Old 04-12-2020, 11:20 PM #1
benjamin247's Avatar
benjamin247 benjamin247 is offline
benjamin247 is on a distinguished road
Will these fenders add more clearance to fit 285s?
Saw these fenders and was wondering if these would give me more clearance to fit 285s with my factory suspension (99 talls):
96-01 Toyota 4 Runner 4" Flare Off Road Fiberglass Fenders
– McNeil Racing Inc
Currently I have 265/75/16s and at full turn I have slight rubbing (rubbing at inner rear wheel well) if I go up my driveway with a slight incline.
1999 Black SR5 5-speed 4WD Rear e-locker
Suspension: Toytec 3" Ultimate Lift, JBA STD High Caster Upper A-arms, Eimkieth PCK
Wheels/Tires: Method 305 NV Bronze (16x8 | 0/4.5"), Goodyear Duratracs 285/75-16, 1.25" Spidertrax Wheel Spacers
Others: SRQ Fabrications Flush Grille, TJM T17 Front Bumper, Magnuson Supercharger, URD 7th Injector, Rock Gray Avery vinyl wrap, TG Sliders
benjamin247 is offline   Reply With QuoteReply With Quote
Old 04-12-2020, 11:31 PM #2
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire has a spectacular aura about UnderFire has a spectacular aura about UnderFire has a spectacular aura about
UnderFire's Avatar
If you're rubbing with 265's you've got an alignment issue, and fiberglass fenders don't necessarily add clearance because you'll get into the firewall.
Sent from my JSN-L23 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
UnderFire is offline   Reply With QuoteReply With Quote
Old 04-13-2020, 10:15 AM #3
AZBub's Avatar
AZBub AZBub is offline
Real Name: Chris
AZBub will become famous soon enough AZBub will become famous soon enough
AZBub's Avatar
Real Name: Chris
– McNeil Racing Inc
So adding a fender does NOT add clearance for larger tires. The larger you go the more you cut AWAY at the fender area. With 285 you can generally get away with just hammering flat the pinch weld. Larger tires require more chopping to get clearance. Running a 35 for example would require chopping into the firewall to properly get clearance. It’s all documented is obsessive lengths in this forum under 100s of topics including “how to’s” and pics of the work.
You have an alignment issue for sure if you’re rubbing with a 265/75r 16. If you look at all the alignment topics you should be able to assess what are “good” alignment numbers for a 3rd gen. Generally you want 3-4 degrees of castor. That moves the tire away from the pinch weld.
AzBub Build2000 Toyota 4Runner Highlander, 4x4, E Locker. 4:30 gears. TRD Taco springs on Tundra 5100s. FJ80 8 wraps/Monroe economy rear lift.
AZBub is offline   Reply With QuoteReply With Quote
Old 04-13-2020, 12:56 PM #4
oh ya...I forgot to mention I have 1.25" wheel spacers. Before installing them, I had about 0.25-0.5" clearance.
Ok, gonna pass on these fenders and just gonna try to hammer it out. Thanks for info.
285s , clearance , fenders , fit , talls
01-02 SR5 fenders comtible w/ older limited fenders? silver4est 3rd gen T4Rs 0 01-28-2019 06:07 PM
Just got 285s, should've gone 295? fireweatherguy 3rd gen T4Rs 8 08-04-2015 11:27 AM
84-89 4Runner Toyota Fiberglass Custom Hi Clearance F/R Fenders - NorCal Christopher W. For Sale: T4R Items 8 05-19-2013 04:37 PM
285s or 265s? Do the 285s look that much better? 4RunnerTrail 5th gen T4Rs 23 11-16-2011 12:42 PM
285s vinnysrunner 4th Gen T4Rs 7 10-03-2010 08:49 PM
