Old 04-26-2020, 12:19 PM #1
lowlinkin's Avatar
lowlinkin lowlinkin is online now
Real Name: Brian Killebrew
lowlinkin will become famous soon enough
lowlinkin's Avatar
Need some help
So I’m tackling my injectors and valve covers today and came across this. Anybody had this happen. Spark plug came out with the coil pack. I’m concerned because the threads are stripped on the end of the spark plugs!
Need some help-12b17bd9-7334-42f1-b9d1-c2118e1ac11f-jpeg
lowlinkin is online now   Reply With QuoteReply With Quote
Old 04-26-2020, 12:26 PM #2
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Not a good sign... normally though if they go, they will blow out of the spark plug hole during the combustion stroke!
Can you try and gently hand thread it back in? Any chance it's just that one spark plug that's the issue? If not, you can try a helicoil or something similar but it may be a job for a shop. Alternative is to replace the head, unfortunately.
326WHP 347TQ
Old 04-26-2020, 12:30 PM #3
RandyBobandy's Avatar
RandyBobandy RandyBobandy is offline
RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice
maybe the spark plug wasn't threaded all the way in? I'm not sure if that would cause a miss or not, I would try to put a new plug in and see if it holds
RandyBobandy is offline   Reply With QuoteReply With Quote
Old 04-26-2020, 12:35 PM #4
lowlinkin's Avatar
lowlinkin's Avatar
I had gotten a misfire code so I assumed I fried that injector. That’s the only on that came out like that. I’m going to replace the plugs while I’m here and hopefully it work. Fingers crossed. I’ll update what I find. If I have to take the head off it will be faster just to replace the motor with a Japanese spec motor.
Old 04-26-2020, 12:41 PM #5
lowlinkin's Avatar
lowlinkin's Avatar
Ok so just tried another plug and I can’t even get it started! Sooo now to figure out what my best options are.
Old 04-26-2020, 12:52 PM #6
HiLife HiLife is offline
When I got my rig, i did a spark plug change as part of getting back to baseline.
OP didnt mention one of the plugs was stripped. Oh well, part of buying anything used.
I put I Time sert in and it's been good for 90k miles now. Ideally a non stripped spark plug thread head would be best.
Old 04-26-2020, 01:02 PM #7
sweet88gt's Avatar
sweet88gt sweet88gt is offline
sweet88gt is on a distinguished road
sweet88gt's Avatar
YouTube
I would start here for some info to get started
1997 3.4 Limited 4x4 197xxx miles
sweet88gt is offline   Reply With QuoteReply With Quote
Old 04-26-2020, 01:25 PM #8
Reinout's Avatar
Reinout Reinout is offline
Real Name: Reinout
Reinout will become famous soon enough Reinout will become famous soon enough
Reinout's Avatar
Real Name: Reinout
If the condition of your engine is otherwise good I would say have a mechanic put in a heli-coil. I'd probably NOT mess with that myself since there'll be metal shavings and you don't want that in your engine block if you don't already have shavings in there.
Know-How Notes: How to install a Helicoil Insert ~
1997 4Runner SR5- ~376k Miles and counting - 5 Speed E-Locker
2007 4Runner Limited V6- 165k Miles - Automatic - Brake Controller
2011 VW JSW TDI- 130k Miles - 6 Speed - Air Lift 1000
2006 Scamp trailer 16'
Reinout is offline   Reply With QuoteReply With Quote
Old 05-02-2020, 11:35 PM #9
lowlinkin's Avatar
lowlinkin's Avatar
ok so quick update, I retreaded the hole and added a seat to it today. Went ahead and changed out the injectors since I had them and now its running like a champ.
Old 12-23-2020, 07:07 PM #10
4x4runnerMT 4x4runnerMT is offline
4x4runnerMT is on a distinguished road
Any updates on if the time sert is still holding beyond 90k miles?
4x4runnerMT is offline   Reply With QuoteReply With Quote
Old 12-23-2020, 07:08 PM #11
Originally Posted by sweet88gt View Post
YouTube
Didn’t know this video existed! Thanks!
Old 12-24-2020, 08:00 PM #12
I recently did a plug change at 11k miles ago.
The time sert been in the head for seven years and 97600 miles with no issues to the time sert to the spark plug fitting. I say that because there is an issue with the time sert to head fitting very tight. Timesert itself is not loose. The plug looks to be burning great. Color is like the rest of the 5 spark plugs with virtually no compression loss via compression gauge.
Only issue is I have been getting oily residue on the threads, so it could be a ring or valve guide issue in that cylinder. Engine is going on 322000 miles.
I already checked the spark plug tub seal is sealing up good on that cylinder. Could be I fouled up on the oversize reaming in preparation for the timesert.
Old 12-25-2020, 08:23 PM #13
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
I would put in a time sert and see what happens.
2000 4Runner Limited 4x4 V6
coil , concerned , i’m , pack , spark
