Old 04-22-2020, 11:57 AM #1
snydmax's Avatar
snydmax snydmax is offline
Real Name: Matt
snydmax will become famous soon enough
snydmax's Avatar
Real Name: Matt
Sheared Rear sway bar bolts
I recently tracked down a new rattle to a rear sway bar shackle... one of the bolts had fallen out and the bracket was jingling around back there. A few months back I swapped in energy suspension poly bushings while installing new shocked and springs so I figure I must have missed that bolt when torquing everything down.
I ordered (4) new bolts from Toyota, but when trying to get them to the 42ftlbs spec, they were snapping off. Looks like the bolts bottom out before you get there.
Anybody else seen this? Do I have the wrong torque spec? Could it be Something is worn out with the mounting brackets that is letting the bolts bottom out prematurely?
To clarify, we are talking about the bolts that hold the sway bar to the axle... here’s what Toyota sold me: 91611-g0816
'98 4WD Limited, Warm Grey, 172k, Factory E-Locker, Ride-Rites, 265/75-16 Wildpeak AT3s
snydmax is offline   Reply With QuoteReply With Quote
Old 04-22-2020, 12:07 PM #2
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
That should be a 12mm headed bolt. No way it can sustain a 42 lb-ft torque spec. More like 10 is what I would expect.
JZiggy is offline   Reply With QuoteReply With Quote
Old 04-22-2020, 12:25 PM #3
Close. The bushing bracket bolt spec is 14 ft-lbs, along with the end link top nut. The end link nut at the bottom is 51 ft-lbs (seems high?).
Basically, those 12mm head bolts/nuts should be just above snug with a 12" ratchet.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 04-22-2020, 12:37 PM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Not only will those bolts break they rot off too on those brackets and those sway bar end links. I had quite of few end links rust off and need replaced too. :-(
Old 04-22-2020, 01:05 PM #5
snydmax's Avatar
Real Name: Matt
snydmax's Avatar
Real Name: Matt
Thanks y’all! Snug it is... I must have been dyslexic when I looked up the specs.
back , bar , bolts , rear , sway
Sheared bolts and seized bolts. Need help. mavrick1903 4th Gen T4Rs 8 07-18-2017 01:33 PM
Rear Sway Bar mount bolt sheared off worldcoast 3rd gen T4Rs 4 03-16-2013 08:17 PM
Rear shock sheared off... thatgreentruck 3rd gen T4Rs 7 12-20-2012 07:10 PM
Bolts sheared off of LBJ Dous 3rd gen T4Rs 39 06-27-2012 08:58 AM
Front Skid Plate Bolts Rusted/Sheared Off? EzyGlider 4th Gen T4Rs 4 10-03-2011 08:52 AM
