Originally Posted by benjamin247
So adding a fender does NOT add clearance for larger tires. The larger you go the more you cut AWAY at the fender area. With 285 you can generally get away with just hammering flat the pinch weld. Larger tires require more chopping to get clearance. Running a 35 for example would require chopping into the firewall to properly get clearance. It’s all documented is obsessive lengths in this forum under 100s of topics including “how to’s” and pics of the work.
You have an alignment issue for sure if you’re rubbing with a 265/75r 16. If you look at all the alignment topics you should be able to assess what are “good” alignment numbers for a 3rd gen. Generally you want 3-4 degrees of castor. That moves the tire away from the pinch weld.
