07-10-2018, 10:55 PM
Radiator for manual transmission 4runner
I’ve got a crack in my radiator so it’s time to replace. I see that Toyota only sells the larger radiator for auto transmissions. Should I just pick up one of these or should I look to something aftermarket?
07-10-2018, 11:04 PM
Real Name: Jarrod
Real Name: Jarrod
I think they only ever had the radiators with the built in transmission cooler lines. The stock one on my 96 5-speed had them, and the OEM one I replaced it with did as well. The trans cooler lines come capped already. I just left them capped since I usually like sticking with Toyota parts.
07-11-2018, 01:07 AM
No, my '99 5-speed factory rad has no cooler and there is a p/n for it (16400-75160). But if you try to buy it it tells you it is replaced by the auto rad p/n.
Toyota Part No.: 16400-75160
RADIATOR ASSEMBLY
Toyota 16400-75160 RADIATOR ASSEMBLY
Part Description Radiator Assy
Replaced By 16410-YZZAJ
Manufacturer Toyota. This genuine Toyota part is guaranteed by Toyota's factory warranty.
Toyota stopped making the 5-speed rad years ago and I have never seen any after-market ones either. You just have to use the auto rads and cap the cooler lines if they don't come that way.
My Backyard Frame Swap
07-11-2018, 11:55 AM
Real Name: Scramble
Real Name: Scramble
Look at Taco rads. I noticed on Amazon that they had different sizes. I dont know if any are made for a manual though. I haven't researched it yet but I hate my replacement rad for the auto. It hangs down 2" lower than the manual & butts up against my skid. I actually had to lower my skid to accommodate it.
Please report back if you find anything.
____________
'99 4Runner - 2.7L 3RZ, 5 Speed, 4.56 Gears - Lifted, Locked & Loaded - 166k Original owner - http://www.toyota-4runner.org/3rd-ge...ld-thread.html
'99 Limited - E-Locker- Stock (for now) - 233k 2nd Owner http://www.toyota-4runner.org/3rd-ge...ted-build.html
07-11-2018, 12:23 PM
Real Name: C8H18 Mike
if you hate the extra cooling capacity of the larger radiator just cut the bottom tank off
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto -> 2WD 4runner Journal Thread
07-11-2018, 02:15 PM
Real Name: Scramble
Real Name: Scramble
There is no extra cooling capacity, the bottom is for the trans fluid.
____________
07-11-2018, 02:36 PM
The radiator has a larger core, hence it is taller. The bottom tank is not for trans fluid, but the trans cooler is in there; yes.
Maybe spend less time looking for "topical" memes
07-11-2018, 03:21 PM
Real Name: Keith
Real Name: Keith
I have a 5 speed with auto radiator, hangs low. Got the 4x4 innovations bumper, getting ready to buy the skid. From their site pic, it looks like it will clear, may be close, not sure if rub or hits.
Sent from my SM-N920V using Tapatalk
*1999 3.4L, 4wd/5spd, swapped motor and trans, heavy use DD, seasonal rust proofing using WD-40 only
*2000 3.4L, 4wd/5spd, parts rig, picking the carcass
Reason: miss spelling
07-11-2018, 03:30 PM
Real Name: Scramble
Real Name: Scramble
It will fit, all fabricators build for the auto. My engine skid was custom made for manual taco's so now I have to lower it with spacers so I dont crush the auto rad.
____________
07-11-2018, 03:33 PM
Will I need spacers to make an auto radiator fit my truck? I have a stock skid plate.
07-11-2018, 03:55 PM
Real Name: Scramble
Real Name: Scramble
I dont know what truck you have, you should put the specs in your signature.
Stock skids should work with any rad.
____________
07-11-2018, 03:59 PM
Real Name: Keith
Real Name: Keith
Oooh a taco skid. I was wondering why there would be a clearance issue.
07-11-2018, 04:05 PM
Not sure how to do that.
2000 sr5 3.4 manual 4x4
07-11-2018, 04:16 PM
The auto radiator will be fine man. I just replaced mine and had to do the same thing. Some guys get the Tacoma radiator because it is shorter (or so I hear) but that really doesn't matter unless you are all hardcore off road and modified. I believe all the aftermarket skids/bumpers etc are built for the auto radiator anyway.
96' 4x4 5spd-SS1.2
07-11-2018, 05:03 PM
Real Name: Jerod
Real Name: Jerod
Yup, roughly 90% of the 3rd gen 4Runners are auto. If they made them to fit manuals only they'd be missing out on a huge market.
