Old 04-21-2020, 12:11 AM #1
benjamin247's Avatar
benjamin247 benjamin247 is offline
benjamin247 is on a distinguished road
0-2.5" rear shocks with 3" lifting coils ok?
I'm thinking of getting the Bilstein 5160 rear shocks and specs say it can be used for 0-2.5" applications. Can I pair these with the Toytec 3" rear lift coils?
1999 Black SR5 5-speed 4WD Rear e-locker
Suspension: Toytec 3" Ultimate Lift, JBA STD High Caster Upper A-arms, Eimkieth PCK
Wheels/Tires: Method 305 NV Bronze (16x8 | 0/4.5"), Goodyear Duratracs 285/75-16, 1.25" Spidertrax Wheel Spacers
Others: SRQ Fabrications Flush Grille, TJM T17 Front Bumper, Magnuson Supercharger, URD 7th Injector, Rock Gray Avery vinyl wrap, TG Sliders
benjamin247 is offline   Reply With QuoteReply With Quote
Old 04-21-2020, 10:58 AM #2
blairracd's Avatar
blairracd blairracd is offline
blairracd is on a distinguished road
blairracd's Avatar
Why not just get the 5100?
Living and breathing and bleeding Toyota
https://imgur.com/a/KvwQdyO
RIP my ‘96.
blairracd is offline   Reply With QuoteReply With Quote
Old 04-21-2020, 12:55 PM #3
Those are for 2" max lift. They have the same (errr, close enough) compressed and extended lengths as the 5160's.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 04-21-2020, 01:46 PM #4
fourfive's Avatar
fourfive fourfive is offline
fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough
fourfive's Avatar
Some companies like Wheeler's offer 5100s for 1.5-3" rear lift, 13.84" x 22.44".
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
fourfive is offline   Reply With QuoteReply With Quote
Old 04-21-2020, 01:53 PM #5
fourfive's Avatar
fourfive's Avatar
You could probably get away with it but may increase wear/tear and not get the full benefit of those shocks. You'll likely run into less issues and get a better functioning suspension if you get an appropriate length shock.
Old 04-21-2020, 02:10 PM #6
Those are not 4Runner shocks, I believe they are the Tundra application with different lower bushings to fit the 4Runner - and the likely need bump stop extensions to keep from damaging the shocks. Still an option, you just want to know what you are getting.
Old 04-21-2020, 02:26 PM #7
blairracd's Avatar
blairracd's Avatar
Nope, this 5100 Rear Shock Set for 1996-2002 4Runner (1.5"-3" Lift) 5100 is good for 3”.
RIP my ‘96.
Old 04-21-2020, 02:45 PM #8
fourfive's Avatar
fourfive's Avatar
The 1.5-3" rear shocks Wheeler's offers for 3rd gens is most likely a tundra shock, bil 24-100144 (13.84" x 22.44), with new bushings. My point was there are companies that sell 5100s for a 3" rear lift & already have the bushings set up to directly bolt on to 3rd gens. Similar to Sonoran Steel offering 4th/5th gen 4runner shocks, bil 33-187174 (14.91-23.5), with 3rd gen bushings & ready to bolt on.
Old 04-21-2020, 04:21 PM #9
Well, don't try to warranty them through Bilstein and tell them it was on a 4Runner. It will bolt on and work, but it is *NOT* a 4Runner shock.
Old 11-23-2020, 04:30 PM #10
Fiffa's Avatar
Fiffa Fiffa is offline
Fiffa will become famous soon enough Fiffa will become famous soon enough
Fiffa's Avatar
In case you were still looking, I just put 4th gen 4Runner 5160's on because the long travel 3rd gen 5100's are actually 4th gen standard travel shocks!
33-187174 (5100 3rd gen "long travel"/4th gen standard travel):
Collapsed Length (IN): 14.91
Extended Length (IN): 23.5
25-227611 (5160 4th gen 4Runner)
Collapsed Length (IN) 14.83
Extended Length (IN) 23.5
I had standard length 3rd gen 5100's in before and after putting in 210v springs (~4" lift with approx. 350 extra lbs. full-time up top and in back) the valving felt kind of soft. The 5160's (for the few miles on them now) are much better suited for the higher stance, as they make the truck feel more planted while eating up the bumps better than before.
'00 'Get Lost' Build
IG: get_lost_fiffa
Fiffa is offline   Reply With QuoteReply With Quote
0-2.5 , coils , rear , shocks , toytec
FS: 2016 "take offs" Coilovers and rear shocks, $40, St Louis MO brenfoley For Sale: T4R Items 0 02-10-2020 01:00 PM
WTB Toytec superflex 2" or sway away 1.5" rear coils for 5th gen chrissurfr For Sale: Suspension/Wheels/Tires 0 07-05-2018 11:39 PM
Icon 2" rear coils or Wheelers 1.5" rear coils? Bennmann 4th Gen T4Rs 7 11-01-2016 01:31 PM
3" Lift w/spacers & rear OME coils & Stock Shocks??? TegoXR 3rd gen T4Rs 8 07-03-2013 09:32 AM
WTB: OME 906 Coils & "SR5" + "4wd" Rear Hatch Badges slampe Want to Buy/Trade 0 08-14-2011 09:00 PM
