Originally Posted by Dom8706
Found the diagram online.
Going to make a guess here - if that grey wire from the switch measures as a switched +12V, use the following diagram. This is from a 2000, so the wire colors could change... If the grey wire from the switch measures as a switched ground, skip the relay and wire directly to the unlock warning switch.
This will make the lights appear as if the key were still in the ignition - with the ignition off and the driver door open, it will continue to chime even after the key is removed.
