04-14-2020, 04:04 PM
Scangauge W/ Bluetooth OBD2 on a 98?
I got a scangauge and Android headunit that has torque pro I stalled. Can I use 2 obd devices with a splitter? I'm not sure what the communications protocol is for our trucks. Is this CAN-BUS¿
98 SR5 4wd, CS144, compass/temp mirror, 2nd gen Hilux Altimeter/Inclinometer ,Chinese knock off diesel heater, Chinese copy of Alpicool CX50, OME 3" lift, 1" Toytec body lift, Snorkel, 13WE, Borla catback, Android hu, LED H4
04-14-2020, 04:09 PM
All 3rd gens are ISO 9141 protocol.
1999 4Runner Limited - 5VZ, 4wd, Factory E-Locker, Multi-Mode, 5-speed swap, Armored, Icons, 295s ( thread)
2001 Tacoma Xtracab - 3RZ, 4wd, 5-speed (Daily Driver)
04-14-2020, 04:46 PM
The OBD2 splitters are readily available. Give it a google.
_________
2000 SR5 five speed. Everything works, even the antenna. No special mods; It's my canoe, kayak and dog hauler/winter beater.
I find that things usually go well right up until the moment they don't.
04-14-2020, 06:47 PM
So thats a yes, 2 devices on one obd stream will work?
04-14-2020, 06:55 PM
I don't personally have experience, but the majority of customers seem to indicate no problems. It sounds like the connection is "bounced" back and forth, but perhaps it is fast enough to provide seamless data.
Maybe someone who actually has a similar setup will chime in.
_________
04-17-2020, 01:52 AM
The BT adapter and a splitter are cheap enough to try
