Old 04-28-2020, 05:46 PM #1
906-Runner's Avatar
906-Runner 906-Runner is offline
Real Name: Blayne
906-Runner is on a distinguished road
906-Runner's Avatar
Real Name: Blayne
Ignition Problem
First off of this has been discussed please point me to the correct thread, I’ve been searching but I can’t find anything that is close to the same problem. My 4Runner was driving fine until I pulled it into my shop and took the fender flares off. They were broken already so I didn’t do it very gently, I just literally just ripped them all off.
Once I got done I went to pull it out and it won’t start, only cranks over. Scanners telling me the ignition is not reading the key, would tearing the fender flares off have triggered the anti theft system hence it not starting? If so is there a way I can fix it without having to go to a dealer?
-Blayne
1999 4Runner SR5 V6 4x4
2000 4Runner SR5 V6 5-speed E-locker 4x4
906-Runner is offline   Reply With QuoteReply With Quote
Old 04-28-2020, 07:10 PM #2
There's nothing related to the fenders (or flares) that should have any effect on the ECU. Your truck is listed as an SR5, which is unlikely to have the immobilizer system anyway... so that wouldn't be causing a problem.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 04-29-2020, 12:19 AM #3
906-Runner's Avatar
Real Name: Blayne
906-Runner's Avatar
Real Name: Blayne
Well it does have the Toyota Security light, so I’m not sure if that means it has the immobilizer or not. If that’s not the problem, could it be the ignition has gone bad and needs to be replaced? Would getting a new key cut to the VIN make it start?
-Blayne
Old 04-29-2020, 01:20 PM #4
For your year, "security' light in a button cutout (left of steering wheel) is the RS3200 security system, not the immobilizer. The immobilizer is the LED in the center console, next to the passenger seatbelt warning light. You can have either/both depending on options and they do different things.
If the key is working to turn the ignition cylinder, you don't need a new key cut. I'd suspect something else is going on, but I'm not sure what yet.
Old 04-29-2020, 06:07 PM #5
906-Runner's Avatar
Real Name: Blayne
906-Runner's Avatar
Real Name: Blayne
I’ve not seen an LED by the seatbelt light so I’ll guess I don’t have that. Another thing I just realized is I don’t have any of the original keys, I got the truck with one valet key and had new keys cut from that. Would having an original key anything different?
-Blayne
Old 04-29-2020, 06:40 PM #6
If you had new keys cut and they weren't programmed to the truck you *definitely* don't have the factory immobilizer. The non-immobilizer trucks came with three keys - a plastic-headed master, an all-metal master and an all metal valet key. If the key can lock the glove box, you have a master key, even if it is all metal.
Once again though, if the key turns the ignition cylinder and the starter spins, the key is not the issue.
Old 04-29-2020, 06:57 PM #7
sudokukami sudokukami is offline
sudokukami is on a distinguished road
Have you tried checking for other obvious things? Fuel pump, fuses, spark, crankshaft position sensor, etc?
sudokukami is offline   Reply With QuoteReply With Quote
Old 05-04-2020, 05:25 PM #8
906-Runner's Avatar
Real Name: Blayne
906-Runner's Avatar
Real Name: Blayne
I’ve eliminated spark and fuel as the problem, how does one determine if the crank position sensor is bad?
-Blayne
Old 05-04-2020, 06:29 PM #9
HiLife HiLife is offline
If you got spark, most likely your crank sensor isn't the problem.
fender , flares , ignition , i’ve , problem
Ignition/key problem wslytoy 3rd gen T4Rs 6 05-04-2018 12:55 PM
ignition coil problem sparky275 4th Gen T4Rs 2 11-26-2014 01:25 AM
'92 ignition/glow problem nosepeg Classic T4Rs 0 05-12-2009 04:36 PM
Ignition Problem crdean1 3rd gen T4Rs 0 02-28-2008 04:40 PM
Ignition Problem mball73 Problems & Warranty Issues 9 10-06-2004 02:45 PM
