Old 04-22-2020, 01:04 AM #31
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
It’s been mentioned above a couple of times. If you don’t want to go the Billy route, the KYBs have been recommend. They are 1/2 the price of the Billies and are reported to be closer to a stock ride. There are members here who actually are using them.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 04-22-2020, 01:37 PM #32
losso losso is offline
losso is on a distinguished road
Amazon has a good deal on kyb momos
For anyone that wants to buy new shocks
What shocks are you using?-cab00d75-3777-4f91-aae9-6538d8b204a1-jpg
losso is offline   Reply With QuoteReply With Quote
Old 04-22-2020, 05:26 PM #33
SeaBassHWD SeaBassHWD is offline
SeaBassHWD will become famous soon enough
I have KYBs in mine and I'm not impressed. It's too stiff. I bought it this way and only has 3k miles on them. I have front and rear bumpers coming so I'm going to upgrade anyway.
SeaBassHWD is offline   Reply With QuoteReply With Quote
Old 04-22-2020, 11:00 PM #34
snydmax's Avatar
snydmax snydmax is offline
Real Name: Matt
snydmax will become famous soon enough
snydmax's Avatar
Real Name: Matt
Running sensen front and rear currently with better than stock ride height... moog springs in the back and preloaded sensen’s up front.
For the money, definitely a great quick refresh option
On my ‘98 gave a definite ride height boost over worn out original equipment
'98 4WD Limited, Warm Grey, 172k, Factory E-Locker, Ride-Rites, 265/75-16 Wildpeak AT3s
snydmax is offline   Reply With QuoteReply With Quote
Old 04-23-2020, 10:23 PM #35
2ndhandyotaman's Avatar
2ndhandyotaman 2ndhandyotaman is offline
2ndhandyotaman will become famous soon enough
I have my Monomaxs on stock front springs and Moog replacement rear springs. It doesn't too rough to me, but the ride quality is very subjective to what you consider to be "smooth " or "rough".
I had tried some cheap Gabriel shocks and struts, took them off within 2 days. They handled worse than worn out OEM shocks. My intention was to use the Monomaxs for a year until I could justify a OME suspension. I really have no desire to change it out now.
'99 Limited, 225K miles, 3.4/automatic, multi-mode, e-locker, broken sunroof, no DRL's. 265-75-16 Hankook Dynapro ATM. New Moog rear springs, KYB Monomax F&R.
2ndhandyotaman is offline   Reply With QuoteReply With Quote
Old 07-15-2020, 05:53 PM #36
varol1's Avatar
varol1 varol1 is offline
varol1 is on a distinguished road
varol1's Avatar
Same here - running the Gas-a-Just with Moog 99 talls up front and OME 906 in the back. The ride is quite stiff to where you feel every imperfection on the road. Folks are saying Billies are even stiffer.. I drove a friend's 3rd gen with the same springs paired with OEM Tokicos and honestly didn't feel a difference. I'm considering swapping back to OEM springs unless I can find a lifted setup that is more tolerable.
varol1 is offline   Reply With QuoteReply With Quote
Old 07-15-2020, 06:03 PM #37
itskohler's Avatar
itskohler itskohler is offline
itskohler is on a distinguished road
itskohler's Avatar
Originally Posted by Toyojay View Post
blue and yellow Bilstein 4600's, if keeping stock height. 5100's if lifting a bit. Just about to put a set of 4600's on my 2001 with 5th gen springs all 4 corners
Man I'm getting my 5th gen springs this week and shocks have been driving me crazy. What made you go with the 4600?
98 Limited - 2010 Triumph Daytona - 2017 GTI
itskohler is offline   Reply With QuoteReply With Quote
Old 07-15-2020, 06:40 PM #38
Endlessblockades's Avatar
Endlessblockades Endlessblockades is online now
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
I have 5100s with OME 906 in the rear (I didn't plan any extra rear weight for a good while - 906's are considered mild and for stockish weight.) and they soak things up very well. On the road, I can hit a speed 'hump' a lot faster than I would in another vehicle and the combo is very well behaved - compression is smooth and no rebound kick. Silly example, I know, but your issue may be the strut pairing.
Endlessblockades is online now   Reply With QuoteReply With Quote
Old 07-15-2020, 10:46 PM #39
Its GSatt Its GSatt is offline
Its GSatt is on a distinguished road
Just put 5100s on with 99 talls in front and Dobinson’s 137 in the rear.
5100’s not really any “stiffer”. More of a low/high speed compression and rebound tune. Handles rough terrain very well but still manages street - Not airing down tires felt like my old gas-adjusts with tires air’d down. Less brake dive, but at low speeds it’s wallowy. hwy is loose when swerving (this could be more related to the 1”-2” lift sensation from stock). Really good for blasting driveways etc, really smooth. Straight-on high speed dips and speed bumps, awesome. Just, not new SUV stiff or flat handling.
Get the idea? I like them
Its GSatt is offline   Reply With QuoteReply With Quote
Old 07-15-2020, 10:53 PM #40
Built4Run Built4Run is offline
Real Name: Jacob Jensen
Built4Run is on a distinguished road
I run some cheap ass Monroe’s from oreilly’s in my taco... lifetime warranty From oreillys
If they go bad I just go pick up another set my man!!!
Built4Run is offline   Reply With QuoteReply With Quote
daily , driving , find , rims , shocks
New lift combo TRD shocks, bilestine 5100s shocks, rear superflex & LC80 shock feelingstoned 3rd gen T4Rs 39 10-29-2019 12:05 AM
2015 TRDP Shocks, OME Old Man Emu Shocks, Sway-a-way Rear Springs - Central MO - $350 Ammomac For Sale: Suspension/Wheels/Tires 0 09-07-2018 04:43 PM
FS: 5th Gen (2016 Trail) Front Coilover Shocks & Rear Shocks/Springs $175, West LA rgoodman00 For Sale: Suspension/Wheels/Tires 3 01-28-2016 03:22 PM
FS: FJ Swap Stuff Shocks Springs and More Shocks! Boulder, CO DonP4Runner For Sale: Suspension/Wheels/Tires 13 02-18-2015 09:42 AM
FS: 4th GEN NEW Radflo 2.0 rear Regular Travel Shocks $350+ship Boulder, CO shocks - HOJeepster For Sale: Suspension/Wheels/Tires 11 01-09-2014 05:26 PM
