Old 04-10-2020, 06:48 PM #16
Team_Jake's Avatar
Team_Jake Team_Jake is offline
Team_Jake is just really nice Team_Jake is just really nice Team_Jake is just really nice Team_Jake is just really nice
Team_Jake's Avatar
Originally Posted by JohnMc View Post
My wife put manual hubs on her '96 a few years ago. The ABS warning light obviously came on, but the speedometer did continue to work - running off the rear wheel sensors. Sort of, anyhow. It began dropping speedo readings at highway speeds after driving for a bit, only way to 'reset' it was to slow way down again. After messing around with that issue for a while with no resolution - she finally added a Tacoma speed sensor onto the transfer case. The ABS equipped 4Runners (all US market 3rd gens?) just have a metal plug/stopper stuck int hat position. Just a plain metal slug with an o-ring on it. Remove it, install the sensor, and do some wiring. Now here speedo/odo runs off that and has no issue at all.
Later on, she replaced the front wheel bearings and had the machine shop install ABS sensor rings as part of the job - and reenabled her ABS. But didn't bother to remove the Taco speed sensor.
This is also a good way to correct your speedo after getting bigger tires and changing gears.
1999 4Runner Limited - 5VZ, 4wd, Factory E-Locker, Multi-Mode, 5-speed swap, Armored, Icons, 295s (thread)
2001 Tacoma Xtracab - 3RZ, 4wd, 5-speed (Daily Driver)
Team_Jake is offline   Reply With QuoteReply With Quote
Old 04-10-2020, 07:15 PM #17
RandyBobandy's Avatar
RandyBobandy RandyBobandy is offline
RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice
anyone know what all is involved in wiring that speed sensor in?
RandyBobandy is offline   Reply With QuoteReply With Quote
Old 04-10-2020, 07:30 PM #18
Team_Jake's Avatar
Team_Jake's Avatar
Yeah it's called a search bar
Old 04-10-2020, 07:59 PM #19
JohnMc JohnMc is offline
JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all
She originally got the info from here, but the pics are dead: 3rd gen 4runner/ functioning speedo without wheels speed sensors - Pirate4x4.Com : 4x4 and Off-Road Forum
She has some pics and a write up in her build thread on Yotatech: habanero's 1996 4Runner Build-Up Thread - Page 97 - YotaTech Forums
JohnMc is offline   Reply With QuoteReply With Quote
Old 04-10-2020, 08:12 PM #20
thanks that's exactly what i'm looking for, I'll see if I can get the speed sensor from the tacoma I got the hubs off of.
Old 04-12-2020, 10:58 AM #21
Apparently those sensors are oddly pricey from the dealer. Plus you'd still need to get a wiring pigtail for it.
abs , axles , manual , time , worry
Manual hub question. Vegas4Runner Classic T4Rs 2 02-26-2013 10:31 PM
Quick manual hub question mikedks Classic T4Rs 13 06-20-2012 12:06 PM
Manual shifting question steve73 5th gen T4Rs 12 01-19-2012 02:44 AM
285's/manual tranny question. spongerx 3rd gen T4Rs 20 11-15-2011 03:51 PM
3rd Gen Manual Transmission Question clinte234 3rd gen T4Rs 4 07-20-2010 03:50 PM
