Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Old 04-28-2020, 02:08 PM #31
Blackdawg's Avatar
Blackdawg Blackdawg is offline
Blackdawg is on a distinguished road
Blackdawg's Avatar
Originally Posted by midcoma View Post
This kit will fit a 1st Gen Tacoma axle. Does your Tacoma have ABS? If it does, these brackets will fit fine, if not, I can make brackets without the ABS cut-out. Take a look at the picture of the brackets laid out in the back of my 4Runner. The sets on the right are for non-ABS axle housings.
The parking brake assembly will work also, but it's a bit different for a Tacoma. I have it set up on my 1st Gen Tacoma using a 4Runner parking brake handle mounted between the seats. PM me and we can discuss it more.
I don't disagree with you; however, I'd love to hear what you have to say about running a proportioning valve on an ABS set-up.
My thought is that the ABS gets it's input from the axle shaft rotation and makes adjustments from there. Rear disc brakes don't change how the ABS system gets its input from the rear axle shaft. In my mind, the system will function as designed.
On my 4Runner, I deleted the ABS system and I do run a manual proportioning valve. But I don't think a proportioning valve is a required item for a kit designed to work with ABS.
Truck had ABS but I ripped it out. Still has the sensors in there though. Likely change to a T100 axle in the future anyways. But ABS ones will be fine.
Will send a PM. looking at it I think it'll be easy enough to make the ebrake work.
Blackdawg is offline   Reply With QuoteReply With Quote
Old 04-28-2020, 02:12 PM #32
midcoma midcoma is offline
midcoma has a spectacular aura about midcoma has a spectacular aura about midcoma has a spectacular aura about
Ok, I'll put you down for a set with the ABS cut-out.
midcoma is offline   Reply With QuoteReply With Quote
Old 04-28-2020, 02:39 PM #33
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
The only way to know for sure would be to test braking distance before and after install, which I have not done. So I can't give you any factual, tested information.
I don't have any plans to provide a rock shield. I've heard of rocks getting stuck between backing plates and rotors, but never between pads and rotors. Have you had this happen? The pads are just about touching the rotors. That doesn't leave much room for rocks to get between them.
Actually its rare but yes I had this happen. Not on a 4 runner but Camry and other vehicles. Granted the closer the pads sits the less this likely this can happen. I was just curious.. The rock climbers and heavy off-roading would know if this would be a benefit or not. I know they are on the front for a reason and it could be simply to keep the disc drier as I never thoroughly looked into it. :-)
Old 04-28-2020, 03:08 PM #34
rideexileex's Avatar
rideexileex rideexileex is offline
rideexileex will become famous soon enough
I ripped out the whole ABS actuator too...
On a rig that still has ABS, the ABS computer will still receive the correct signals to detect wheel slip, but now ABS will be kicking in far, far more often for the rear brakes.
Further, the actual brake/ABS pulses will still be of the same strength (ABS system would assume drum brake power) and cause a longer duration of ABS activation. I still think a proportioning valve would benefit by reducing power sent to the now rear disk brakes.
2000 4Runner Sport - TRD&AEM SuperCharged
Solo Long Travel & KING 2.5 & bumps, 4th gen rear axle & KING 2.5 12's
F+R ARB's, 4.88 Yukon's, 295 KM3s
rideexileex is offline   Reply With QuoteReply With Quote
Old 04-28-2020, 03:31 PM #35
RandyBobandy's Avatar
RandyBobandy RandyBobandy is offline
RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice
Really looking forward to this kit, was going to rebuild my drums with new backing plates because mine are rusty but I'd much rather do this conversion and it will likely cost less.
I still have my abs system installed but it doesn't function because I don't have the front sensors hooked up, so I will probably take the opportunity to delete it entirely and install a proportioning valve
Would you recommend installing a residual valve as well to help with the issue of rotor runout pushing the piston back into the caliper and causing a soft pedal? and for anyone who has a residual valve, would you just attach it at the T fitting for the rear brake lines?
RandyBobandy is offline   Reply With QuoteReply With Quote
Old 04-28-2020, 04:57 PM #36
Hopkins Hopkins is offline
Hopkins is on a distinguished road
I’m in for a kit and parking brake assembly
Hopkins is offline   Reply With QuoteReply With Quote
Old 04-28-2020, 05:00 PM #37
ACE115 ACE115 is offline
ACE115 is on a distinguished road
Sign me up for a kit with an E-Brake set up as well please.
ACE115 is offline   Reply With QuoteReply With Quote
Old 04-28-2020, 09:16 PM #38
Team_Jake's Avatar
Team_Jake Team_Jake is offline
Team_Jake is just really nice Team_Jake is just really nice Team_Jake is just really nice Team_Jake is just really nice
Team_Jake's Avatar
Sub'd.
I'm not quite ready for this yet, but I'll be watching closely in the meantime.
1999 4Runner Limited - 5VZ, 4wd, Factory E-Locker, Multi-Mode, 5-speed swap, Armored, Icons, 295s (thread)
2001 Tacoma Xtracab - 3RZ, 4wd, 5-speed (Daily Driver)
Team_Jake is offline   Reply With QuoteReply With Quote
Old 04-28-2020, 09:40 PM #39
Chuckles89's Avatar
Chuckles89 Chuckles89 is offline
Real Name: Charlie
Chuckles89 has a spectacular aura about Chuckles89 has a spectacular aura about Chuckles89 has a spectacular aura about
Chuckles89's Avatar
Real Name: Charlie
I am interested in seeing how much the parking brake kit will cost after you figure it out... I will probably buy both the brackets and the cable kit if reasonable. Subscribed!
Originally Posted by STX4Runner View Post
90% of the build threads in the 5th Gen section consist of Fuel Wheels, Plastidip, Duratracs and window tint.
1998 4Runner "Diamond" - Daily Driver (rolled & rebuilt) - 3.4 5-Speed, Coastal Bumper, Manual Hubs, 255/80r17 AT3Ws (409k+ Miles)
1997 4Runner "Becky" - Camping Rig - 3.4 Auto (for now), Armored, Cable E-Locked, Coastal Bumper, Sleeper Deck, 255/80r17 AT3Ws (185k+ Miles)
1989 4Runner | Tennessee 4Runner Group
Chuckles89 is offline   Reply With QuoteReply With Quote
Old 04-29-2020, 05:39 AM #40
Rcastle's Avatar
Rcastle Rcastle is offline
Real Name: Richard Castle
Rcastle is on a distinguished road
Rcastle's Avatar
I already have the disc brake setup on mine but am definitely interested in the parking brake cable kit if I can get it seperate.
Good job, this looks like a solid kit.
1999 4Runner Highlander Edition S/C
It gets me around... everywhere.
Rcastle is offline   Reply With QuoteReply With Quote
Old 04-29-2020, 09:59 AM #41
theesotericone's Avatar
theesotericone theesotericone is offline
theesotericone is just really nice theesotericone is just really nice theesotericone is just really nice theesotericone is just really nice
@midcoma
Just found out I'm going back to work on the 4th. I also did the research and Powerstop makes the calipers. I've had great results with their front TBU calipers so I'll use those. If there's still a kit left I'll take one. I'll also take the parking brake kit to hold me over until I can get the t-case lock. Shoot me a PM about what you have left from your t-case lock set-up when you get time and maybe I'll grab that from you as well. Thanks for getting the plates together for this.
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. --Albert Einstein
theesotericone is offline   Reply With QuoteReply With Quote
Old 04-29-2020, 04:24 PM #42
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
I've been working on this project for a few years and finally had some time to get serious about it. The design is complete and fabrication is in progress.
I know you and I have corresponded about this setup in the past. Looks like you have done a terrific job. as always your work is top notch.
I put this vid togeather that shows my setup. the one issue I'm having with the ebrake setup... well I will let the vid do the talking. wondering if you can lock up the rears with the cable setup your running?
Old 04-29-2020, 09:08 PM #43
Twan's Avatar
Twan Twan is offline
Twan will become famous soon enough Twan will become famous soon enough
Twan's Avatar
I'm definitely interested in a setup with the parking brake.
2000 SR5 Sport - 4EAT and E-locker, King 2.5s, EimKeith PCK, SPC UCAs, 33" KO2s on Black Rhino Boxer gloss gold 17x8.5, Savage/Lotus skids, 4xInnovations front bumper/sliders, Shrockworks bumper & tire carrier, Lil Skip Gas Tank Skid, Magnaflow Overland cat back
Twan is offline   Reply With QuoteReply With Quote
Old 04-29-2020, 11:04 PM #44
AntonioCm1983's Avatar
AntonioCm1983 AntonioCm1983 is offline
Real Name: Antonio Claudio Michael
AntonioCm1983 is on a distinguished road
I'm totally in for the conversion kit as well as the emergency brake kit as well this will be a welcoming site to a 20 year old 2000 4runner
AntonioCm1983 is offline   Reply With QuoteReply With Quote
Old 04-30-2020, 12:31 AM #45
itskmill06 itskmill06 is offline
itskmill06 is on a distinguished road
I’m Interested in a setup including parking brake! If there’s still room on the list 😂
itskmill06 is offline   Reply With QuoteReply With Quote
bracket , brake , caliper , disc , rear
PSA to rear disc brake conversions rideexileex 3rd gen T4Rs 17 12-04-2018 05:39 PM
drum to disc brake conversion Rc4r 3rd gen T4Rs 34 11-18-2018 03:54 AM
All Pro Off Road rear disc conversion kit review pwalsh53 3rd gen T4Rs 9 10-08-2015 04:55 PM
'85 disc brake conversion BLT2CRWL Classic T4Rs 1 09-13-2005 11:41 AM
front brake disc size > rear tcpoob 4th Gen T4Rs 5 08-11-2005 07:22 AM
