Old 04-19-2020, 12:35 AM #1
gmaneod gmaneod is offline
gmaneod is on a distinguished road
No speedo
Gents,
My 2000 Limited had the ABS light on so I bought and had installed the ABS wheel sensors cables installed after I got the truck back no speedo any idea what could be wrong thanks?
Gary
gmaneod is offline   Reply With QuoteReply With Quote
Old 04-19-2020, 11:39 AM #2
jross20's Avatar
jross20 jross20 is offline
jross20's Avatar
Hey man.
Does your cluster work at all? Tachometer? Odometer?
Old 04-19-2020, 10:47 PM #3
kolelt kolelt is offline
kolelt will become famous soon enough kolelt will become famous soon enough
Was the Speedo working prior to installing the sensors ? For a while I ran only 2 front sensors and the rears I cut out. My Speedo still worked. Till magically it stopped after messing with the wheel bearings. The Speedo runs of ABS as we now. There is a crown type metal ring that the sensors read. Maybe that is messed up or rusty or something ? Anyways, I gave up and installed a Tacoma speed sensor. Which is a sensor in the back of the tcase. But you need to run 3 wires , one goes to the cluster.
97 3.4 JDM/5 Speed swap/eLocker Swap/ICON CDC all around/+more.....
kolelt is offline   Reply With QuoteReply With Quote
Old 04-20-2020, 12:27 PM #4
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Originally Posted by gmaneod View Post
Gents,
Gary
You need to flash the abs codes to see what is wrong with the abs system
Old 04-20-2020, 12:59 PM #5
The speedo runs off the ABS system, as others have said. Fix the ABS system and your speedo should heal itself.
If you aren't planning on fixing the ABS system, you can put in the Tacoma speedo sensor on the back of the trans/transfer case and wire that in instead.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 04-25-2020, 12:25 AM #6
Originally Posted by jross20 View Post
Hey man.
Tac works but no speedo and no odometer
gary
abs , idea , installed , speedo , wrong
No Speedo e10pvmt 4th Gen T4Rs 13 04-02-2015 04:32 PM
Speedo Off Aelfwine 3rd gen T4Rs 10 02-09-2014 10:17 AM
Is my speedo going out? Jon 3rd gen T4Rs 5 04-04-2012 06:06 PM
Are the speedo's different?? eplanajr 3rd gen T4Rs 15 04-18-2011 01:48 PM
speedo Q's thegreasemonkey Classic T4Rs 2 09-22-2010 10:38 PM
