09-11-2012, 05:15 PM
Lotus CV Axles are here!
ToyTec Lifts is now carrying the new CV axles by Lotus Development!
Since heavy 4 wheeling and rock crawling puts much more stress on the axles, the stock ones are prone to breaking. One employee here has broken 12 stock axles! (100 useless points if you guess who )
These axles take Toyota OEM axle housings and upgrade the components inside the outer joint with a newly engineered race and cage. In addition to the added material thickness we also upgraded to chromoly steel. The new cage and race components are over 6 times stronger than a stock outer joint. They fit on 96-02 4Runners and 95.5-04 Tacomas with ADD. They will not fit truck with manual locking hubs.
Lotus wall depth
OEM wall depth
Check them out on our website and give us a call if you have any questions!
*NEW* Lotus Heavy Duty Front CV Axles - Toytec Lifts: Toyota Lift Kits: FJ Cruiser Lift Kits, Tacoma Lift Kits, Tundra Lift Kits, 4 Runner Lift Kits, Sequoia Lift Kits, Toyota Truck Lift Kits
-Dylan
09-11-2012, 05:31 PM
Moderator
Real Name: Waldo
Moderator
Real Name: Waldo
Any warranty on them? Cus, I guarantee you I'd break one lol
'99 Toyota 4Runner LTD - Dual Locked | Geared | Mid-Travel | 35s | Armored
09-11-2012, 05:40 PM
Real Name: Brian
Real Name: Brian
Better not break for $500 each:jaw drop:
09-11-2012, 05:47 PM
Real Name: Jeff
Real Name: Jeff
I'm willing to bet that you wont. I've been running these axles for a year now and they have not broke. Your diff will explode before the axles will break. Ask me how I know...
That's not to say they are unbreakable. But they are definitely WAY STRONGER than the stock axles.
3RDGENS.COM
My Video's
'96 Limited - October '08 T4R Of The Month (Sold)
'00 SR5 - Lifted/Supercharged/E-locker
'16 SR5 Barcelona Red
09-11-2012, 05:49 PM
Those are SWEET! Just saw your fb post about them.
Wish I had an extra $1,000 lying around for them
'97 SR5 4x4
3" Toytec lift | Eibach/OME Springs | Bilstein Shocks | 285/75 Treadright MTs | Curt Rack | DVD/NAV | More to come...
Follow the build here:
The Waketek516 Build
09-11-2012, 06:10 PM
Real Name: Isaac
Real Name: Isaac
yeah they say ARBs wont break either....
when are you guys gonna make a set for the manual hubs?
if a*sholes could fly this place would be an airport -2004 GX470 spm -97 SR5 3.4, SCS Stealth 6's w/305 70 17s MTRs, Icon 2.5" RR w/700#coils, OME861s w/Icon tacoma 2.0 RR, ARBs w/nitro 4.88, PIAA LED lights, 170amp CS144, ARB snorkel, ARB bumper w/xd9000ce, CBI swingout loaded, BudBuilt skids, lil skip tank skid, sliders, LCE 231s(d&s), first gen roll bar mod, LED interior/dash lighting, B&M 70624+perma cool w/electric fan, dual electric fanshttp://www.toyota-4runner.org/3rd-ge...ld-thread.html
http://www.metaltech4x4.com/
09-11-2012, 06:19 PM
I think would would rather replace an axle then rebuild or replace my diff because now you are just moving the weak spot to the diff. So if you up grade your Axles then you need to upgrade everything that it goes to. My .02$ worth
09-11-2012, 06:29 PM
Real Name: Jeff
Real Name: Jeff
Correct. I would agree with that. That happened to me. But the stock diff is pretty weak. These axles paired with an ARB, TruTrac, Lockright, etc will be considerably stronger than the stock set up.
3RDGENS.COM
My Video's
09-11-2012, 06:51 PM
But how much is it 6x stronger to hold up to the new axles what about everything else ball joints and Thing like that if you get all that stuff in a bind that would break a stock axles with my break ball joint bust up the diff you have to look at all that stuff. An axle is 65 buck from oreallys and maybe a 45 min job vs $$$$$ for a diff or a tow to fix some really jacked up stuff I would Like to see what kind of R&D they put in to this not much if you ask me I can get a local shop he to beef up the joints in my cv axles they rebuilt the but I don't see any point for what I can buy one for plus they have a Lifetime warr. And only takes me 20 mins after I have it on the rack to replace one. So that is an hour d my time to pull it go get a new one and install it.
09-11-2012, 07:04 PM
Real Name: Jeff
Real Name: Jeff
I'll wait to hear COB's translation for this post. You lost me after the first line.
3RDGENS.COM
My Video's
09-11-2012, 07:45 PM
Real Name: Jeremiah
Real Name: Jeremiah
It's about time!
x2 on the warranty?
Has the axle bar or inner joint been upgraded as well, or is it just stock stuff?
If it is stock components, can you sell just the HD outer joint and boot?
09-11-2012, 07:48 PM
talk about a run on a sentence there, making it hard to read..
Anyways, if you, keep snapping CVs, maybe you, need to learn how to wheel.
If the price is to much for you to handle, then stop *****ing about them.
As far as the R&D of these, unless you personally know the guys at Toytec, as I do, then you have NO room to talk, these guys test everything they sell, and they test it HARD....
Toytec has a very good reputation unlike yourself, if they are selling something, they back it up, if they sell something I want, Im buying from them.
I dont see you questioning Toyotas R&D, or Goodyears R&D, etc etc, so for you, to come here and questions a very highly reccommended vendor, a company with a great, customer service record, is just plain funny, shows just how much you know.
If you think, you can make something better, go for it, or stop your *****ing.
09-11-2012, 07:56 PM
Real Name: Connor
Real Name: Connor
This just completed my life.
1996 Toyota 4Runner 4x4 w/ 5 speed- Lifted, Locked,Painted,Armored
Build: http://www.toyota-4runner.org/3rd-ge...ld-thread.html
Originally Posted by invisible4Runner
Highlander = minivan, purses, soccer practice
4Runner = testosterone, steak, dirt
09-11-2012, 08:00 PM
Moderator
Real Name: James
Moderator
Real Name: James
dude, I almost died laughing when I read this. I can't decipher most of it.
Those lotus axles are kick ass, sure wish I could afford a pair.
04rnr looks like he's got it covered haha
IG: @jimharb | YouTube | '99 Limited 2WD |
'99 4Runner - 2.7L 3RZ-FE - TRD S/C - 4WD Conversion + R150F 5-Speed Swap - Imperial Jade Mica on Oak
'87 4Runner Turbo - 2.4L 22R-TE - CT-26 Supra Turbo - W56 5-Speed Swap - Red on Red
'90 4Runner 2-Door - 3.0L 3VZ-E - Auto to R150F 5-Speed Swap - Red on Gray
'94 Supra Turbo Targa - 3.0L 2JZ-GTE - Marlin Crawler R154 - Imperial Jade Mica on Black
'89 Supra Turbo Targa - 3.0L 7M-GTE - Marlin Crawler R154 - White Package on Blue
'89 Pickup DLX 2WD - 2.4L 22R-E - W55 5-Speed - White on Blue
09-11-2012, 08:23 PM
The whole point if the post is that if you beef up your axle you are just moving the weak point to your diff what is so hard you all to get that in your head....
Like i said did they test this with a 6x stronger Diff.... That is I am talking about R&D.
Axles I have one ever broken one and that was because the boot was ripped open and I drove it like two years then it was popping and I took it wheeling.
So the point of the post was hey I just paid a 1000 bucks for some 6x stronger Axles and now I ****ed up my diff and got to drop 3000 in it damn that was a lot of money spent for some axles.
I don't make anything I just test it and break it that is what I do for a living test things to there breaking point just like the super 35 for jeeps you see how long they lasted in the market....
Rant off
