Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Old 08-11-2020, 02:36 AM #211
Kramer03 Kramer03 is offline
Kramer03 is on a distinguished road
Need this kit asap!
How do I place an order for these? How fast can you ship them out?
Kramer03 is offline   Reply With QuoteReply With Quote
Old 08-14-2020, 10:26 AM #212
atcpup's Avatar
atcpup atcpup is offline
atcpup is on a distinguished road
atcpup's Avatar
Ready!!
atcpup is offline   Reply With QuoteReply With Quote
Old 08-14-2020, 10:30 AM #213
midcoma midcoma is offline
midcoma has a spectacular aura about midcoma has a spectacular aura about midcoma has a spectacular aura about
I know some people are trying to get their brakes installed this weekend. I’m still working through instructions and will have at least a very detailed draft posted in the morning. If anyone needs the info sooner, send me a message and I’ll make sure you get the info you need.
midcoma is offline   Reply With QuoteReply With Quote
Old 08-14-2020, 01:01 PM #214
weekendclimber's Avatar
weekendclimber weekendclimber is offline
Real Name: Scott
weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice
Real Name: Scott
Originally Posted by midcoma View Post
Glad you're happy with them. One of the hard lines looks like it was bent in shipping. This section should be straight.
The copper-nickle should be easy to straighten out by hand.
No worries. Brake lines are easy to get straightened.
One thing that maybe we should do, is post up the additional parts needed (ie: calipers, pads, disc, etc.) so we can get a list of parts that function with this kit. There are a lot of options out there, so it would be nice to have an easy list that people can shop with.
Here is what I have:
Calipers: Power Stop #S4824A
Banjo Bolts: BrakeBest H9479-2
Brake Pads: BrakeBest Organic Rear Disc Brake Pads #D627
Brake Discs: BrakeBest Select Brake Rotor #96929RGS
Rear Axle Seals/Bearings: Marlin Crawler #MCAX-241 (vary's by year)
Brake Fluid and Gear Oil of your choice
weekendclimber is offline   Reply With QuoteReply With Quote
Old 08-15-2020, 06:14 AM #215
A link to the installation instructions has been added to the end of post #1.
Old 08-15-2020, 08:52 AM #216
atcpup's Avatar
atcpup's Avatar
Very nice instructions! I know you have an incredible mount of time invested in that document and the whole project. Thank You!
Old 08-17-2020, 02:48 AM #217
Originally Posted by atcpup View Post
Ready!!
Be careful with those PowerStop calipers. I didn't want to wait for the calipers I ordered to come in so I went to a Summit Racing store near me and got those exact same calipers.... they don't come with a banjo bolt so I had to go back to get some. Then the correct size did not want to thread in after getting started. Multiple employees and myself proceeded to go through every pair of those calipers there to find that only one single caliper would accept the banjo bolt. Manufacturers defect was what they ruled. PowerStop did not re-thread those after powder coating them. Don't know if they just had a bad batch or they all are like that. I would check it out before you get invested in the project. It was a headache for me and I am still waiting for my original purchase to come in.
Old 08-17-2020, 03:29 AM #218
[IMG]Rear Disc Brake Conversion Kit[/IMG]
Seriously, Thank you midcoma for taking the time and effort to make this happen! I will post more pictures once it is completed. I am also working on the parking brake kit too. Awesome directions on that, I definitely did not want to guess on the parking brake kit. Don't mind the wheel cylinder hanging around in the photo; I have a long steel braided line that runs from the T to the cylinder so I just plugged it back up with it.
Old 08-17-2020, 12:26 PM #219
You can always buy a bottoming tap and clean the threads up yourself. You shouldn’t have to, but it’s easier to buy them already coated than to get them coated yourself. Pretty sure the banjo is M10x1.0, but verify that before cutting any threads. Use some grease on the tap to catch the shavings and blow the hole out with air to remove the rest.
On a separate note, I just got a call from the shop producing my flex lines. Apparently my guy got in trouble for the last order I placed. His bosses are telling him that he has to charge $45-$50 for each of the flex lines ($90-$100 per pair). So needless to say, I’m back on the search for a shop that can make them at reasonable prices.
Old 08-17-2020, 03:22 PM #220
atcpup's Avatar
atcpup's Avatar
After reading your post I ran out immediately to get the banjo bolts. Mine threaded up nice and easy. For reference, I ordered Powerstop rear calipers for a 1999 Mustang Cobra. The banjo bolt size is M10 x 1.5
Powerstop Rear Calipers and Banjo Bolt part numbers for 1999 Mustang Cobra
Old 08-17-2020, 03:26 PM #221
atcpup's Avatar
atcpup's Avatar
After a bit of research, most 94-98 Cobra calipers are M10-1.0 fine pitch thread (some 99's use this too) Ford went to the M10-1.5 course thread for the later years. Folks are just going to have to check and confirm. This is the problem that I believe kramer03 may have had.
Old 08-17-2020, 04:04 PM #222
@atcpup Those brake lines look great with the calipers!
Old 08-17-2020, 10:32 PM #223
After a bit of research, most 94-98 Cobra calipers are M10-1.0 fine pitch thread (some 99's use this too) Ford went to the M10-1.5 course thread for the later years. Folks are just going to have to check and confirm. This the problem that I believe kramer03 may have had.
That's good information to have. I had the 04' calipers and we tried both the M10x1.5 and the M10x1.0 just to be on the safe side. The M10x1.5 did thread into one lone caliper but none of the other 04' calipers would accept it. We also tried a bunch of other fittings to see if by chance something else would work on the defective ones and got nothing. It was probably just a bad batch that they had from the manufacturer. Just thought I'd share my experience with them so those who decide to use them could check before diving into the project.
Old 08-18-2020, 08:33 AM #224
atcpup's Avatar
atcpup's Avatar
Your info was pure gold. I definitely would have started the project without the banjo bolts and my normal luck would have been to have defective calipers, too. Thanks for sharing, that's what make this forum invaluable!
Old 08-18-2020, 01:05 PM #225
jkoni426 jkoni426 is offline
Real Name: Joe
jkoni426 is on a distinguished road
Real Name: Joe
This is so freakin tempting... curious as to what's been everyone's all in cost on this? Conversion kit, calipers, pads, rotors, everything
'99 T4R SR5 V6 4WD Imperial Jade Mica | 199mm TBU
jkoni426 is offline   Reply With QuoteReply With Quote
bracket , brake , caliper , disc , rear
PSA to rear disc brake conversions rideexileex 3rd gen T4Rs 17 12-04-2018 05:39 PM
drum to disc brake conversion Rc4r 3rd gen T4Rs 34 11-18-2018 03:54 AM
All Pro Off Road rear disc conversion kit review pwalsh53 3rd gen T4Rs 9 10-08-2015 04:55 PM
'85 disc brake conversion BLT2CRWL Classic T4Rs 1 09-13-2005 11:41 AM
front brake disc size > rear tcpoob 4th Gen T4Rs 5 08-11-2005 07:22 AM
