Old 04-15-2020, 01:14 PM #1
nalbertasr5's Avatar
nalbertasr5 nalbertasr5 is offline
nalbertasr5 is on a distinguished road
Manual Door Lock completely seized, tried the usual stuff
Hi guys
It was a bad winter. Even had a few days where it was -50c (-56F!!) Locks were frozen, battery almost completely died. Sometimes I wonder why I live where the air hurts my face
Anyway, I've discovered that I can't get into my 4runner using the actual key. The fob works, but I don't want to rely solely on that for emergency purposes. I've tried penetrating oils, WD-40, you name it. No luck. Driver's side lock the key goes in but won't turn. On the passenger side door lock the key will only go halfway in. I tried the stuff mentioned in another thread I found.
I'm in the process of removing the lock cylinder from one of the doors and cleaning it up. Maybe I should give it a nice bath in some penetrating oil? Anyone have a favorite lube they like to use? (no pun intended)
nalbertasr5 is offline   Reply With QuoteReply With Quote
Old 04-15-2020, 01:59 PM #2
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
Maybe preheat it somewhat with a hot air gun or air dryer to help encourage the lube to flow in?
My personal favorite is Kroil but you may not be able to get it there.
JZiggy is offline   Reply With QuoteReply With Quote
Old 04-17-2020, 12:21 AM #3
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
I squirt Tri Flow into my locks several times a year. No info on how it works at sub-zero temps, tho...sorry.
Once you get the locks out, I'd recommend flushing them with solvent (spray like Brake Kleen, Lectra Motive, etc or immerse it in a jar of solvent like paint thinner, naptha, etc. THEN lube it with a light oil suitable for winter.
pluton is offline   Reply With QuoteReply With Quote
Old 04-17-2020, 02:19 AM #4
heat's Avatar
heat heat is offline
heat will become famous soon enough heat will become famous soon enough
heat's Avatar
I use spray (dry) graphite. Coat a key first then work it. Maybe
a cleaning first, depends on the lock. All bets off if it's still
stuck, though.
'02 Limited 4x4 AT - Stock ~181k miles
Thundercloud aka metallic dirt
heat is offline   Reply With QuoteReply With Quote
completely , door , key , lock , stuff
Key won’t completely turn to “Lock” estoe 3rd gen T4Rs 7 02-17-2020 10:25 PM
Manual door lock failure? Sparda 3rd gen T4Rs 4 08-21-2019 06:25 PM
Stuck / Seized Lug Nut Lock honda99ex 5th gen T4Rs 28 05-14-2018 01:02 PM
2007 4runner driver side back seat door lock won't lock Richqwert7 4th Gen T4Rs 0 11-30-2013 06:28 PM
Power Lock Works... But Not Completely TiN 4th Gen T4Rs 4 11-07-2013 11:35 AM
