Here is a photo of some info on the 2 sizes I talked about as well as the post on here about it info below
I believe that only the Sport models had the 338mm rotors. The 319mm rotors should have a 13WG or 13WL marking on the calipers while the 338mm rotors have a 13WH marking on the calipers. Here's the rotor diameter as indicated by the markings on the calipers:
13WH- 13.3"/338mm rotor diameter
13WL- 12.6"/319mm rotor diameter
13WG- 12.6"/319mm rotor diameter
This thread may also help:
How To: Upgrading to Sport Brakes (319 to 338mm)
Originally Posted by Bad Luck
You need 4th gen rear rotors. Says so in the 1st post here. The rears only came in one size as far as I know. 312 mm if I remember correctly.
