Old 05-04-2020, 03:40 PM #16
JohnMc JohnMc is offline
JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all
I've pondered a dual battery setup on mine as well. After seeing the packaging issues with two full sized batteries in my wife's '96 (a red and a yellow Optima) I was pondering doing something similar for mine - a full sized deep cycle in the stock position for the house battery, and a cute little AGM stuck wherever it is easy for the start battery. And an automatic isolator to keep them from doing weird things like overcharging.
JohnMc is offline   Reply With QuoteReply With Quote
Old 05-04-2020, 03:42 PM #17
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
Originally Posted by TonyB66 View Post
Find a way to dual charge it via engine and solar and I'd be all set... Since that battery should be dead, I'm going to remove it from the MINI and use it for mock-up purposes. Thanks for chiming-in....
Interesting thought there.
You could use an ignition switched relay to connect the second battery when the engine is running (standard procedure here). You could use a second relay wired as normally closed that would open with the same ignition source and disconnect your solar while the engine is running. Should be easy, although I am not positive that there would be any need to disconnect the solar at all...
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 05-04-2020, 04:44 PM #18
TonyB66's Avatar
TonyB66 TonyB66 is offline
Real Name: Tony (no surprise)
TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light
TonyB66's Avatar
Appreciate the thoughts. I'll likely draw-up something, if the fitment is doable. That said, I crawled through the MINI to find the battery...
It's about 6x3x6 alright...
Registered .16 volts, dead alright. I'll remove that rear panel at some point soon and see what's possible...
EDIT/ADD: This battery, the ETX14 is less than 80 bucks:
Amazon.com: Deka Sports Power ETX14 Battery: Automotive
12 Ah, which looks to be fine for my application, a fridge that averages 1Ah on DC. It's job would be to get through the night, until I'm back on solar or driving...
2000 Limited, E-locker
Maintenance/Build Thread
TonyB66 is offline   Reply With QuoteReply With Quote
Old 05-05-2020, 07:40 AM #19
tx_shooter's Avatar
tx_shooter tx_shooter is offline
tx_shooter will become famous soon enough
tx_shooter's Avatar
Those specs line up with a battery my motorcycle uses. I ran a motorcycle battery for a few years as my 2nd/ house battery without any issues. It did get my Dometic fridge through the night in cooler weather without any issues. Trips during the summer did not fare as well.
As for my 2nd battery; here is a quick pic for everyone. I came home from Death Valley right as the covid lockdown started so I have not had a chance to really go through my rig and get it back in proper shape. I need to get after that.
tx_shooter is offline   Reply With QuoteReply With Quote
battery , bigger , full , size , starting
Starting Problem, Battery Good! Pauly67 3rd gen T4Rs 12 06-21-2020 03:09 PM
Battery questions. What size wire for battery? 2 gauge enough? e60ral 5th gen T4Rs 9 03-12-2017 12:29 PM
Starting/Battery Cable Issues walkerwl Maintenance/Detailing 1 11-11-2014 03:16 PM
Wiring battery in "aux" position to be starting battery... joneseyyy 5th gen T4Rs 6 06-09-2013 11:10 PM
Video of starting/battery problem???? hdoggie24 3rd gen T4Rs 2 09-20-2011 01:19 AM
