Old 04-14-2020, 10:12 PM #1
triangles triangles is offline
triangles is on a distinguished road
Part# 17630-15090 control valve on power steering?
Does anyone know what the control valve does that is attached to two vacuum lines? It's on a 2.7L 4cyl if that matters. I broke off the nipples while replacing my belts and see it is an expensive part but for the life of me I can't figure out what it does. it's part# 14 on this diagram Control Valve - Toyota (17630-15090) | Toyota Parts
triangles is offline   Reply With QuoteReply With Quote
Old 04-14-2020, 11:12 PM #2
spartacus's Avatar
spartacus's Avatar
Air control valves raises the rpm which intern increase the pump pressure helps in steering.
It creates a vacuum when steering wheel is turned raising the rpms. salvage yards will be cheaper.
Old 04-15-2020, 01:15 AM #3
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
I've wondered if this could be eliminated altogether. I only see it having any affect at idle and I don't spend a lot of time at idle wiggling my wheels around. Surely when the rpms are up it would be insignificant.
Try just blocking off the 2 air ports and see how she runs!
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 04-15-2020, 08:33 AM #4
Thanks I saw that one vacuum line goes before and one after the throttle body. So I assume this somehow reacts to a drop in hydraulic pressure and opens to allow a small amount of air to bypass the throttle body and bring rpm up for more pump power.
I will block off the intake ports for now and if it bogs out at idle I'll eventually get around to snagging one from a junk yard.
Old 04-15-2020, 08:13 PM #5
Well I drove to the store to get some vinyl #10 screw thread protectors to use as caps. They were very tight, Probably could have used 1/4".
The vacuum leak on the way to the store raised warm idle by 200 RPM to 900. After putting the caps on idle went back down to about 700 RPM. I literally noticed no difference so I have no idea what this thing supposedly did but as far as I am concerned it was an unnecessary part.
Old 04-15-2020, 10:27 PM #6
shazbot shazbot is offline
shazbot will become famous soon enough
I cracked those nipple off when I did my celica PS pump years ago, $250 mistake
shazbot is offline   Reply With QuoteReply With Quote
Old 04-15-2020, 10:29 PM #7
I think its suppose to help with far turns to the end of the rack, give a idle up at the extremes. Might stall on a 3 point turn, sub 2-300 rpm I think thats why its there
control , expensive , life , part# , valve
Denso heater control valve part number? MONTYMTB 3rd gen T4Rs 5 11-29-2023 04:00 PM
What is this part? Power Steering Pump - High Pressure Hose Seat? pinemind Classic T4Rs 3 06-14-2019 04:53 PM
Power Steering Problem Part II sport2004 4th Gen T4Rs 17 10-22-2018 05:53 PM
Power Steering - cap says Dexron ATF, dealer tech says power steering fluid acolsen Maintenance/Detailing 7 02-24-2017 03:00 PM
Cleaning Power Steering Screen + Cardone Magna-Pure Inline Power Steering Filters BamaDrewski 3rd gen T4Rs 1 03-23-2016 05:48 PM
