Old 04-13-2020, 08:20 PM #1
G_Raw's Avatar
G_Raw G_Raw is offline
G_Raw has a spectacular aura about G_Raw has a spectacular aura about
G_Raw's Avatar
Sway bar links rattle, clunk, squeak
Anyone else battle these noises with him joint sway links? I've checked my torque on them. Greased bushings. Dry lube Heim joints even. And still rattle, clunk, squeak with slightest bit of motion. It's to the point where I can hold my rear link and wiggle by hand. Both from and rear make tons of noise just rolling down driveway. I'm used to heims making noise while flexing them on trails but this seems excessive...
99 Limited: 4wd conversion, OME 883/891, Built Right UCAs, Armored and winch up front, 285's with 4.88s and dual locked.
G_Raw is offline   Reply With QuoteReply With Quote
Old 04-13-2020, 09:03 PM #2
HiLife HiLife is offline
Can't say I have a problem with squeaks. I did have a problems with the clunks and clangs when the rubber bushings split-ted and fell off.
New rubber bushings on the old oem 2nd gen links...and it's quiet again.
Old 04-13-2020, 10:09 PM #3
fourfive's Avatar
fourfive fourfive is offline
fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough
fourfive's Avatar
Tri flow ptfe lube resolved the squeaks in my sway bar end link heim joints. I'll lube them every other oil change.
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
fourfive is offline   Reply With QuoteReply With Quote
Old 04-13-2020, 10:34 PM #4
G_Raw's Avatar
G_Raw's Avatar
Bushings are 4 months old...I used blaster dry lube with Teflon. Thought I still had tri flow but I was wrong...
Old 07-19-2020, 04:06 PM #5
mavrick1903's Avatar
mavrick1903 mavrick1903 is offline
mavrick1903 is on a distinguished road
Mine are loud as hell. I tried the ones from @Mstud and then tried a greasable version of the same. Problem exists in both cases. They're beefy but the squeaking is crazy making.
mavrick1903 is offline   Reply With QuoteReply With Quote
Old 07-19-2020, 07:33 PM #6
G_Raw's Avatar
G_Raw's Avatar
Make sure your jam nuts are tight. Tri flow lubes. This solved my issue.
Old 07-19-2020, 10:25 PM #7
WeakSauz WeakSauz is offline
WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about
My heim sway links were clunky and loud, but I found out the problem was the bottom nut (that attaches to the swaybar) was getting ever-so loose, that it would "pop" on any amount of flex.
Tightened the crap out of it-- came loose again.
Blue loctite and a lot of torque has fixed all noises for me, about 1.5monts noise-free here.
I have not had any squeaking, though. I soak the heims in PTFE dry lube
2000 SR5 4x4 | Geared, Locked and Fully restored OEM+ build.
Forged and Cammed 1UZ Single Turbo, Standalone ECU + Built R150 in process. Why, you ask? Because it makes no sense in this platform, and I love it!
WeakSauz is offline   Reply With QuoteReply With Quote
Old 07-20-2020, 12:33 AM #8
TRD 4RNR's Avatar
TRD 4RNR TRD 4RNR is offline
TRD 4RNR will become famous soon enough
TRD 4RNR's Avatar
Are you using the factory brackets to hold the Swaybar to the 4Runner? I had the Energy Suspension brackets on mine for a while and got a lot of undesirable notices.
I ended up keeping the ES Greaseable Bushings and got a pair of Dorman Brackets - that combo has cut down the noises a lot.
1999 "Highlander" V6 4WD E-Locker || TRD Supercharger, URD 7th Injector, 2.2 Pulley || Toytec Aluma Series Boss Suspension, SPC A-Arms, Durobumps, Overland Endlinks || B&M Trans Cooler || 231mm Tundra Brakes, SS Brake Lines || 17" TRD Pro Wheels || BFG KO2 265/70R17-C || TRD Exhaust || 01-02 Tail Lights || Original Owner
TRD 4RNR is offline   Reply With QuoteReply With Quote
Old 07-20-2020, 09:49 PM #9
G_Raw's Avatar
G_Raw's Avatar
I'm running @MStudt links.
Old 07-20-2020, 11:50 PM #10
TRD 4RNR's Avatar
TRD 4RNR's Avatar
Understood. (I am as well)
What brackets are in the middle of the Swaybar?
Old 07-21-2020, 06:15 AM #11
G_Raw's Avatar
G_Raw's Avatar
Oh. I misunderstood. Mine are OEM, OEM bushings. My situation has been solved however. So no issues for me at this point.
links , noise , rattle , rear , sway
Rattle/squeak when low RPM AntleredRuin 3rd gen T4Rs 1 05-21-2019 11:09 AM
Front end clunk only when sway bar links on Supermoney 3rd gen T4Rs 14 06-06-2017 10:05 AM
Suspension "Clunk" - Sway Bar End Links Bad? trevo_man 3rd gen T4Rs 20 02-23-2017 12:29 AM
Front sway bar removal and extended rear sway bar links. morphious 4th Gen T4Rs 25 11-29-2015 01:36 PM
Low speed clunk and squeak? jstim 3rd gen T4Rs 4 04-07-2015 06:18 PM
