Old 04-08-2020, 04:41 PM #1
blairracd's Avatar
blairracd blairracd is offline
blairracd is on a distinguished road
blairracd's Avatar
Multiple shops telling me they cannot install OME 881s with Bilstein 5100s
Why is this? I didn’t think this was something that couldn’t be done.
Living and breathing and bleeding Toyota
https://imgur.com/a/KvwQdyO
RIP my ‘96.
blairracd is offline   Reply With QuoteReply With Quote
Old 04-08-2020, 04:53 PM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Did they say why they couldn't?
Old 04-08-2020, 04:55 PM #3
blairracd's Avatar
blairracd's Avatar
One shop said “ OME front coils can only be installed with OME Nitrocharger struts and coil seats ”
The other “ the OME springs require the OME spring seats that are different than what Bilstein provides we would not do this install.”
RIP my ‘96.
Old 04-08-2020, 04:56 PM #4
Real Name: Patrick
Real Name: Patrick
Sounds like they don't want to do it and are covering their a**es. They'll work. Why don't you rent spring compressors and do it your self?
Old 04-08-2020, 05:07 PM #5
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
You don't need a spring compressor, using a floor jack under your LCA's is very easy and a lot less hassle and danger.
Old 04-08-2020, 05:32 PM #6
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
Or just order a fully assembled shock/spring combo from Wheelers and drop it in yourself... at least that's the the route I took.
Old 04-08-2020, 05:47 PM #7
blairracd's Avatar
blairracd's Avatar
I don’t have enough tools and lost access to my shop due to covid, so I’m okay with paying.
RIP my ‘96.
Old 04-08-2020, 06:51 PM #8
spartacus's Avatar
spartacus's Avatar
Surprising for sure. I've done mine and others with a spring compressor and if you were close I would help. Maybe there is a forum member near you that can help. Don't know if you have a local lockdown order where you are at due to covid 19.
Old 04-08-2020, 07:22 PM #9
sugjavier sugjavier is offline
sugjavier will become famous soon enough
I'm actually running 881s up front due to my front bumper and also have the bilstein 5100s so i know this can be done. My mechanic is just a 1 car garage type of shop, so if he can do it, the other shops should be able to no problem. Normally i hear something from him if it's something weird but I heard nothing so I assumed this was a straight up remove and replace like you would any shock/struts.
2001 Toyota 4Runner Limited. 231k miles.
sugjavier is offline   Reply With QuoteReply With Quote
Old 04-09-2020, 09:29 AM #10
hattrickey hattrickey is offline
hattrickey is on a distinguished road
That is the first I have ever heard of that. In fact, the Bilstein/OME combo is quite popular.
Like another poster said, you don't need a spring compressor. You can use this guide to help: OME Install - no spring compressor - Toyota 120 Platforms Forum
hattrickey is offline   Reply With QuoteReply With Quote
Old 04-09-2020, 10:39 PM #11
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
thats nice, but its a 4th gen in the write up and we are in 3rd gens, minor differences but idea is similar. I know I have seen a similar write up using a 3rd gen.
not being rude...just saying
Old 04-15-2020, 10:55 PM #12
I get that, I have a 3rd gen as well and it's the same process. Also, I just installed OME 880s and Bilstein 5100s last weekend so go ahead and get to it!
5100s , couldn’t , didn’t , multiple , shops
WTB: 4th gen Bilstein 5100s Diocletian Want to Buy/Trade 0 09-26-2019 06:57 AM
0 to .85 on Bilstein 5100s w/ OME 885? Matrixman955 4th Gen T4Rs 25 02-19-2019 11:11 PM
Bilstein 5100s on an IFS first gen? zak897 Classic T4Rs 2 07-21-2017 09:24 PM
Bilstein 5100s - Post Install Review nicheel8 4th Gen T4Rs 7 05-02-2016 04:59 PM
Which perch on 5100s for 881s (I searched!) KurtL 3rd gen T4Rs 0 09-11-2014 07:45 PM
