Originally Posted by tgreenwood75
Thanks
@ 19963.4lsr5
, I had actually read that post but did not understand the phrasing and context of the problem until I ran into the same issue! Now that I've figured out exactly what I need, all additional adapters are ordered up and I should be set. Seeing everyone else's touchscreen setups is making me want to upgrade before I even finish this install!
I love the T1819 but wanted a dedicated NAV unit in the 4Runner. It also rocks better. (At least in my little Saturn SL sounds great with 4 6.5” 3 way speakers) And I had done all the work fitting the T1819. I ended up using a 2013 Corolla unit. Mainly because it had built in XM radio if I ever wanted to use that. The T1819 required a external module. Plus I couldn’t find the newer NAV units with the entune module.
I miss the call button the T1819 radio has that the NAV doesn’t. Plus you can’t make calls through the NAV if your moving.
Enjoy. It’s a great “mod” if you spend a lot of time in your rig. I spend 50min each way to work.
