Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Old 04-30-2020, 01:03 AM #46
PandaRescue89's Avatar
PandaRescue89 PandaRescue89 is offline
PandaRescue89 is on a distinguished road
First post. Long time lurker.
Would this bracket still leave room for the full float conversion kits?
Also how many runs of these do you plan to do?
If this is your only one, go ahead and throw my name in there with the parking brake kit if you will make more than 10 on this run, otherwise ill be on the wait list and tell me where to send my monies!!
-Dirty hands
PandaRescue89 is offline   Reply With QuoteReply With Quote
Old 04-30-2020, 03:37 AM #47
midcoma midcoma is offline
midcoma has a spectacular aura about midcoma has a spectacular aura about midcoma has a spectacular aura about
Originally Posted by rideexileex View Post
On a rig that still has ABS, the ABS computer will still receive the correct signals to detect wheel slip, but now ABS will be kicking in far, far more often for the rear brakes.
Further, the actual brake/ABS pulses will still be of the same strength (ABS system would assume drum brake power) and cause a longer duration of ABS activation. I still think a proportioning valve would benefit by reducing power sent to the now rear disk brakes.
ABS is a continuous feedback system. So if the pulse strength and/or duration causes lock-up, it will still receive that signal and adjust for it accordingly. Maybe I'm giving the system more credit than it deserves. It's good to hear in sleepydad's post that his ABS works properly.
I'm still not saying a proportioning valve wouldn't be beneficial, just not convinced it's necessary with ABS. If you remove the ABS, absolutely run a proportioning valve.
How would you adjust the valve with ABS? I would think the system would prevent you from being able to get the response required to adjust it properly.
Originally Posted by RandyBobandy View Post
Would you recommend installing a residual valve as well to help with the issue of rotor runout pushing the piston back into the caliper and causing a soft pedal? and for anyone who has a residual valve, would you just attach it at the T fitting for the rear brake lines?
I haven't used a residual valve, but I think it would only help.
According to Wilwood, the residual valve should be installed as close to the master cylinder as possible. 2lb valves are standard for disc brake systems, but Wilwood also has a 4lb valve for "disc brake systems where extreme shock loads, hard vibration, and suspension component flex can contribute to excessive caliper piston retraction and pad knock back."
Info here.
Originally Posted by sleepydad View Post
Wondering if you can lock up the rears with the cable setup your running?
I've never tried. I only use the parking brake as a parking brake. I kind of doubt it though, the handle requires a decent effort to lift. At what speed were you applying the brake in your video?
I don't think this kit would work with a full float conversion, but I don't know for sure. It hasn't been tested with one.
Based on the interest so far, it looks like I'll be doing more runs than expected.
midcoma is offline   Reply With QuoteReply With Quote
Old 04-30-2020, 03:46 AM #48
@powerman83 @RandyBobandy @2TH4IST @zacattack20 @weekendclimber @Prezioso70 @Blackdawg @MattJakobs @ACE115 @eimkeith @theesotericone @Twan @AntonioCm1983 @itskmill06 @PandaRescue89 @rexassian @Rcastle
The interest in a parking brake kit has been pretty overwhelming so I'm trying to get this going ASAP. I added information for a parking brake kit to the original post. Please review it and let me know if you're interested. I plan to start ordering parts soon to get these together. My intention is to get the kits ready to ship with the brackets so you have everything you need for a complete install in one shipment.
Old 04-30-2020, 03:51 AM #49
Quick Update
The brackets are on their way to the electroplating shop. I'm hoping for a quick turn around.
Due to there being more interest than I expected, I placed an order today for another run of brackets. So if you didn't make it into the first 10 you shouldn't have to wait too long to get a set.
Old 04-30-2020, 04:13 AM #50
Hopkins Hopkins is offline
Hopkins is on a distinguished road
You must have missed my post earlier in thread.....but add me in for a kit and parking brake kit thanks
Hopkins is offline   Reply With QuoteReply With Quote
Old 04-30-2020, 04:21 AM #51
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
I’m thinking the ABS system in these just pulses the fluid pressure in the system if it detects a wheel stopping out of sync with the others.
So I can’t see how it could be expected to resolve an imbalanced system.
If the system too easily locks up the rear tires, for instance on wet pavement, then the ABS will pulse all the brakes and your stoping distance will suffer. You’ll loose the braking power and traction of the front wheels if you lock up the rear wheels.
At least that’s my understanding of these ABS systems. They don’t appear to deal with individual wheels or axles like newer systems.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 04-30-2020, 07:07 AM #52
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
I have a very similar setup with these same calipers. I have driven with this setup in 2 winters and the ABS works fine in snow and ice. Where I live we get everything from ice storms to regular snow.
I have also tested it doing emergency stops on dry pavement and it functions just like the drums and the ABS pulse still happen.
If your ABS works now this setup should continue to work.
Old 04-30-2020, 08:37 AM #53
weekendclimber's Avatar
weekendclimber weekendclimber is offline
Real Name: Scott
weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice
Real Name: Scott
Still in!! TAKE MY MONEY!!
weekendclimber is offline   Reply With QuoteReply With Quote
Old 04-30-2020, 10:38 AM #54
I think you're right. I added you to the list in the right order. Thanks for catching this and pointing it out.
Old 04-30-2020, 10:52 AM #55
2TH4IST's Avatar
2TH4IST 2TH4IST is offline
2TH4IST has a spectacular aura about 2TH4IST has a spectacular aura about 2TH4IST has a spectacular aura about
2TH4IST's Avatar
@midcoma - yes still count me in for the parking brake and adapter brackets.
There's danger lurking around every corner, that's why I propose we make all of our buildings round.
I don't remember the time I was human that's why I don't understand anybody.
2TH4IST is offline   Reply With QuoteReply With Quote
Old 04-30-2020, 12:08 PM #56
I’m not saying the ABS wouldn’t activate. I’m saying it may be overactive.
Good to hear your setup works good.
What was your stopping distances pre and post the conversion? Did you see meaningful improvement?
Old 04-30-2020, 12:38 PM #57
If anyone in the Hampton Roads, VA area is interested in a kit, I can help with the install and we can do a before/after stopping distance test to try and get some real world performance info.
Thinking about this more, anyone from Eastern NC also. The best place to do this would be at NCCAR. I could talk to the track manager and see if I'd be able to set up track time for testing. Test the 4Runner stock, install the kit in their garage, then test with the rear discs.
Old 04-30-2020, 12:39 PM #58
Everyone should note that generally, disc brakes need MORE line pressure for the same braking force application. That is all variable with piston sizes, drum/rotor diameters, brake pad/shoe material, etc... The advantage of disc is linear application, better pedal feel, better heat dissipation, etc.
Early brakes were drum brakes because they required less force to get the required stopping power (pre vacuum assist)...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 04-30-2020, 12:58 PM #59
rideexileex's Avatar
rideexileex rideexileex is offline
rideexileex will become famous soon enough
That's exactly what I'm saying - but ABS on these rigs in my mind and experience is a death trap. Too many times I have tried to stop and ABS wouldn't allow it.... Snow, ice, mud, gravel, sand, slopes, etc. Like others have said in the past, I think the ABS on these trucks works for pavement only.
2000 4Runner Sport - TRD&AEM SuperCharged
Solo Long Travel & KING 2.5 & bumps, 4th gen rear axle & KING 2.5 12's
F+R ARB's, 4.88 Yukon's, 295 KM3s
rideexileex is offline   Reply With QuoteReply With Quote
Old 04-30-2020, 01:16 PM #60
rexassian rexassian is offline
rexassian is on a distinguished road
@midcoma I'm definitely still in for the parking brake kit. Thanks!
1999 SR5 V6 manual trans 4x4 - Lifted on 35's - Build thread
rexassian is offline   Reply With QuoteReply With Quote
bracket , brake , caliper , disc , rear
PSA to rear disc brake conversions rideexileex 3rd gen T4Rs 17 12-04-2018 05:39 PM
drum to disc brake conversion Rc4r 3rd gen T4Rs 34 11-18-2018 03:54 AM
All Pro Off Road rear disc conversion kit review pwalsh53 3rd gen T4Rs 9 10-08-2015 04:55 PM
'85 disc brake conversion BLT2CRWL Classic T4Rs 1 09-13-2005 11:41 AM
front brake disc size > rear tcpoob 4th Gen T4Rs 5 08-11-2005 07:22 AM
