Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 04-28-2020, 11:39 AM #16
sugjavier sugjavier is offline
sugjavier will become famous soon enough
I'm very interested on this but would like to know if this increases braking power over the factory drums?
2001 Toyota 4Runner Limited. 231k miles.
sugjavier is offline   Reply With QuoteReply With Quote
Old 04-28-2020, 11:54 AM #17
JZiggy's Avatar
JZiggy JZiggy is online now
JZiggy is a splendid one to behold JZiggy is a splendid one to behold JZiggy is a splendid one to behold JZiggy is a splendid one to behold JZiggy is a splendid one to behold JZiggy is a splendid one to behold JZiggy is a splendid one to behold
JZiggy's Avatar
Super cool! Nice job! Cant wait to see some more installs.
JZiggy is online now   Reply With QuoteReply With Quote
Old 04-28-2020, 11:58 AM #18
raKnizek's Avatar
raKnizek raKnizek is offline
Real Name: Alex
raKnizek will become famous soon enough
raKnizek's Avatar
Real Name: Alex
This looks great! I would be interested in future orders including the parking brake kit.
I am also curious about the master cylinder and if combining this upgrade with the TBU would required changes to the cylinder.
I will have to do some searching to see experiences people have had with other rear disc brake set ups.
2000 SR5 3.4, Manual, 4x4
Icon 2.5 extended coilovers & 2.0 rear, JBA UCAs
265/75R16 General Grabber X3 on LC80s
4XInnovations Sliders
raKnizek is offline   Reply With QuoteReply With Quote
Old 04-28-2020, 12:08 PM #19
brillo_76's Avatar
Real Name: Jon
brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold
brillo_76's Avatar
Real Name: Jon
I am not one for non stock mods but I must say this solves the problem for the rear backing plates rotting away in the rust belt. Great job OP. Looks like a very solid setup and fairly easily to do.
Any chance that the conversion kits will come with rock shields for the rotor as a kit option? As small rocks can play hell on rotor and pads if they get in between the rotor and pad assembly. ;-)
1997 4X4 V6 5 Speed Sr5 4 Runner (The Tank)
1997 4X4 V6 Red limited 4 Runner (97 Limited)
1998 4X4 V6 Sr5 Red 4 Runner (98 Tetanus1 )
1998 4X4 V6 Sr5 Silver 4 Runner (98 Tetanus2)
2001 4X4 V6 Sport Green 4 Runner (01 Green Sport)
Old 04-28-2020, 12:17 PM #20
midcoma midcoma is offline
midcoma has a spectacular aura about midcoma has a spectacular aura about
Originally Posted by VernySanders View Post
How smaller are these calipers than the tundra calipers?
From a quick search, it looks like the Tundra rotors are 12.6" diameter and the 4Runner rotors are 12.3" diameter. If you're talking about the calipers, the Tundra front, 4 piston calipers are much larger than the the Mustang rear, single piston caliper.
Here's my brakes for reference. 231mm Tundra up front, Mustang conversion on rear.
Front:
Rear:
Second question is isnt drum brakes better for off road?
There are plenty of threads discussing the difference between drum and disc brakes. I'll just say that's it's personal preference. I prefer the rear disc for ease of maintenance on the brakes, axle bearings, and seals. They're also self-cleaning and don't trap mud.
Originally Posted by RandyBobandy View Post
One question, do you need to upgrade the master cylinder for this kit?
I think it will depend on your overall brake set-up and what you prefer for the pedal feel. I upgraded my master cylinder, but I also have 231mm Tundra calipers up front and I removed my ABS. I've read of people converting to rear disc with tundra brakes up front, keeping ABS, and not having any issues with the stock master cylinder. There are too many variables to give you a solid answer.
Originally Posted by eimkeith View Post
Yes; however, order more than you think you need. I ordered one from Amazon and it was the right part number, but the box contained the wrong bracket. So I suggest ordering maybe 4 and returning what you don't need because I expect not all of them will be correct.
Originally Posted by theesotericone View Post
Having the ability to lock one rear tire and pivot off it would be almost as good as front digs.
I was wondering why you would want a line lock if you were using a t-case parking brake. That answers my question though. PM me if you need any more info about setting up a t-case brake. I may have some parts from my old set-up as well if you need them.
Originally Posted by rexassian View Post
Would going down from the frame to the control arm and under the axle tube limit suspension travel?
I have a 4WheelUnderground rear 4-link on my 4Runner and the travel is not limited by the parking brake cables. There will be plenty of cable length for most rear suspension configurations.
midcoma is offline   Reply With QuoteReply With Quote
Old 04-28-2020, 12:31 PM #21
weekendclimber's Avatar
weekendclimber weekendclimber is offline
Real Name: Scott
weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice
Real Name: Scott
Add me to list if you've not filled up the first 10 yet.
Edit: with parking brake kit
weekendclimber is offline   Reply With QuoteReply With Quote
Old 04-28-2020, 12:35 PM #22
The only way to know for sure would be to test braking distance before and after install, which I have not done. So I can't give you any factual, tested information.
I don't have any plans to provide a rock shield. I've heard of rocks getting stuck between backing plates and rotors, but never between pads and rotors. Have you had this happen? The pads are just about touching the rotors. That doesn't leave much room for rocks to get between them.
Old 04-28-2020, 12:40 PM #23
Reinout's Avatar
Reinout Reinout is offline
Real Name: Reinout
Reinout will become famous soon enough
Reinout's Avatar
Real Name: Reinout
If only I had money......and a job.
This is great though and it's a boon to the 3rd gen community.
T4R.org as a whole is just a whole different breed of enthusiasts. I'm rather surprised that companies such as Toyota don't get talent (Employees) from these forums.
1988 4Runner SR5- ~250k Miles and counting - 5 Speed
1997 4Runner SR5- ~370k Miles and counting - 5 Speed E-Locker
2007 4Runner Limited V6- 142k Miles - Automatic - Brake Controller
2011 VW JSW TDI- 104k Miles - 6 Speed - Air Lift 1000
2006 Scamp trailer 16'
Reinout is offline   Reply With QuoteReply With Quote
Old 04-28-2020, 12:59 PM #24
Blackdawg's Avatar
Blackdawg Blackdawg is offline
Blackdawg is on a distinguished road
Blackdawg's Avatar
Have you tried it on a 1st gen tacoma yet? Id be interested in a kit with ebrake.
Blackdawg is offline   Reply With QuoteReply With Quote
Old 04-28-2020, 01:13 PM #25
eimkeith's Avatar
eimkeith eimkeith is offline
Official Vendor
eimkeith is just really nice eimkeith is just really nice eimkeith is just really nice eimkeith is just really nice eimkeith is just really nice
Official Vendor
eimkeith's Avatar
I'm getting a kit for my Taco as well. (well, for the Taco axle, which is going under the 1st gen T4R.)
keith
'96 SR5 - 3.4/5spd
check out the stuff I make
eimkeith is offline   Reply With QuoteReply With Quote
Old 04-28-2020, 01:16 PM #26
Blackdawg's Avatar
Blackdawg's Avatar
Cool.
Im in for a kit with Ebrake.
Old 04-28-2020, 01:18 PM #27
Prezioso70 Prezioso70 is offline
Prezioso70 is on a distinguished road
I am in for a set with parking brake.
Prezioso70 is offline   Reply With QuoteReply With Quote
Old 04-28-2020, 01:27 PM #28
rideexileex's Avatar
rideexileex rideexileex is offline
rideexileex will become famous soon enough
REAR DISC BRAKES REQUIRE A PROPORTIONING VALVE!!!
People are going to get in bad accidents without a properly adjusted rear brake system... This should be a required part of the kit IMO.
2000 4Runner Sport - TRD&AEM SuperCharged
SoloLT & KING 2.5 adj-resi & bumps, 4th gen w/ disc brake rear axle & KING 2.5 adj-resi 12's
F+R ARB's & OBA, 4.88 Yukon's, STT Pro, Shrockworks Front, Homemade Rear, BudBuilt-Lil Skip-Lotus Skids & 4xI Sliders
Post Long Travel Sale!!! CVs and a sway bar https://www.toyota-4runner.org/for-s...-arms-etc.html
rideexileex is offline   Reply With QuoteReply With Quote
Old 04-28-2020, 01:37 PM #29
Blackdawg's Avatar
Blackdawg's Avatar
Already have a manual one personally.
But there is the stock one already there as well..least on tacos.
Old 04-28-2020, 01:57 PM #30
This kit will fit a 1st Gen Tacoma axle. Does your Tacoma have ABS?
The parking brake assembly will work also, but it's a bit different for a Tacoma. I have it set up on my 1st Gen Tacoma using a 4Runner parking brake handle mounted between the seats. PM me and we can discuss it more.
I don't disagree with you; however, I'd love to hear what you have to say about running a proportioning valve on an ABS set-up.
My thought is that the ABS gets it's input from the axle shaft rotation and makes adjustments from there. Rear disc brakes don't change how the ABS system gets its input from the rear axle shaft. In my mind, the system will function as designed.
On my 4Runner, I deleted the ABS system and I do run a manual proportioning valve. But I don't think a proportioning valve is a required item for a kit designed to work with ABS.
bracket , brake , caliper , disc , rear
PSA to rear disc brake conversions rideexileex 3rd gen T4Rs 17 12-04-2018 05:39 PM
drum to disc brake conversion Rc4r 3rd gen T4Rs 34 11-18-2018 03:54 AM
All Pro Off Road rear disc conversion kit review pwalsh53 3rd gen T4Rs 9 10-08-2015 04:55 PM
'85 disc brake conversion BLT2CRWL Classic T4Rs 1 09-13-2005 11:41 AM
front brake disc size > rear tcpoob 4th Gen T4Rs 5 08-11-2005 07:22 AM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
