.com
Old 04-08-2020, 02:15 PM #12
hntz4x4 hntz4x4 is offline
hntz4x4 will become famous soon enough
Excited about this news. I had used Inchworm dual case in 2 different 1st gen builds in the early 2000's. Jim great guy to work with. I had messaged with him late last year, he said he was getting back into production early this year.
hntz4x4 is offline   Reply With QuoteReply With Quote
Old 04-08-2020, 03:51 PM #13
Team_Jake's Avatar
Team_Jake's Avatar
It has mostly to do with strength and the ability to run lower gears. There are advantages and disadvantages to each -- a chain driven transfer case can shift on the fly and is quieter, but the chain can stretch over time and isn't as strong as gears. You also don't have the ability to change to lower gears in a chain driven transfer case, you are stuck with the 2.57:1 low range. That means if you want to add the 4.7:1 taco box in front of the chain driven transfer case, you are multiplying the torque by 4.7 onto the weaker chain driven transfer case and parts can fail much more easily.
A gear driven transfer case allows you to run 4.7 gears in the transfer case itself (and if you want dual cases typically the case in front is a 2.28:1 case). This means the max torque on the stronger gear driven transfer case is only multiplied by 2.28. The gear driven transfer cases are found in pre-1995 4Runners and Pickups but they were all passenger side drop, so they couldn't be swapped over onto 3rd gen+ 4Runners, Tacomas, T100s, Tundras, Sequoias, FJ Cruisers, or GXs.
A Lefty is a gear driven transfer case, exactly the same as the ones found in pre-1995 4Runners and Pickups, but flipped to drop to the "left" (driver side), using a custom housing...and that's where Inchworm comes in.
Old 04-08-2020, 04:18 PM #14
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
My 1st gen has a single transfer with 4.7 gears and it's a huge upgrade.
So... the Lefty could be fitted with 4.7 gears and directly replace the transfer case in a 3rd gen? I'd be super interested in doing this with my truck, but would realistically never need to go to a dual-case setup.
JZiggy is offline   Reply With QuoteReply With Quote
Old 04-08-2020, 04:35 PM #15
eimkeith's Avatar
Official Vendor
Official Vendor
eimkeith's Avatar
yes. - plus this has the benefit of not steepening the angle of the rear driveshaft on the 4Runner...
keith
eimkeith.com
inchworm , it’s , lefty , marlin , marlins
Coming back to a 5th Gen rasber3140 5th gen T4Rs 8 01-17-2019 12:52 AM
Xterra Coming Back!?!? swampdodo Off Topic 12 12-19-2017 11:34 AM
I think I'm coming back to the 4R world StRanger7032 5th gen T4Rs 55 02-27-2017 11:01 PM
thinking of Coming back to the 1st GEN!! tortora New Members 2 04-25-2014 11:54 PM
Coming back to my old 4Runner Phil79886 Classic T4Rs 3 12-07-2007 12:39 PM
