04-04-2018, 05:31 PM
Pre/Post 1/99 head gasket differences
I'm attempting to order a R side passenger head gasket for a 3.4L. My problem is that there are two different part numbers depending on if the motor was from a vehicle before or after 1/99. The last 7 digits stamped on the block do not match the T4R that it was pulled from, so I'm not sure that I can find out what year this motor is from. What differences are there in the block/head that would warrant the use of a different head gasket?
Pre 1/99 R head gasket: 11115-62071
From 1/99 R head gasket: 11115-62081
☆Floor Mats
04-04-2018, 06:54 PM
Out of curiosity, could that be because Toyota improved the head gasket design?
2000 Limited V6 4WD | Factory Locker | 2nd Gen SC | NGK Spark Plug Wires | AEM Boost/AFM Gauges | Scangauge II | Sonoran Steel 1.2 Lift/Washer Reservoir | AirLift Rear Airbags/Wireless Compressor | 4XInnovations Front/Rear Bumpers | Schrockworks Skid Plates/Sliders | Warn 12k LBS Winch-Synline | LED Halo Driving Lights | LED "Satoshi Cover" Lightbar | Thermal IR Cam | BFG All-Terrain KO2 | Kenwood with Sirius/Garmin Nav and Surround-View Cam | Heated Seats | Lumbar Support | Blacked out Emblems TRD Badge | Rear Diff Breather Extension | LED Taillights | LED 6k Headlights | 120V Power Socket | Flipped Hood and Fuel Release | Rear Window Switch in Cargo Area | Custom FlipBlade Key | Warm White LEDs
04-04-2018, 08:05 PM
If that were the case, I'd imagine that the newer gasket (and part number) would replace the older one (as you can see with other parts), but it's not showing as a replacement in this case.
☆Floor Mats
04-05-2018, 02:01 PM
bump
☆Floor Mats
04-05-2018, 02:39 PM
It seems to me that if only the gasket changed part numbers, and neither the head nor the block changed numbers, then that gasket is an improved version and would thus retrofit older engines.
Occam's Razor, etc.
04-05-2018, 03:15 PM
You'll want the newer head gasket. The early ones were composite, the newer ones are MLS.
'96 SR5, 5spd, Sparco front seats, updated sound system, building new SC'd engine. Build Thread
04-05-2018, 03:36 PM
Checked at the dealer and only the newer headgaskets (from 1/99 onward) had an update in part number. The older ones didn't change from the original. They unfortunately didn't have any on hand and neither does any other dealer close to here to compare. How certain would you say you are that 11115-62071 is a composite gasket, and that 11115-62081 is mls?
Dealer showed me that 11115-62081 replaced/superseded 11115-62080. Perhaps only 11115-62080 was composite?
Felpro's head gasket shows the same part number for 98 & 00, both being mls, so a material change would make sense in that regard.
☆Floor Mats
04-05-2018, 04:12 PM
Not sure if this helps, but I used the MLS gasket on my 97.
https://www.yotashop.com/toyota-5vzf...-kit-kit-1020/
It has a note stating:- Toyota used composite head gaskets thru 1999- late model 1999 and on used a MLS head gasket stock. The MLS head gaskets will work on all years and models.
97 4runner 3.4l, 5spd, 4wd trd s\c, urd 7th injector, tc upper arms, Fox 2.5" extended travel coil overs, Icon 2.5" piggy back rear shocks, ome 2" lift rear springs, fj cruiser wheels,custom front skid, Modified trail gear rock sliders, tundra brakes, 275/70r/17 bfg AT ko2, true track, Corbeau sport seats, trs h1 hid retrofit.
2011 BMW 135I 6spd
2009 Lexus LX570
04-05-2018, 04:59 PM
Does anyone know then if the changeover has resulted in 99+ model years having fewer or no head gasket failures?
Compared to the 2nd gen, I've barely heard of any HG failures, but now that I think about it, I don't recall if most of the 3rd gen HG failures were 96-98.5 or included all years.
04-05-2018, 05:05 PM
My HG was replaced TWICE through Toyota's HG recall campaign. Didn't cost me a penny, and that's another reason I love Toyota!
'96 T4R SR5 V6 Auto 2WD 329,000 miles
04-05-2018, 06:54 PM
Real Name: Jerod
Real Name: Jerod
The headgaskets issues on the 3VZ-E and 22-RE engines was due to the fact that the heads were aluminum and the engine block was iron. They would expand and contract at separate rates until the gaskets themselves failed. It was usually on the back of the engine where there was the most heat.
I loved my old Toyota Pickup, but absolutely despised that engine. Was definitely one of Toyota's worst.
04-05-2018, 07:07 PM
Doesn't the 5VZFE have an iron block with aluminum heads?
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
04-05-2018, 08:36 PM
It does. I'm pretty sure its mostly due to overheating and/or gasket material which is why there's more documented cases of failure on the older 3rd gens vs later ones.
'06 4Runner SR5 V8 2WD -- Flowmaster 50 Delta Series w/ resonator delete | 265/70R17 Toyo Open Country A/T | Pro Comp Series 5044 | Black headlights
'98 Jeep Cherokee Classic -- Fender armor | 35x12.5x15 Pro Comp MT2 | 4.5" RE short arm lift | Locked | Swingout Plate Rear Bumper | Shackle Relocation Kit
04-05-2018, 09:26 PM
I’ve heard oh 5vzfe with bad head gasket. I even had that experience. But not so much where it was recalled ? Was a 3rd gen head gasket ever on recall??
97 3.4 JDM/5 Speed swap/eLocker Swap/ICON CDC all around/+more.....
04-05-2018, 09:39 PM
Real Name: Scramble
Real Name: Scramble
The 5VZ & 3RZ are both iron/alum.
____________
'99 4Runner - 2.7L 3RZ, 5 Speed, 4.56 Gears - Lifted, Locked & Loaded - 166k Original owner - http://www.toyota-4runner.org/3rd-ge...ld-thread.html
'99 Limited - E-Locker- Stock (for now) - 233k 2nd Owner http://www.toyota-4runner.org/3rd-ge...ted-build.html
