04-29-2020, 12:36 AM
What oil do you use?
I use whatever 5W-30 SAE brand the Toyota stealership uses. Have never had a problem with oil leaks.
'98 4Runner Ltd 4WD.
A Ford might get you from point A to point B. But a Toyota will always get you home.
04-29-2020, 12:58 AM
I just got mine last week and will be changing the oil with Pennzoil Ultra Platinum 5W-30 and a Fram Ultra oil filter.
04-29-2020, 01:59 AM
Real Name: Keith
Real Name: Keith
5w-40.
04-29-2020, 05:05 AM
10W-40 NAPA. 2005 SR5 150,000 miles - is in Bahamas (temps range from 60F to 100F year round)
04-29-2020, 09:03 AM
bobistheoilguy.com
04-29-2020, 09:15 AM
Real Name: Justin
Real Name: Justin
Just started using Amazon Basics 5W-30.
1999 Toyota 4Runner Limited
04-29-2020, 09:18 AM
Originally Posted by JZiggy
bobistheoilguy.com
Interesting read. Thanks for that!
To answer OP, I have been using Mobil 1 synthetic 5w30.
99 Limited: 4wd conversion, OME 883/891, Built Right UCAs, Armored and winch up front, 285's with 4.88s and dual locked.
04-29-2020, 11:29 AM
6 Qts: 5w30 SuperTech full synthetic high milage + 1 Qt: Marvel Mystery Oil + Mobil1 M1-301 oil filter = Oil change
'96 Toyota 4Runner Limited 4x4, Supercharged
04-29-2020, 11:34 AM
Real Name: Jerod
Real Name: Jerod
5W-30 Amsoil signature oil. 10,000 mile change interval.
Flame me.
04-29-2020, 11:37 AM
7 quarts?
04-29-2020, 11:38 AM
7 qts? Odd
I use Mobile 1 synthetic 5W30 or 10w30, whatever’s cheaper. If both the same then 10w30. Change it every 3000-3500.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Real Name: Tim
Real Name: Tim
This is what I switched to for my two 3rd Gens.
Castrol EDGE Extended Performance 5W-30 Advanced Full Synthetic Motor Oil
https://amzn.to/2QIp00L
04-29-2020, 11:51 AM
Originally Posted by thennen
7 quarts?
More capacity due to remote filter mount and extra large M1-301 oil filter
04-29-2020, 12:40 PM
Ah, I see. More oil can't hurt.
