Old 04-28-2020, 05:07 PM #31
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Originally Posted by Devbot View Post
I thought about this after the new ECU failed to fix it, but i dont have the first clue where these wires start and end up. How hard of a job is it?
That's a hard question to answer. I can rank it in terms of hardest jobs I have done, 1 through 10. 1 meaning an air filter replacement and 10 being complete engine swap and rebuild. I'd rate removing and re-installing an engine harness a 5, since it's for both the engine and the transmission. The engine part actually isn't that bad, since you can leave the lower engine harness in place (alternator, starter) and only replace the main harness. You can disconnect the ECU and just shove the whole harness into the engine bay and just go one by one following wires and taking them off. No two connectors are alike so you can't mess it up. You do have to pull the upper intake to disconnect the fuel injectors. The auto transmission is what will give you the most trouble since there's no space between the transmission and the floorpan to disconnect those connectors and they corrode something fierce. I had to use mirrors and pliers on mine.
You'd also have to find a harness from your year and drivetrain. So a 98 4WD isn't the same as a 98 2WD, which isn't the same as a 99 2WD, etc.
326WHP 347TQ
Old 04-28-2020, 09:28 PM #32
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Thanks for the info, sounds like quite a bit of work and money. Considering I've dumped a lot of cash into this already I'm gonna continue to keep prodding around first and hope I can catch a short in progress. From the knock sensor connector to the ECU initially measured less than 0.2ohms, maybe I just need to try over and over
Edit: forget to mention that the car now idles better (only high on a cold start) and OBD shows no retarded spark despite the codes, so that's a plus
Old 04-29-2020, 11:00 PM #33
jbtvt's Avatar
jbtvt jbtvt is offline
jbtvt has a spectacular aura about jbtvt has a spectacular aura about
jbtvt's Avatar
A short may not affect continuity to the ECU but it may still affect the signal. If a rat chewed the wires so that the signal and grounded shielding wires are touching but the signal wires are still intact, you would get continuity to the ECu, but also continuity to ground. Depending on the resistance in the ECu circuit, it is likely that more current will got straight to ground, which could potentially throw your ECU for a loop and trigger a code.
Continuity tests should be done after depinning the wires from the connector, do a search and you'l see how to do it, or at least unplugged from ECU. It isn't a good idea to test for continuity while connected to sensitive electronics as the voltage used to test can damage components.
'85 4Runner, 22re 5spd; '90 4Runner, 5spd, 3.4 swap
'98 GS400 1uz; '07 GX470 2uz
jbtvt is offline   Reply With QuoteReply With Quote
Old 05-02-2020, 10:07 PM #34
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
I hear you. Once the weather clears up I'll tackle it again, been pissing rain over the past few days
Old 05-03-2020, 01:11 AM #35
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Where would be the best place to find a spare ECU harness? Pick n pull shows no 4runners anywhere close
Old 05-03-2020, 01:19 AM #36
jbtvt's Avatar
jbtvt's Avatar
car-part.com
Might do better searching for other parts besides harness on year you need and then calling to see if they'll pull or you can pull yourself. I know from experience that wiring harnesses aren't a big mover so they might have the truck you need on the yard but not bothered to list the wiring harness
edit: although I'd still start with just rewiring the couple wires you suspect are shot, of tracking down the flaw in your existing harness, whole replacement is a PITA, much easier to cut and splice what you need
Old 05-03-2020, 07:42 AM #37
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
PM fellow member @DeathCougar . He is in the Evergreen state as well.
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 05-05-2020, 07:51 PM #38
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
That's more or less what I'm starting to get at - from what I understand they have to come from a nearly identical vehicle and trying to find a harness for a Californicated '00 SR5 4x4 specifically could take a while. Local hardware store sells lots of shielded wire I could use to replace what's there but I'm still figuring out how to properly fix them to the connectors.
The other problem is determining which wire is giving me hell; given that it's been quite a few codes (0135, 0325, 0330, 0420; knock and O2 sensors) then it seems like it's unlikely to be purely the knock sensor wire, and I feel like the combination of codes has to help allude to this. At least that's my take. I'm clearly no electrician.
Thanks for the help everybody, btw. Much appreciated. Just my damn luck that 99% of threads on this issue either come to a halt or end with "took it to the shop lol"
Old 05-05-2020, 10:41 PM #39
jbtvt's Avatar
jbtvt's Avatar
"be the change" ;)
Shielded wire is basically a coaxial cable. Just tie a length of regular wire into the shielding/sheathing wires, I'd use solder but might be able to get away with a crimp connector as long as you check connections, wrap other end of wire around a tec screw anywhere on body and shoot it in. Main conductor connects like any other. Heat shrink and/or 2 coats liquid electrical tape to insulate
Thinking, it's interesting that all the codes you mention are related to a fluctuating/oscillating voltage signal to ECU. I wonder what the signals are compared to internally. Maybe there's some error in the reference signal for either volts or...time signal (is hz even a thing in dc?) Have you checked how many volts your regulator I putting out?
Old 05-08-2020, 02:32 PM #40
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
I cant say that I have, but now I have a bigger problem. Hood cable has broke and now I cant get inside the engine bay. So now that has to be fixed, if it can be. Was able to pull on the cable to get inside once but its stuck good now. I'll have to jump back on this gremlin after I sort this out.
The build quality on these vehicles is so piss poor, it's starting to become impressive.
EDIT: thankfully these cables are <$20 from vatozone
Old 05-17-2020, 09:20 PM #41
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Fixed the hood release. Hopefully it'll last another 20 years
What are the chances of finding one of these connectors, outside of buying an entire engine harness? Roped in my pops to help me and he had the same idea about splicing in some new connectors and running it to the ECU, if they're easily found that is
Hopefully this will be the last step; really want to put this behind me so I can get to building this into a crawler
Old 05-17-2020, 09:34 PM #42
jbtvt's Avatar
jbtvt's Avatar
I'd just cut the wires a few inches up and solder new to it, and ground shielding to anywhere handy. If you really want to replace, spade connectors are readily available, as far as the knock connector you might be able to find something here - Toyota parts catalog
Old 05-30-2020, 10:24 PM #43
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Well, tried to tap a new wire in today to no avail, but it did help shed some light. CEL came back pretty fast.
The new wire was soldered to the knock sensor harness as opposed to the engine harness, which was done for this situation; if the code came back (which it did) then we know for a fact the problem would lie in the KS harness since the wires connecting from there to the ECU are completely out of the equation (or could be the sensors themselves, but given that the waveforms were almost textbook, and the harness is much more inclined to giving out, I'll take the cheaper route.) I'm forced to take it down to the manifold again, but at least now I know which "half" the problem lies on.
Old 06-13-2020, 08:53 PM #44
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Fixed?
Think I've done it. Today I went the full nine and removed the bypass and replaced both the KS harness and sensors themselves - this time using Denso sensors as opposed to Matsu's, which tested out MUCH more cleanly in comparison, and were also much more sensitive. To boot, the old harness ended up having a hard pinch in it (from the manifold) but the continuity still tested fine through it. I'm not sure which of these were the potential source.
Regardless, everything was replaced brand new for a 2nd time. Car was left to idle with occasional revs for maybe 5 minutes, then I drove it like a bat out of hell for maybe 10 with no codes returning
Eventually I did get another P0171 code but it's because of a vacuum leak at the plenum/manifold, thanks to a good ol carb clean diagnosis, which I can tackle again later. Hopefully this is the last of it. Will come back in a week or so with a verdict
Old 06-20-2020, 01:06 PM #45
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Fixed.
Been a week and I feel comfortable in saying;
the gremlin has been caught
In the end I'm not sure what exactly remedied the issue. I did read iffy things about Matsu's knock sensors, and Denso's seem to test out much more cleanly, so if there's anything to be taken away - use OEM Denso sensors
Thanks for everybody's help.
harness , knock , p0325 , sensor , sensors
P0330 AND P0325 Check Engine Codes? Knock Sensor 1 and 2 Circuit Malfunciton Nooga_Rock 3rd gen T4Rs 6 12-09-2020 08:32 PM
P0325- Knock Sensor on 3.4L Supercharged Noshirtganshirt 4th Gen T4Rs 3 11-25-2017 07:56 AM
P0325 Knock Sensor But..... UTEP 3rd gen T4Rs 6 04-18-2016 09:08 AM
P0325 (Bank 1 sensor 1) Knock sensor (Help) djskorch 3rd gen T4Rs 3 01-08-2015 06:36 PM
