07-02-2013, 04:39 PM
I'd just call crutchfield. They have the correct harness and will let ya know which one ya need -
'96 Limited - Locker - 127k- totaled out -
'01 Limited 175k - sunken and resurrected - stock, other than TBU 231mm
'98 Limited - Locker -158k-Bilstein 5100 Tacos- Toytec/Eibach 3" lift coils- diff drop-265/75/16 Duratracs -OME 890's-Bilstein 5125's, panhard bar drop, TBU 231mm, Spidertrax 1.25' spacers, Savage sliders, 2nd gen SC/URD 7th, JBA exhaust, HID retrofits -
07-02-2013, 11:57 PM
Real Name: Steven
Real Name: Steven
I wired mine without a wiring harness, I hated the previous owners aftermarket head unit. He had cut the Toyota stock wiring harness so i had to hard wire the new head unit I picked up as well. After following his wiring I quickly found out he was an idiot. If you don't want to use the wiring harness at all here is the color codes for the stock wires. Just look up the color code for your head units wiring harness and match up the correct colors and crimp them together. It will take a little longer but will save money and wait time on the harness being shipped
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Violet
Car Stereo Dimmer Wire: Black/White
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
07-03-2013, 01:50 AM
Real Name: Mr. Allen
Thank you so much! Great info. The person who installed this aftermarket radio was also an idiot. I hate that we have to put up with someone elses stupidity...it only confuses me
07-03-2013, 01:48 PM
I agree with afg10000, call crutchfield. Their customer service is awesome.
85 Xtracab, 3Link Front, Marlin Dual Ultimate, Double Locked on 37s
07-03-2013, 01:54 PM
is the factory amp pulled out? it should be when installing new radio.
Never ask a girl if shes sick, she might not be wearing any make up. - lets just say she went storming off.
Never tell your wife she looks tired, they tend to hit and say that means she looks ugly. (weird logic i know)
07-03-2013, 01:59 PM
Yeah, it wasnt there when i pulled the old radio out. It looks like 4th of July snuck up on me so I am going to get back on this Monday. Woot! Independence Day!!
07-03-2013, 02:53 PM
I just bought one from Best Buy and it really was plug (solder) and play. I think it was $15-20 and they had it in stock...
2014 4Runner Trail Edition Premium - Magnetic Gray
2001 4Runner SR5 Thread...Sold
2010 Bernese Mountain Dog
1998 4Runner Limited: Smooshed on an icy bridge in MT
07-19-2013, 03:19 PM
I figured it out. It looks like the person who installed the aftermarket radio did not use a harness at all. Crutchfield and Best Buy all had the same harness and they insisted I use the one they specify.....if I had the original equipment then I am sure the harness would have worked but I do not so time to crimp and cut!
02-06-2014, 12:32 AM
i am confused on the diagram. i am working with a 99 4runner and my question is on the Car Radio Illumination Wire: Violet and the Left Front Speaker Negative Wire (-): Violet are they the same wire? because i only have one violet.
02-25-2015, 07:47 PM
Revived from the dead.
Scrhew, did your truck come with the stock amp? I'm about to wire in an aftermarket deck and this was the best wiring list i could find. I'm no google or search button noob either.
02-25-2015, 08:16 PM
I'm sure his did. If you are replacing from stock the harness you get at bestbuy/crutchfield should be a plug and play situation, but in my situation ALL the wires were cut so I used his diagram but if I remember correctly the wires matched up color for color anyways...
02-25-2015, 09:43 PM
I think i just answered my own question. The amp is removed when you install an aftermarket deck, so you're dealing with the wiring straight from the harness, not the wires from the amp. Amirite?
02-26-2015, 12:11 AM
They are not the same wire. Assume yours is the speaker wire. The other violet wire is only in the harness between the stock amp and the stock HU. If both stock amp and HU are gone, then so is the other violet wire--no biggie.
If you want to confirm, take a D cell battery and touch between the violet and the pink wires. You should hear a click from the driver's door speaker.
BTW, one error on the list is the antenna trigger is the black/white wire--4Runner had no dimmer function on the radio. My list is the factory '99 4Runner EWD manual.
My Backyard Frame Swap
02-26-2015, 12:17 AM
Yeah. Ideally you can use the harness plug and an aftermarket conversion harness with your new HU pigtail. But if dumbass PO cut out the plug, you have to crimp and cut to the body harness.
