Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Old 04-27-2020, 11:50 PM #1
midcoma midcoma is offline
midcoma has a spectacular aura about midcoma has a spectacular aura about midcoma has a spectacular aura about
Rear Disc Brake Conversion Kit
***ALL DISC BRAKE CONVERSION KITS ARE SOLD AND PRODUCTION IS ON HOLD UNTIL FURTHER NOTICE***
More details provided in post #380 for those interested.
Disc Brake Conversion Kit:
This is a bolt on kit to replace the rear drum brakes with disc brakes.
What's included:
- Conversion brackets & spacers (1 pair for 1 axle).
- All hardware to mount the bracket to the axle and the caliper to the bracket.
What's required:(details below)
- '94-'04 Mustang Cobra rear calipers & caliper mounting bracket.
- '94-'04 Mustang Cobra rear brake pads.
- 2003-present 4Runner rear rotors.
CAD Images:
The Brackets:
The brackets are laser cut from 3/8" A36 steel. The spacers are also laser cut from A36 steel to match the brackets. Both the brackets and spacers are Zinc Yellow-Chromate plated to prevent corrosion.
The brackets are designed to fit the factory 4Runner axle housing with ABS.
The spacers are required to get the proper offset for the caliper mounting bracket. They allow the rotor to fit properly in the caliper mounting bracket.
Parking Brake Kit:
I completely re-worked my junction bracket to increase the force applied to the caliper. Instead of using off the shelf parts that I used in the first version on my 4Runner, I designed new parts and had them fabricated to provide the best mechanical advantage in the space available. The junction bracket now incorporates a lever and pulley to increase the mechanical advantage over the 1:1 ratio of version 1. The 4Runner parking brake cable enters the junction bracket through the aluminum fitting in the front, loops around the pulley, and ends by securing to the zinc-yellow fitting.
The kit includes everything required to connect the parking brake in a way that I'm comfortable having my name associated with. Here's an example of what is included.
- (2) brake cables for the Mustang calipers.
- Factory clips to secure the cable on the caliper.
- Junction bracket for the cables.
- Fittings to adapt the factory cable to work with the junction bracket.
- All necessary hardware (all 18-8 stainless steel).
- Spare rivet nuts, just in case you need them. Or if you haven't used them before and need to experiment before installing on your 4Runner. The correct size drill bit for the rivet nuts is also included.
Brake Line Kit:
These brake lines replace all the brake lines on the rear axle. The copper-nickel lines replace the hard lines from the axle mounted "T" to the outside of the axle. They mount using the factory tabs. The stainless steel braided flex lines connect the copper-nickel hard lines to the caliper.
The year must be specified for the brake line kit due to the changes in the ABS system. There are two different sets of hard lines, one for '96-'00 and one for '01-'02.
Installation Instructions:
Click here.
weekendclimber's video install:
*****These brackets have not been tested/approved by the DOT and are recommended for off-road use only*****
midcoma is offline   Reply With QuoteReply With Quote
Old 04-27-2020, 11:51 PM #2
What's Required
Calipers:
- '94-'04 Mustang Cobra rear calipers.
The Cobra part is important. The difference is in the caliper mounting bracket. The rear caliper itself is the same for all '94-'04 Mustangs. The Cobra came with a thicker, vented rotor. The caliper mounting bracket was different to allow more room for this thicker rotor. The 4Runner rear rotor is also vented. It needs the wider gap in the Cobra bracket to fit properly.
The easiest way to tell if you have the correct caliper mounting bracket is to look and see if the outside of the bracket is connected. If it is, you're good to go. You would think this is easy, but even the auto part manufacturers mess it up. I've purchased part #14-1042 from Cardone, BrakeBest, and Wearever. All of them have gotten it wrong. That is the part number for the correct caliper mounting bracket. Always open the box and look at the mounting bracket before you leave the store. It's about a 50-50 chance if the properly labeled box has the right part in it or not.
These are not my images, but they show the difference in the two brackets.
Brake Pads:
If you want to make life easy, go with brake pads for a '94-'04 Mustang Cobra. The pad is slightly thinner to account for the thicker rotor. As mentioned, the caliper is the same. So in order to fit a thicker rotor in the same amount of space, the pads are thinner.
You can make pads from a non-Cobra work, but they will either be pretty tight until the get worn down or you will have to run them without backing plates/pads until they wear down a bit. They are much more difficult to fit and assemble than Cobra pads.
Rotors:
- '03-current 4Runner rear rotors.
When used with the Cobra caliper mounting bracket, these rotors fit great. The best thing about them is that they are a Toyota part and they don't need to be modified. The Montero rotors that have been used in the past have interference issues with the Toyota lug studs and the back of the rotor hat needs to be countersunk to correct the issue. This is not an issue with the newer 4Runner rotors. Everything fits without modification.
Old 04-27-2020, 11:52 PM #3
Brake Kit Background
I've been running version 1 of this conversion since 28JUN17. It was installed on my 4Runner when it was at 233,910 miles. It now has over 279K miles, so over 45k miles on the kit so far. I used the lessons I learned from my first kit to develop these brackets and I'll be upgrading to a set as soon as they're finished. The biggest thing I learned was the difference between the Cobra caliper mounting bracket and the others. My first set of brackets used the non-Cobra mounting brackets and it caused the tolerances to be very tight.
Here's a few pictures of the version 1 brackets after install.
You can see in this picture that it's the wrong caliper mounting bracket.
In this picture you can see how tight of a fit it is between the caliper mounting bracket and the rotor.
On 15JUL18, I finally got around to connecting the parking brake. I'm sourcing the parts now to be able to offer this as a kit for those interested.
Old 04-27-2020, 11:53 PM #4
Status Update
Picked up the first run of brackets from the shop today.
Test fitting:
Picture from inside with the caliper mounting bracket in place.
Caliper mounting bracket, spacer, conversion bracket.
Rotor and caliper mounting bracket.
With brake pads.
Now I have a 64lb box packed and ready to go to the shop for plating. How to make friends with USPS employees
Old 04-28-2020, 12:51 AM #5
theesotericone's Avatar
theesotericone theesotericone is offline
theesotericone is just really nice theesotericone is just really nice theesotericone is just really nice theesotericone is just really nice
What years work for the Mustang calipers? This kit, a line lock, and a t-case brake are probably in my future.
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. --Albert Einstein
theesotericone is offline   Reply With QuoteReply With Quote
Old 04-28-2020, 01:59 AM #6
Details added above.
I recommend against a t-case brake. I ran one on my Tacoma for a while and it was a pain. Getting it set up was difficult and part availability was another problem. I can provide the parts to connect the parking brake of the Mustang calipers to the factory hand brake. I've been running that on my 4Runner for a while and it's much nicer than the t-case brake was on the Tacoma.
Old 04-28-2020, 07:52 AM #7
VernySanders's Avatar
VernySanders VernySanders is offline
Real Name: Werner
VernySanders will become famous soon enough VernySanders will become famous soon enough
Real Name: Werner
First and foremost, I applaud your work, and I appreciate it. Two questions, how smaller are these calipers than the tundra calipers? It would drive my OCD nuts if I knew I had little baby rotors on the rear of the rig. Second question is isnt drum brakes better for off road? Thats the excuse toyota uses to still put factory drums on all new off road vehicles today.
The dunes got boring because I couldn't jump. I'm not the type to enjoy someone else's vehicle. So i'm in the process of making making the dunes no longer boring. I guess that involves jumping.... A lot.
VernySanders is offline   Reply With QuoteReply With Quote
Old 04-28-2020, 08:18 AM #8
eimkeith's Avatar
eimkeith eimkeith is offline
Official Vendor
eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light
Official Vendor
eimkeith's Avatar
I'm in, and in for the parking brake kit as well.
keith
eimkeith.com
all product descriptions © eimkeith LLC 2016-2023
eimkeith is offline   Reply With QuoteReply With Quote
Old 04-28-2020, 08:37 AM #9
powerman83 powerman83 is offline
powerman83 is on a distinguished road
I'm in also , and in for the parking brake kit as well.
powerman83 is offline   Reply With QuoteReply With Quote
Old 04-28-2020, 08:56 AM #10
RandyBobandy's Avatar
RandyBobandy RandyBobandy is offline
RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice
I’m in for a kit and parking brake assembly
One question, do you need to upgrade the master cylinder for this kit? I have 199mm tundra brakes on the front
RandyBobandy is offline   Reply With QuoteReply With Quote
Old 04-28-2020, 09:28 AM #11
eimkeith's Avatar
Official Vendor
Official Vendor
eimkeith's Avatar
This bracket, right?
keith
eimkeith.com
Old 04-28-2020, 09:46 AM #12
I appreciate the first hand knowledge of the t-case brake but I've done the research. It's what I'll go with. The less crap I have hanging off the rear axle the better for how I wheel my rig. I'm still debating if I really even need a line lock. I do really want one though. Having the ability to lock one rear tire and pivot off it would be almost as good as front digs. lol
Old 04-28-2020, 10:07 AM #13
2TH4IST's Avatar
2TH4IST 2TH4IST is online now
2TH4IST has a spectacular aura about 2TH4IST has a spectacular aura about 2TH4IST has a spectacular aura about
2TH4IST's Avatar
I'm in as well! Also interested in the parking brake kit too. Can't wait for this!
There's danger lurking around every corner, that's why I propose we make all of our buildings round.
I don't remember the time I was human that's why I don't understand anybody.
2TH4IST is online now   Reply With QuoteReply With Quote
Old 04-28-2020, 11:33 AM #14
rexassian rexassian is offline
rexassian is on a distinguished road
For sure interested in the parking brake kit if you would consider selling that separately. But I have a question about the cable routing, would going down from the frame to the control arm and under the axle tube limit suspension travel? Thanks
1999 SR5 V6 manual trans 4x4 - Lifted on 35's - Build thread
rexassian is offline   Reply With QuoteReply With Quote
Old 04-28-2020, 11:38 AM #15
zacattack20's Avatar
zacattack20 zacattack20 is offline
zacattack20 will become famous soon enough
I want it. Take my money. I’m in for the parking brake too.
'98 SR5 Converted to '01-'02 Sport Edition
Matte Blue Vinyl Wrap - Black Interior - Too Many Mods
Build Thread
Instagram: 98trd4r
zacattack20 is offline   Reply With QuoteReply With Quote
bracket , brake , caliper , disc , rear
PSA to rear disc brake conversions rideexileex 3rd gen T4Rs 17 12-04-2018 05:39 PM
drum to disc brake conversion Rc4r 3rd gen T4Rs 34 11-18-2018 03:54 AM
All Pro Off Road rear disc conversion kit review pwalsh53 3rd gen T4Rs 9 10-08-2015 04:55 PM
'85 disc brake conversion BLT2CRWL Classic T4Rs 1 09-13-2005 11:41 AM
front brake disc size > rear tcpoob 4th Gen T4Rs 5 08-11-2005 07:22 AM
