Old 04-21-2020, 04:52 PM #1
Double0-12 Double0-12 is offline
Double0-12 is on a distinguished road
What is this part called!!??? (It's not a transfer case mount)
I have a clunk upon acceleration from a stop or when accelerating after coasting and think I found the culprit, but I can't find the part number for the life of me. I would call it a transfer case mount/support. When looking at the TC from the rear, it's on the right side and is made of rubber. Bonus points if you provide a part number! Here's a pic:
What is this part called!!??? (It's not a transfer case mount)-transfer-case-mount-jpg
Double0-12 is offline   Reply With QuoteReply With Quote
Old 04-21-2020, 05:00 PM #2
Team_Jake's Avatar
Team_Jake Team_Jake is online now
Team_Jake will become famous soon enough Team_Jake will become famous soon enough
Team_Jake's Avatar
Transfer Case Dynamic Damper. P/N 33183-35050.
I always use japan-parts.eu if I need to look up part numbers. They have pictures and diagrams of everything so it's easy to navigate.
1999 4Runner Limited - 5VZ, 4wd, Factory E-Locker, Multi-Mode, 5-speed swap, Armored, Icons, 295s (thread)
2001 Tacoma Xtracab - 3RZ, 4wd, 5-speed (Daily Driver)
Team_Jake is online now   Reply With QuoteReply With Quote
Old 04-21-2020, 05:05 PM #3
Bad Luck Bad Luck is offline
Real Name: Patrick
Bad Luck is a jewel in the rough Bad Luck is a jewel in the rough Bad Luck is a jewel in the rough Bad Luck is a jewel in the rough
Real Name: Patrick
Transfer case vibration dampener. I doubt it's the source of your clunk, but you can remove it and test drive to see if that was your clunk.
2000 Limited V6 Auto E-Locker
Old 04-21-2020, 05:07 PM #4
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim has much to be proud of mtbtim has much to be proud of mtbtim has much to be proud of mtbtim has much to be proud of mtbtim has much to be proud of mtbtim has much to be proud of mtbtim has much to be proud of mtbtim has much to be proud of
mtbtim's Avatar
Real Name: Tim
I think the correct term might be thingamagigger but I could be wrong. It might be a doomaflache or a chingadera.
Old 04-21-2020, 05:18 PM #5
RandyBobandy's Avatar
RandyBobandy RandyBobandy is offline
RandyBobandy will become famous soon enough RandyBobandy will become famous soon enough
I would remove it and see if it fixes your issue, lots of people remove them and report no negative side effects
RandyBobandy is offline   Reply With QuoteReply With Quote
Old 04-21-2020, 05:28 PM #6
gamefreakgc's Avatar
Real Name: Jerod
gamefreakgc is a glorious beacon of light gamefreakgc is a glorious beacon of light gamefreakgc is a glorious beacon of light gamefreakgc is a glorious beacon of light gamefreakgc is a glorious beacon of light gamefreakgc is a glorious beacon of light
Real Name: Jerod
It helps with vibrations. There's also one downstream on your exhaust if it's still stock.
No ill affects if you remove it, just might be a little more noise or vibrations when driving.
'98 4Runner SR5 - 4x4 5VZ-FE Supercharged - 222k miles, JDM engine @ 221k
AEM F/IC 6 Piggyback, 2.1" pulley at 11 PSI, Go-Fast Parts
Old 04-21-2020, 06:24 PM #7
Awesome! Thanks y'all!
Old 04-21-2020, 06:43 PM #8
Holy shit! That thing is $400!!!!
Old 04-21-2020, 06:51 PM #9
Team_Jake's Avatar
Team_Jake's Avatar
OP,
I seriously doubt this part is causing your "clunk" issue, but if you want to get a replacement anyway, scour any pick-and-pull with a 4WD 4Runner and get it from there.
Old 04-21-2020, 06:59 PM #10
OP,
Yeah, you're probably right. I'll spend the money on a proper diagnosis and go from there.
Old 04-21-2020, 07:03 PM #11
how are your U joints? they can cause the issues you are describing
Old 04-21-2020, 08:01 PM #12
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
U-joints, driveline slip joint, 3rd member, upper or lower track bars, shocks, engine mounts, ect....
Lots of stuff could cause such a clunk.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 04-22-2020, 05:19 PM #13
jgue467's Avatar
jgue467 jgue467 is offline
jgue467 has a spectacular aura about jgue467 has a spectacular aura about
jgue467's Avatar
I have a clunk upon acceleration..
Why not just Tighten the bolts holding it down?
It doesn't 'clunk' it rattles very nicely when loose, ask me how I know...
2001 Limited 4WD - 324K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL, ZERO RUST - StopTech ANGLED rotors - Magnefine trans filter - In series trans cooler, ORIGINAL: paint, engine, 4wd, trans, mstr cyl & brake system, rear axle seals, A/C, steering pump, steering rack, front/center/rear diffs, all electric motors, seat heaters and so on. WooHoo!!
Oh yeah, GO LONGHORNS!
Old 04-22-2020, 05:39 PM #14
3bears 3bears is offline
Real Name: Joshua 3 Bears
3bears has a spectacular aura about 3bears has a spectacular aura about 3bears has a spectacular aura about
agree with above...every spring...and every fall....when I do a shake down service and prep for the next season and conditions....I crawl through everything and check to see if tight....
2000 SR-5 V6 Auto . Desert Dune, Spectre intake, Borla muffler, Magnafine tranny filter, B&M cooler, Talls, KYB, Airlift 1000, DRL delete, Big 3 wire, full rack, TBU, Swapped in Elocker, some LEDs, PIAA headlights, , Amsoil
Old 04-22-2020, 05:45 PM #15
yep...good site and more accurate with a vin,
case , mount/support , number , part , transfer
Transmission to transfer case hose part number: *Pic* fourfive 3rd gen T4Rs 3 12-10-2019 01:33 PM
FS 3rd Gen '01-'02 Transfer Case Actuator $50 + Transfer Part Out, Idaho Falls, ID BanditJunior For Sale: T4R Items 1 05-01-2019 01:57 PM
Transfer Case bushing and extra part numbers? help sleepydad 3rd gen T4Rs 2 03-29-2018 06:49 PM
part number help: transfer case input shaft oil seal infamousRNR 3rd gen T4Rs 2 02-26-2017 10:54 AM
What is this part- Transfer Case davidaw 4th Gen T4Rs 1 02-19-2014 12:19 AM
