04-21-2020, 12:11 AM
0-2.5" rear shocks with 3" lifting coils ok?
I'm thinking of getting the Bilstein 5160 rear shocks and specs say it can be used for 0-2.5" applications. Can I pair these with the Toytec 3" rear lift coils?
1999 Black SR5 5-speed 4WD Rear e-locker
Suspension: Toytec 3" Ultimate Lift, JBA STD High Caster Upper A-arms, Eimkieth PCK
Wheels/Tires: Method 305 NV Bronze (16x8 | 0/4.5"), Goodyear Duratracs 285/75-16, 1.25" Spidertrax Wheel Spacers
Others: SRQ Fabrications Flush Grille, TJM T17 Front Bumper, Magnuson Supercharger, URD 7th Injector, Rock Gray Avery vinyl wrap, TG Sliders
04-21-2020, 10:58 AM
Why not just get the 5100?
Missing my 4runner...
04-21-2020, 12:55 PM
Those are for 2" max lift. They have the same (errr, close enough) compressed and extended lengths as the 5160's.
'16 Honda Odyssey
04-21-2020, 01:46 PM
Some companies like Wheeler's offer 5100s for 1.5-3" rear lift, 13.84" x 22.44".
•Black 2002 SR5 4x4 3.4L V6
Suspension: Front: Toytec Boss coilovers/eibach 600#, SPC UCA, durobumps Rear: Bilstein/Superflex, SS adjustable panhard, durobumps Body Lift: 2" 4crawler Tires: 315/75/16 General Grabber AT2 Wheels: SCS F5 Matte black 16x8 3.5bs Armor: Custom bolt on rock sliders (no frame drilling)
•Black 2018 TRD Pro (wife’s)
Armor: Custom bolt on rock sliders (U-bolts)
04-21-2020, 01:53 PM
You could probably get away with it but may increase wear/tear and not get the full benefit of those shocks. You'll likely run into less issues and get a better functioning suspension if you get an appropriate length shock.
04-21-2020, 02:10 PM
Those are not 4Runner shocks, I believe they are the Tundra application with different lower bushings to fit the 4Runner - and the likely need bump stop extensions to keep from damaging the shocks. Still an option, you just want to know what you are getting.
'16 Honda Odyssey
04-21-2020, 02:26 PM
Nope, this 5100 Rear Shock Set for 1996-2002 4Runner (1.5"-3" Lift) 5100 is good for 3”.
04-21-2020, 02:45 PM
The 1.5-3" rear shocks Wheeler's offers for 3rd gens is most likely a tundra shock, bil 24-100144 (13.84" x 22.44), with new bushings. My point was there are companies that sell 5100s for a 3" rear lift & already have the bushings set up to directly bolt on to 3rd gens. Similar to Sonoran Steel offering 4th/5th gen 4runner shocks, bil 33-187174 (14.91-23.5), with 3rd gen bushings & ready to bolt on.
04-21-2020, 04:21 PM
Well, don't try to warranty them through Bilstein and tell them it was on a 4Runner. It will bolt on and work, but it is *NOT* a 4Runner shock.
'16 Honda Odyssey
11-23-2020, 04:30 PM
In case you were still looking, I just put 4th gen 4Runner 5160's on because the long travel 3rd gen 5100's are actually 4th gen standard travel shocks!
33-187174 (5100 3rd gen "long travel"/4th gen standard travel):
Collapsed Length (IN): 14.91
Extended Length (IN): 23.5
25-227611 (5160 4th gen 4Runner)
Collapsed Length (IN) 14.83
Extended Length (IN) 23.5
I had standard length 3rd gen 5100's in before and after putting in 210v springs (~4" lift with approx. 350 extra lbs. full-time up top and in back) the valving felt kind of soft. The 5160's (for the few miles on them now) are much better suited for the higher stance, as they make the truck feel more planted while eating up the bumps better than before.
'00 'Get Lost' Build
IG: get_lost_fiffa
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
